How to change mode of a z-wave device
I do have a :climate.eurotronic_eur_cometz_wall_radiator_thermostat_valve_control_comfort_setpoint_8_1
Which does habe the following Attributes:
battery_level: 97
current_temperature: 22.5
friendly_name: Eurotronic Comforttemp Setpoint
max_temp: 35
min_temp: 7
node_id: 8
operation_list: Heat Econ,Off,Heat
operation_mode: Heat
temperature: 22
unit_of_measurement: °C
My question is how I can change the operation_mode from Heat to Off in HA?
climate.set_operation_mode:
I do have a zwave device. So I added:
climate:
  platform: zwave
But the whole config is not changing anything in my zwave thermostat.
- alias: Turn on Heater at 8pm
      - platform: time
        after: "08:00:00"
      - service: climate.set_operation_mode
        entity_id: climate.eurotronic_eur_cometz_wall_radiator_thermostat_valve_control_furnace_8_7
      - service: climate.set_temperature
          temperature: "{{states.input_slider.temperatur_bad.state}}"
      - service: notify.my_pushbullet
        data_template:
          message: "Bad Heat auf {{states.input_slider.temperatur_bad.state}} Grad"
- alias: Turn off Heater at 21:00
      - platform: time
        after: "21:00:00"
          operation_mode: 'Off'
        data_template:
          message: "Bad Heat turned OFF"
Try it like this:
and
  data_template:
Sebastian
