I am getting this error for the last 2 days so I would like to have access to device logs to understand whats going on, but i´ve tried following some steps without success. What is the correct way? Thanks
Go to the Integrations tab in Settings, Devices & services. Click on the integration. On the displayed screen, bottom of the menu on the left is “Enable debug logging”
Ok, done. After there where do I receive the logs?
When you toggle that off it will download the logs.
Perfect. Apparently the ip of the air conditioner changed. So I removed the integration and installed it again and everythink is fine now.
