How to add Picture
Hi, I’m hoping to somebody this is a very simple question, but I’m struggling to be able to put a picture on a dashboard
For example I have a page that displays details about my Synology NAS , so I wanted to put a picture of the NAS on the dashboard … simple right… Nope Tried the picture card with the jpg picture in config/www/sunology.jpg No picture … Tried a number of url’s nothing as worked
Please do tell me where I am going wrong
Many thanks
Regards Andy
show us the yaml please in right formating
entity: input_select.washing_machine_status
state_image:
  Clean: /local/images/laundry_clean_2_square.jpg
  Finishing: /local/images/washer_square.jpg
  Idle: /local/images/washer_square.jpg
  Running: /local/images/laundry_running_square.jpg
type: picture-entity
or
type: picture-elements
elements: []
image: /local/images/plants.jpg
where local is the www folder (if you dont have one just created it)
Hi
Thanks for the reply. I think it must be me being daft but it just doesn’t work for me
So this is the yaml from the card
elements: []
image: /local/images/synology.jpg
and this is the result (after a restart)
I have a www folder inside which is an images folder and I placed the jpg file in there
so path is www/images/synology.jpg which I believe translates to /local/images/synology.jpg
Also checked the picture is square as I read somewhere all images must be square but not sure thats correct .
Help please as I’m sure this is easy but I’m not understanding why it doesnt work for me
Thanks for the help
Regards
Andy
Yes your Path is right
Dum question is the file name the same case
did you do a F5 or Ctrl+R on the page
Hi, thanks for the reply/help
yes I’ve checked the case … every letter is correct… also tried both F5 and Ctrl+R
Its very strange … I cant seem to get any picture to work no matter what I try
Hi @AndyN,
I seem to have the exact same issue! Created a docker container of HA on my Synology NAS, and can’t seem to find the image located in /www/image/ (which should be /local/image/ in HA).
Have you ever found a way to fix this issue?
Kind regards!
For future reference:
I have found that adding the folder via the Synology GUI, made the folder not visible to Home Assistant. I fixed this by opening a terminal via Container Manager > Containers > Home Assistant container and creating the folder from there using mkdir.
Now I have a folder in /docker/homeassistant/www/ which is accessible in Home Assistant via /local/
