my Samsung has routines and automations. Not SmartThings, actual android automations like when you get into a location or receive a notification.
I’m trying to call home assistant from it, I added a shortcut on home assistant and was able to call from an android automation but instead of running the script it opens the script page so I can click run, and I have to unlock the screen first.
Is there a way to launch a script directly from an automation?
I am using, however I need to trigger something with my samsung smarttag2, which triggers the routines with a notification, and routines should trigger home assistant
