I am trying to add OSC capabilities to one of my ESPHome devices.
I keep receiving this error:
Dependency Graph
|-- lvgl @ 8.4.0
|-- noise-c @ 0.1.10
Compiling .pioenvs/esp-screen-system/src/main.cpp.o
Compiling .pioenvs/esp-screen-system/lib69a/lvgl/core/lv_disp.o
Compiling .pioenvs/esp-screen-system/lib69a/lvgl/core/lv_event.o
Compiling .pioenvs/esp-screen-system/lib69a/lvgl/core/lv_group.o
Compiling .pioenvs/esp-screen-system/lib69a/lvgl/core/lv_indev.o
Compiling .pioenvs/esp-screen-system/lib69a/lvgl/core/lv_indev_scroll.o
Compiling .pioenvs/esp-screen-system/lib69a/lvgl/core/lv_obj.o
src/main.cpp:4:10: fatal error: ArduinoOSC.h: No such file or directory
* Looking for ArduinoOSC.h dependency? Check our library registry!
* CLI > platformio lib search "header:ArduinoOSC.h"
* Web > https://registry.platformio.org/search?q=header:%1B%5Bm%1B%5BKArduinoOSC.h
4 | #include <ArduinoOSC.h>
compilation terminated.
*** [.pioenvs/esp-screen-system/src/main.cpp.o] Error 1
========================= [FAILED] Took 21.12 seconds =========================
I have the ArduinoOSC Library being installed.
Code:
esphome:
friendly_name: ESP Screen System
libraries:
- "hideakitai/ArduinoOSC@^0.6.0"
includes:
- <ArduinoOSC.h>
I have also placed the ArduinoOSC.h file in all the possible places I could think for it to need access. The main spot being the /config/esphome root folder.
Useage:
icon: "mdi:lightbulb-on"
on_press:
- lambda: |-
const char* host = "10.1.1.3";
const int port = 7700;
OscWiFi.send(host, port, "/3/toggle8", 1);
What is it i’m missing?
I am not a major programmer, but I know my way around. I have a number of esphome nodes doing various sensors around the house. I have also made osc work on a rpi fairly easily. Any help would be appreciated!!!
Tried this?
esphome:
includes:
- ArduinoOSC.h
I did. I feel like I tried every combination of including the file. I had some luck switching over to the OSC library and adding wifinina library, but now I’ve run into a whole other issue.
I am very much at a loss and would gladly start over if anyone has any clue how to get OSC running on ESPHome
neel-m
(Neel Malik)
March 15, 2026, 1:04am
4
OSC communications · Issue #942 · esphome/feature-requests · GitHub is the request for what you want, but it appears no one has done it yet.
Using external libraries can be tricky as can creating external components that use them.
Look here:
Pay close attention to this section:
You can always look at the generated PlatformIO project (.esphome/build/ ) to see what is happening - and if you want you can even copy the include files directly into the src/ folder. The includes option is only a helper option that does that for you.
The compile error indicates things are not where they should be, so you don’t have the right magic yet. Look at the generated project code to see what it is doing and what is missing.
Sorry, let me elaborate. Your includes syntax is wrong (it should be a list of files, not C syntax), and you also don’t need the #include <ArduinoOSC.h> (because ESPHome automatically adds that once you do include).
With an ESPHome directory that looks like this (I just copypasted these files from the repo):
$ ls | grep -E 'esp32.yaml|OSC.+'
ArduinoOSC.h
ArduinoOSCWiFi.h
esp32.yaml
esphome:
includes:
- ArduinoOSC.h
- ArduinoOSCWiFi.h
button:
on_press:
- lambda: !lambda |-
I only got this far though:
Reading CMake configuration...
Dependency Graph
|-- noise-c @ 0.1.10
Compiling .pioenvs/esp32/src/main.cpp.o
In file included from src/ArduinoOSC.h:4,
from src/main.cpp:441:
src/ArduinoOSCWiFi.h:14:10: fatal error: WiFi.h: No such file or directory
* Looking for WiFi.h dependency? Check our library registry!
* CLI > platformio lib search "header:WiFi.h"
* Web > https://registry.platformio.org/search?q=header:%1B%5Bm%1B%5BKWiFi.h
14 | #include <WiFi.h>
*** [.pioenvs/esp32/src/main.cpp.o] Error 1
========================= [FAILED] Took 47.63 seconds =========================
I think there’s instructions for adding the Arduino core libraries in the ESPHome documentation. Not sure how this works with ESPHome also using Wi-Fi though
Omg you just blew my mind, and I feel this will be exactly the solution I need. I will mess around with it after work tomorrow and report back. Thank you!!
Sorry I briefly glanced. Where should this code be placed?
ArduinoOSC.h
ArduinoOSCWiFi.h
esp32.yaml
This is not code, I was just trying to demonstrate where I had placed the files (all in the esphome directory where your device YAMLs are).
Oh, I kind of follow that. As if I were using terminal to navigate files. So if you don’t mind, I am using a home assistant file explorer app, where should I place those files if browsing through a smb:// connection?
I don’t know, it depends on how your ESPHome server is set up. Where ever you find your device YAML files.
I really truly appreciate your patience. I think I’m on to something here. I’m going to flash now and mess around, and I’ll post the results tomorrow. This is a really awesome community, and I look forward to growing with it!
Edit* I should mention, I’m on a RPI 4 HA build. Not that I think that matters, but maybe?
Here is the latest results
Build Error
In file included from src/WiFiNINA.h:23,
from src/BetterWiFiNINA.h:23,
from src/main.cpp:219:
src/WiFi.h:30:18: fatal error: utility/wl_definitions.h: No such file or directory
30 | #include "utility/wl_definitions.h"
========================= [FAILED] Took 207.72 seconds =========================
YAML
esphome:
#libraries:
#- OSC
#- gershnik/BetterWiFiNINA@^1.3.0
#- file:///config/ArduinoOSC-main/library.json
#- cnmat/OSC@^1.0.0
#- "hideakitai/ArduinoOSC@^0.6.0"
#- file:///ArduinoOSC-main/ArduinoOSC
includes:
- src/BetterWiFiNINA.h
#- src/WiFiNINA.h
#- src/WiFi.h
#- src/utility/wl_definitions.h
#- <WiFiUdp.h>
#- <OSCMessage.h>
- osc/ArduinoOSC.h
- osc/ArduinoOSCWiFi.h
#- <WiFi.h>
#- "<ArduinoOSC.h>"
#- <ArduinoOSCWiFi.h>
#- test.h
esp32:
board: esp32dev
framework:
type: esp-idf
YAML
on_press:
YAML
- button:
width: 70
height: 68
checkable: false
#state:
# checked: true # here you activate the state to be used at boot
# checked:
# bg_color: 0x00FF00
widgets:
- label:
align: CENTER
width: 70
text: "redchase\nToggle"
text_align: CENTER
long_mode: wrap
on_click:
- button.press: redchase_toggle
can you direct me as to how to find the path?
“You can always look at the generated PlatformIO project (.esphome/build/ )”
is that somrething I need to ssh into my rpi ha system for? Or something I can access through a file manager app? I can’t seem to find that hidden folder with the access I currently have. Nor can I find the answer as to where I modify those files.
This is one of the more fun puzzles I have yet to solve
Forgive me, this was not true - not sure why I assumed this off the top of my head. This compiles:
esphome:
libraries:
- "arduino-libraries/[email protected] "
- "SPI"
includes:
button:
on_press:
I don’t actually know what it does though, so you’ll have to test if it works in runtime.
So I gave this a shot, but I am receving the same error:
In file included from src/ArduinoOSCWiFi.h:14,
from src/main.cpp:4:
========================= [FAILED] Took 21.77 seconds =========================
still in limbo… Here is the full yaml
esphome:
libraries:
#- "cnmat/OSC@^1.0.0"
#- "jandrassy/WiFiEspAT@^2.0.0"
#- "arduino-libraries/[email protected] "
#- "vekjja/ESPWiFi@^0.0.1"
#- "SPI"
includes:
# - src/BetterWiFiNINA.h
#- src/WiFiNINA.h
# - src/WiFi.h
#- wifi/src/WiFiUdp.h
#- <OSCMessage.h>
#- arduino-osc/ArduinoOSC.h
#- arduino-osc/ArduinoOSCWiFi.h
#- osc/OSCBoards.h
#- espwifi/src/WiFiEspAT.h
#- <WiFi.h>
#- "<ArduinoOSC.h>"
#- test.h
esp32:
board: esp32dev
framework:
type: esp-idf
# Enable logging
logger:
# Enable Home Assistant API
api:
encryption:
key: "RPkjFZcCR1hdc8om2VR9jysCBiKHx1UjwJVVXgt/W/0="
on_client_connected:
- if:
condition:
lambda: 'return (0 == client_info.find("Home Assistant "));'
then:
- lvgl.widget.show: lbl_hastatus
on_client_disconnected:
- if:
condition:
then:
- lvgl.widget.hide: lbl_hastatus
ota:
- platform: esphome
password: "f1f32c8baacd0a966872af47e40cc314"
wifi:
ssid: !secret wifi_ssid
ap:
ssid: "Esp-Screen-System"
password: "SLpgtLGyfy0H"
captive_portal:
light:
- platform: monochromatic
output: backlight_pwm
name: Display Backlight
restore_mode: ALWAYS_ON
output:
- platform: ledc
pin: GPIO21
spi:
- id: tft
clk_pin: GPIO14
mosi_pin: GPIO13
miso_pin: GPIO12
- id: touch
clk_pin: GPIO25
mosi_pin: GPIO32
miso_pin: GPIO39
font:
- file: "fonts/Dosis-Bold.ttf" #"gfonts://Roboto"
bpp: 4
extras:
- file: "fonts/materialdesignicons-webfont.ttf"
glyphs: [
"\U000F02D1", # mdi-heart
"\U000F05D4", # mdi-airplane-landing
"\U000F0055", # arrow right
"\U000F004E", # arrow left
"\U000F0827", # house
"\U000F0928", # wifi icon
"\U000F02E3", # bed
"\U000F04B9", # couch
"\U000F0979", # moon-star
"\U000F0A84", # H symbol hallway
"\U000F0C2D", #W Symbol WLED
"\U000F060A", #wifi symbol slanted
"\U000F1A45", #AC Icon
"\U000F005E", #Up Arrow
"\U000F0046", #Down Arrow
"\U000F003B", #mode button
"\U000F0B12", #K=symbol Kitchen LED
"\U000F1051", #strip symbol
"\U000F1B2A", #kitchen Sink
"\U000F0379", #tv icon
"\U000F03CB" #hyperion icon
bpp: 4
- file: "https://github.com/IdreesInc/Monocraft/releases/download/v3.0/Monocraft.ttf"
- file:
url: "https://github.com/IdreesInc/Monocraft/releases/download/v3.0/Monocraft.ttf"
type: web
image:
- file: "images/lightning.png"
type: RGB565 # Recommended for performance
#resize: 240x380 # Match your display resolution
display:
- platform: mipi_spi
spi_id: tft
model: ESP32-2432S028
dimensions:
height: 320
width: 240
rotation: 270
cs_pin: GPIO15
dc_pin: GPIO2
reset_pin: GPIO04
color_depth: 16
color_order: RGB
# the following are for LVGL
auto_clear_enabled: false
update_interval: never
touchscreen:
- platform: xpt2046
spi_id: touch
cs_pin: GPIO33
interrupt_pin: GPIO36
transform:
mirror_x: True
mirror_y: False
swap_xy: False
calibration:
x_min: 330
x_max: 3780
y_min: 320
y_max: 3750
button:
name: "BB Fan Light"
on_press:
- homeassistant.service:
service: light.toggle
entity_id: light.bruce_br_fan
- logger.log: "Soft Button pressed"
on_press:
service: button.press
entity_id: button.esp_ac_unit_ir_bruce_bedroom_ac_power
#on_press:
#- lambda: !lambda |-
#const char* host = "10.1.1.3";
#const int port = 7700;
#OscWiFi.send(host, port, "/3/toggle8", 1);
#include <WiFiUdp.h>
#include <OSCMessage.h>
#WiFiUDP udp;
#OSCMessage msg("/3/toggle8"); // Your OSC Path
#msg.add(1); // Optional argument
#udp.beginPacket("10.1.1.3", 7700); // Target IP and Port
#msg.send(udp);
#udp.endPacket();
#msg.empty();
binary_sensor:
- platform: homeassistant
publish_initial_state: true # Ensure the state is synced on boot
internal: true
lvgl:
#bg_color: 0x000000
bg_image_src: my_background
theme:
label:
text_font: my_font # set all your labels to use your custom defined font
button:
#bg_color: 0x8585e0
#bg_grad_color: 0x005782
#bg_grad_dir: VER
#bg_opa: COVER
bg_opa: TRANSP
border_color: 0x3333ff
border_width: 1
text_color: 0xFFFFFF
pressed: # set some button colors to be different in pressed state
bg_color: 0x006699
bg_grad_color: 0x00334d
checked: # set some button colors to be different in checked state
#bg_color: 0x1d5f96
bg_opa: TRANSP
bg_grad_color: 0x03324A
text_color: 0x00e6e6
buttonmatrix:
bg_opa: TRANSP
border_color: 0x0077b3
border_width: 0
pad_all: 0
items: # set all your buttonmatrix buttons to use your custom defined styles and font
bg_color: 0x2F8CD8
bg_grad_dir: VER
bg_opa: COVER
border_width: 1
text_font: my_font
pressed:
bg_color: 0x006699
checked:
bg_color: 0x1d5f96
text_color: 0x005580
switch:
bg_color: 0xC0C0C0
bg_grad_color: 0xb0b0b0
bg_grad_dir: VER
bg_opa: COVER
checked:
bg_color: 0x1d5f96
bg_grad_dir: VER
bg_opa: COVER
knob:
bg_color: 0xFFFFFF
bg_grad_color: 0xC0C0C0
bg_grad_dir: VER
bg_opa: COVER
slider:
border_width: 1
border_opa: 15%
bg_color: 0xcccaca
bg_opa: 15%
indicator:
bg_color: 0x1d5f96
bg_grad_dir: VER
bg_opa: COVER
knob:
bg_color: 0x2F8CD8
bg_grad_dir: VER
bg_opa: COVER
border_width: 1
style_definitions:
- id: header_footer
#bg_color: 0x2F8CD8
bg_grad_dir: VER
#bg_opa: COVER
bg_opa: TRANSP
#border_opa: TRANSP
border_color: 0x4dffff
border_opa: COVER
radius: 0
pad_all: 0
pad_row: 0
pad_column: 0
width: 100%
height: 30
top_layer:
widgets:
- buttonmatrix:
align: bottom_mid
styles: header_footer
#text_font: icons_50
pad_all: 0
outline_width: 0
items:
rows:
- buttons:
- id: page_prev
text: "\U000F004E"
on_press:
then:
lvgl.page.previous:
- id: page_home
text: "\U000F0827"
on_press:
then:
lvgl.page.show: main_page
- id: page_next
text: "\U000F0055"
on_press:
then:
lvgl.page.next:
- label:
text: "\U000F060A"
hidden: true
align: top_right
x: -2
y: 7
text_align: right
text_color: 0x80ffe5
pages:
- id: main_page
widgets:
- obj:
align: TOP_MID
border_opa: TRANSP
width: 100%
widgets:
- label:
text: "Lighting"
align: CENTER
text_align: CENTER
text_color: 0x4d4dff
- obj:
align: CENTER
width: 228
height: 224
x: 3
y: 3
pad_all: 2
#bg_color: 0x99e6ff
bg_opa: TRANSP
border_opa: TRANSP
layout: # enable the FLEX layout for the children widgets
type: FLEX
flex_flow: COLUMN_WRAP # the order of the widgets starts top left
flex_align_cross: CENTER # they sould be centered
pad_row: 5
pad_column: 5
widgets:
- button:
width: 68
height: 68
checkable: true
#state:
checked:
#bg_color: 0x00FF00
border_color: 0x00ff00
widgets:
- label:
align: CENTER
text: "\U000F02E3\nBedroom"
text_align: CENTER
long_mode: wrap
on_click:
- homeassistant.action:
action: light.toggle
- logger.log: "BR Fan"
- button:
width: 68
height: 68
checkable: true
checked:
bg_color: 0x00FF00
widgets:
- label:
align: CENTER
text: "\U000F0A84\nHallway\nWLED"
text_align: CENTER
long_mode: wrap
on_click:
#- button.press: light_off
entity_id: light.hall_2
- logger.log: "Hall Press"
- button:
width: 68
height: 68
checkable: true
checked:
bg_color: 0x00FF00
widgets:
- label:
align: CENTER
width: 100%
text: "\U000F0C2D\nWall Palm"
text_align: CENTER
long_mode: wrap
on_click:
entity_id: light.wall_palm
- logger.log: "Wall Palm"
- button:
width: 68
height: 68
checkable: true
checked:
bg_color: 0x00FF00
widgets:
- label:
align: CENTER
width: 100%
text: "\U000F0C2D\nLR WLED"
text_align: CENTER
long_mode: wrap
on_click:
entity_id: light.livingroom
- logger.log: "LR WLED"
- button:
width: 68
height: 68
checkable: true
checked:
bg_color: 0x00FF00
widgets:
- label:
align: CENTER
width: 100%
text: "\U000F04B9\nLR Fan"
text_align: CENTER
long_mode: wrap
on_click:
entity_id: light.fan_living_room
- logger.log: "LR Fan"
- button:
width: 68
height: 68
checkable: true
checked:
bg_color: 0x00FF00
widgets:
- label:
align: CENTER
width: 100%
text: "\U000F0979\nNight\nLight"
text_align: CENTER
long_mode: wrap
on_click:
entity_id: light.night_light
- logger.log: "Nightlight"
- button:
width: 68
height: 68
checkable: true
checked:
bg_color: 0x00FF00
widgets:
- label:
align: CENTER
width: 100%
text: "\U000F0B12\nKit\nLED"
text_align: CENTER
long_mode: wrap
on_click:
entity_id: light.kitchen_strip
- logger.log: "KitchenvLED"
- button:
width: 68
height: 68
checkable: true
checked:
bg_color: 0x00FF00
widgets:
- label:
align: CENTER
width: 100%
text: "\U000F1B2A\nKit\nSink"
text_align: CENTER
long_mode: wrap
on_click:
entity_id: light.sink
- logger.log: "Kitchen Sink"
- button:
width: 68
height: 68
checkable: true
checked:
bg_color: 0x00FF00
widgets:
- label:
align: CENTER
width: 100%
text: "\U000F1051\nBath\nStrip"
text_align: CENTER
long_mode: wrap
on_click:
entity_id: light.strip_bathroom
- logger.log: "Bath Strip"
- id: ac_page
widgets:
- obj:
align: TOP_MID
border_opa: TRANSP
widgets:
- label:
text: "AC Control"
align: CENTER
text_align: CENTER
- obj:
align: CENTER
width: 228
height: 224
x: 3
y: 3
pad_all: 2
#bg_color: 0x00cccc
bg_opa: TRANSP
border_opa: TRANSP
type: FLEX
pad_row: 5
pad_column: 5
widgets:
- button:
width: 70
height: 68
checkable: true
checked:
bg_color: 0x00FF00
widgets:
- label:
align: CENTER
text: "\U000F1A45\nAC Power"
text_align: CENTER
long_mode: wrap
on_click:
#- button.press: ac_toggle
- logger.log: "AC Power"
- button:
width: 70
height: 68
checkable: false
#state:
#checked:
widgets:
- label:
align: CENTER
width: 70
text: "\U000F005E\nUp"
text_align: CENTER
long_mode: wrap
on_click:
entity_id: button.esp_ac_unit_ir_bruce_bedroom_ac_temp_up
- logger.log: "AC Up"
- button:
width: 70
height: 68
checkable: false
#state:
# checked:
widgets:
- label:
align: CENTER
width: 70
text: "\U000F0046\nDown"
text_align: CENTER
long_mode: wrap
on_click:
entity_id: button.esp_ac_unit_ir_bruce_bedroom_ac_temp_down
- logger.log: "AC Down"
- button:
width: 70
height: 68
checkable: false
#state:
# checked:
widgets:
- label:
align: CENTER
width: 70
text: "\U000F003B\nMode"
text_align: CENTER
long_mode: wrap
on_click:
entity_id: button.esp_ac_unit_ir_bruce_bedroom_ac_mode
- logger.log: "AC mode"
- id: l_var
widgets:
- obj:
align: TOP_MID
border_opa: TRANSP
widgets:
- label:
text: "TV Controls"
align: CENTER
text_align: CENTER
- obj:
align: CENTER
width: 228
height: 224
x: 3
y: 3
pad_all: 2
#bg_color: 0x751aff
bg_opa: TRANSP
border_opa: TRANSP
type: FLEX
pad_row: 5
pad_column: 5
widgets:
- button:
width: 70
height: 68
checkable: true
#state:
checked:
bg_color: 0x00FF00
widgets:
- label:
align: CENTER
text: "\U000F0379\nTv On/off"
text_align: CENTER
#icon: "mdi:lightbulb-on"
on_click:
action: media_player.toggle
entity_id: media_player.qled
- logger.log: "TV Off"
- button:
width: 70
height: 68
checkable: false
#state:
# checked:
widgets:
- label:
align: CENTER
width: 70
text: "\U000F03CB\nHyperion\nLR Toggle"
text_align: CENTER
long_mode: wrap
on_click:
service: switch.toggle
entity_id: switch.livingroom_hyperion_component_all
- logger.log: "LR Hyperion Off/on"
- button:
width: 70
height: 68
checkable: false
#state:
# checked:
widgets:
- label:
align: CENTER
width: 70
text: "\U000F03CB\nHyperion\nBR Toggle"
text_align: CENTER
long_mode: wrap
on_click:
entity_id: switch.first_led_hardware_instance_component_all
- logger.log: "BR Hyperion Off/on"
- button:
width: 70
height: 68
checkable: false
#state:
# checked:
widgets:
- label:
align: CENTER
width: 70
text_align: CENTER
long_mode: wrap
on_click:
#WiFiUDP udp;
#OSCMessage msg("/3/toggle8"); # Your OSC Path
#msg.add(1); # Optional argument
#udp.beginPacket("10.1.1.3", 7700); # Target IP and Port
#msg.send(udp);
#udp.endPacket();
#msg.empty();
Have you tried arduino framework?
esp32:
framework:
type: arduino
I thought in theory esp-idf should work since we’re providing all the libraries, but only arduino seemed to work.
