How to call command line from Hassio
I’m running Hassio on RPi. The seven segment display OCR component under “setup process” suggests doing some initial tests before finalising the parameters for the configuration.yaml file by executing ssocr from the command line.
How do I execute ssocr from a command line in hassio?
You missed the notice above that which told to skip that part if using Hassio.
I have followed the instructions on the guide to enable seven segment (I can see it as a new item) but I cannot access the command line tool. When I try to digit ssocr it simply is not installed in hass.io
did u manage to get the cmd line working? I am having the same issue.
thanks
Fred
