Hello, I’m new to HA.
I want to see if a switch from Openhab to Home Assistant is easy and doable.
I have many sensors that communicate with my smart home via MQTT.
Now I’m struggling with my gas meter.
This sensor report every minute the difference of the gasmeter since the last report. So the payload is normally between 0.00 and 0.01.
I use an automation wich triggered by the payload of 0.01 from the sensor. this most of the time works fine.
But how I can add more as 0.01 sometimes the value is 0.03 or 0.02.
It is possible to add the value of the senors payload directly to the Helper entity?
description: Test des Gaszählers
- platform: mqtt
topic: CountSensor/Gas_count/impuls
payload: "0.01"
condition: []
- service: counter.increment
data: {}
entity_id: counter.gas_zaehler_h
mode: single
