Hi there,
Im trying add somfy roller blinds + fgrm-222 + Aeotec by Aeon Labs Z-Stick to Hassbian. I wired everything and the blinds go up and down.
However, it doesnt go down all the way it stops somewhere 80% of the window.
I wonder how can i move this to correct position so it covers all the window?
So far i tried setting different parameters including parameter 29 with no luck.
Another thing to mention is that i dont have a switch and use hassbian->Configuration->zwave to set all this up. I wonder if i missing anything?
You should run it wherever you have your Z-wave stick, so I’d assume hassbian. Last time I used it (a year or so ago) you still had to compile it from scratch.
Hmm, is there any simpler/more user friendly way to calibrate zwave blinds?
If openzwave is the only option I wonder if anyone who worked with it knows whether there is a way to calibrate low and high positions of the blinds?
