How to add EARU Circuit Breaker to LocalTuya?
Have added this breaker https://www.aliexpress.us/item/1005006046931708.html
to Tuya integration. Works ok. I’ve tried to add it to LocalTuya and the Breaker is found but adding it fails with “Cannot connect to device. Verify that address is correct and try again”. I’ve double checked ID, IP and LocalKey and they are correct. This breaker is not supported by LocalTuya?
how did you added it to Tuya ? I can only add it to ewelink :confused:
I just followed the user manual that came with the breaker I think. I assume you don’t mean localtuya. I haven’t been able to use that.
I’m not using the breaker anymore. As it turns out it works one direction only and for the solar panels I want to use it for I need bi-directional.
There is a Wi-Fi version with Tuya firmware, and a Wi-Fi version with Ewelink firmware. But the best buy is the Zigbee version.
I guess I have the eWelink version :frowning:
