How to capture a trigger event in UI
I’m a new user to HA and trying to figure things out…
I have a simple binary helper sensor that combines motion from cameras and philips hue outdoor motion sensors. I want to have this turn lights on when motion is detected and at the same time start a timer to turn lights offf after X mins.
The problem is how the heck do I capture the timer.finished event?
As far as I can tell I can easily add the timer entity in automations but it’s missing the finished option. So I’m assuming to capture the change to timer.finished I need to do this some other way?
I would expect I can just create a new automation, use the timer as the entity and then select “timer.finished” to do things… However this does not seem to be the case so what am I missing?
You don’t need a timer. See Motion activated lights automation
You would use an Event trigger.
Thanks. That works fine for basics but what I’m trying to achieve in the end is to have a single timer that gets reset or disabled by multiple different things (motion sensors,buttons/switches, state of the home etc). Hence I’d really like to understand how to capture that timer.finished event to make life simpler… Also I’m assuming it should be something quite basic.
You know what they say about assumptions…
If you look at the basic examples presented in the Timer integration docs, you will see that the suggested method is to use a Event trigger.
