I recently moved from raspberry pi to an intel NUC with ubuntu server and hassio installed in a docker container. Since I’m starting over I also want to rebuild my zwave network so I’ve reset the zwave stick.
I added my zwave stick to my configuration using integrations and filled in ‘/dev/ttyACM0’ for the USB path.
It looked like the stick was added fine but somehow i cannot add devices.
Are there some easy to follow instructions on how to add the stick to docker. (I’m also installed portainer to manage my docker containers)
THat was indeed the problem. Only two nodes are still giving me troubles. Sensative door/window strip seems to be in “Wakeup” and somehow I can’t reset the aeoteck trisensor… Any advice?
