How to access Voice Assist microphone without SSL
I use nginx to access HA locally without SSL (otherwise I get domain issues using duckdns and can’t get into HA). But I can’t use Whisper without SSL:
" Your connection to Home Assistant is not secured using HTTPS. This causes browsers to block Home Assistant from accessing the microphone. Use the Home Assistant app or visit the documentation to learn how to use a secure URL"
Is there no way I can override this? Does the whole voice project require SSL?
Without SSL no (and speaking as a security professional - you don’t want it to, yes it is a security risk other projects have the same limits - see open-webui, same thing)
You CAN configure self signed, Nabu Casa. Duck, or stand up your own PKI to provide certs.
Right now I have Nabu set up with a custom external domain and use that.
