i tried to add a Device with QR Code, but it s seams that home assitant app and also safari have no access to the camera …
do you have a solution ?
thx
Take a picture and import the photo in zwave js UI (if that is what you are using)
or:
https://www.macobserver.com/tips/how-to/how-to-enable-webcam-in-safari-on-ios/
I had to enable HTTPS / SSL before I could do this:
To use a Z-Wave QR code in Home Assistant, you must first set up a secure connection using HTTPS, which requires installing SSL certificates. Once HTTPS is configured, you can use the Home Assistant mobile app or the Z-Wave JS UI add-on to scan the QR code found on the device’s packaging to add it to your network via Smartstart
