How to access home/pi folder using samba
Hello!
I have set up samba but I can only see files inside home assistant folder (configuration.yaml etc.)
But my home/pi folder is empty.
How can i see files inside pi folder?
Configuration:
[global]
netbios name = RP3
server string = The Pi File Center
workgroup = WORKGROUP
hosts allow =
socket options = TCP_NODELAY IPTOS_LOWDELAY SO_RCVBUF=65536 SO_SNDBUF=65536
remote announce =
remote browse sync =
[HOMEPI]
path = /home/pi
comment = No comment
browsable = yes
read only = no
valid users =
writable = yes
guest ok = yes
public = yes
create mask = 0777
directory mask = 0777
force user = root
force create mode = 0777
force directory mode = 0777
hosts allow =
[HOME ASSISTANT]
path = /home/homeassistant/.homeassistant
read only = no
valid users =
writable = yes
guest ok = yes
public = yes
create mask = 0777
force user = root
hosts allow =
Thank you in advance.
If you use Samba with windows, the files are hinden. In windows you must set your map settings that you can see hinden files.
And ofcourse the location of your Ha files must be right :wink:
Hi
I know this is a old thread, but I have a question:
What if you already set hidden files to be visible and you still cant see any of the hidden files / folders?
