This one has solved it. Thanks to you!
Here’s my flow for everbody who’s interested:
[{"id":"b4f7b0b8.7bb9f8","type":"tab","label":"Schildkröten Automation","disabled":false,"info":""},{"id":"3389c9c8.74a64e","type":"switch","z":"b4f7b0b8.7bb9f8","name":"Warm oder kalt?","property":"payload","propertyType":"msg","rules":[{"t":"gte","v":"uppertempday","vt":"global"},{"t":"lt","v":"midtempday","vt":"global"},{"t":"lt","v":"lowertempday","vt":"global"}],"checkall":"true","repair":false,"outputs":3,"x":620,"y":140,"wires":[["9a8db627.6dcb3","bfbcf1bc.95095"],["b0c3b017.1d3578"],["e874821a.471528","b0c3b017.1d3578"]]},{"id":"58287db0.b9c094","type":"debug","z":"b4f7b0b8.7bb9f8","name":"","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"payload","targetType":"msg","statusVal":"","statusType":"auto","x":390,"y":240,"wires":[]},{"id":"9a8db627.6dcb3","type":"api-current-state","z":"b4f7b0b8.7bb9f8","name":"Lampe an oder aus?","server":"86616542.19f378","version":3,"outputs":2,"halt_if":"on","halt_if_type":"str","halt_if_compare":"is","entity_id":"switch.smart_outdoor_plug_mss620_switch_1","state_type":"str","blockInputOverrides":false,"outputProperties":[{"property":"payload","propertyType":"msg","value":"","valueType":"entityState"},{"property":"data","propertyType":"msg","value":"","valueType":"entity"}],"for":0,"forType":"num","forUnits":"minutes","override_topic":false,"state_location":"payload","override_payload":"msg","entity_location":"data","override_data":"msg","x":880,"y":60,"wires":[["caf0a08c.adb5b8"],[]]},{"id":"322e11d5.32dbe6","type":"time-range-switch","z":"b4f7b0b8.7bb9f8","name":"Tag oder Nacht","lat":"52.039453","lon":"7.477365","startTime":"sunriseEnd","endTime":"sunset","startOffset":0,"endOffset":0,"x":400,"y":300,"wires":[["3389c9c8.74a64e"],["79c77414.9b3e0c"]]},{"id":"caf0a08c.adb5b8","type":"api-call-service","z":"b4f7b0b8.7bb9f8","name":"Lampe ausschalten","server":"86616542.19f378","version":5,"debugenabled":true,"domain":"switch","service":"turn_off","areaId":[],"deviceId":[],"entityId":["switch.smart_outdoor_plug_mss620_switch_1"],"data":"","dataType":"jsonata","mergeContext":"","mustacheAltTags":false,"outputProperties":[],"queue":"none","x":1210,"y":200,"wires":[[]]},{"id":"bfbcf1bc.95095","type":"api-current-state","z":"b4f7b0b8.7bb9f8","name":"Keramikstrahler an oder aus?","server":"86616542.19f378","version":3,"outputs":2,"halt_if":"on","halt_if_type":"str","halt_if_compare":"is","entity_id":"switch.smart_outdoor_plug_mss620_switch_2","state_type":"str","blockInputOverrides":false,"outputProperties":[{"property":"payload","propertyType":"msg","value":"","valueType":"entityState"},{"property":"data","propertyType":"msg","value":"","valueType":"entity"}],"for":0,"forType":"num","forUnits":"minutes","override_topic":false,"state_location":"payload","override_payload":"msg","entity_location":"data","override_data":"msg","x":890,"y":120,"wires":[["ecb6e973.c2cad"],[]]},{"id":"ecb6e973.c2cad","type":"api-call-service","z":"b4f7b0b8.7bb9f8","name":"Keramikstrahler ausschalten","server":"86616542.19f378","version":5,"debugenabled":false,"domain":"switch","service":"turn_off","areaId":[],"deviceId":[],"entityId":["switch.smart_outdoor_plug_mss620_switch_2"],"data":"","dataType":"jsonata","mergeContext":"","mustacheAltTags":false,"outputProperties":[],"queue":"none","x":1220,"y":320,"wires":[[]]},{"id":"513c7bc8.2a282c","type":"api-call-service","z":"b4f7b0b8.7bb9f8","name":"Lampe einschalten","server":"86616542.19f378","version":5,"debugenabled":false,"domain":"switch","service":"turn_on","areaId":[],"deviceId":[],"entityId":["switch.smart_outdoor_plug_mss620_switch_1"],"data":"","dataType":"jsonata","mergeContext":"","mustacheAltTags":false,"outputProperties":[],"queue":"none","x":1210,"y":140,"wires":[[]]},{"id":"dbea14c9.1b85","type":"api-call-service","z":"b4f7b0b8.7bb9f8","name":"Keramikstrahler einschalten","server":"86616542.19f378","version":5,"debugenabled":false,"domain":"switch","service":"turn_on","areaId":[],"deviceId":[],"entityId":["switch.smart_outdoor_plug_mss620_switch_2"],"data":"","dataType":"jsonata","mergeContext":"","mustacheAltTags":false,"outputProperties":[],"queue":"none","x":1220,"y":260,"wires":[["85f161d1.7eddc"]]},{"id":"79c77414.9b3e0c","type":"switch","z":"b4f7b0b8.7bb9f8","name":"Warm oder kalt?","property":"payload","propertyType":"msg","rules":[{"t":"nnull"},{"t":"lt","v":"lowertempnight","vt":"global"},{"t":"gte","v":"uppertempnight","vt":"global"}],"checkall":"true","repair":false,"outputs":3,"x":620,"y":360,"wires":[["665b7dfb.fc8ce4"],["e6643818.b040c"],["2a2a29c0.4f6c36"]]},{"id":"b0c3b017.1d3578","type":"api-current-state","z":"b4f7b0b8.7bb9f8","name":"Lampe an oder aus?","server":"86616542.19f378","version":3,"outputs":2,"halt_if":"on","halt_if_type":"str","halt_if_compare":"is","entity_id":"switch.smart_outdoor_plug_mss620_switch_1","state_type":"str","blockInputOverrides":false,"outputProperties":[{"property":"payload","propertyType":"msg","value":"","valueType":"entityState"},{"property":"data","propertyType":"msg","value":"","valueType":"entity"}],"for":0,"forType":"num","forUnits":"minutes","override_topic":false,"state_location":"payload","override_payload":"msg","entity_location":"data","override_data":"msg","x":880,"y":180,"wires":[[],["513c7bc8.2a282c"]]},{"id":"e874821a.471528","type":"api-current-state","z":"b4f7b0b8.7bb9f8","name":"Keramikstrahler an oder aus?","server":"86616542.19f378","version":3,"outputs":2,"halt_if":"on","halt_if_type":"str","halt_if_compare":"is","entity_id":"switch.smart_outdoor_plug_mss620_switch_2","state_type":"str","blockInputOverrides":false,"outputProperties":[{"property":"payload","propertyType":"msg","value":"","valueType":"entityState"},{"property":"data","propertyType":"msg","value":"","valueType":"entity"}],"for":0,"forType":"num","forUnits":"minutes","override_topic":false,"state_location":"payload","override_payload":"msg","entity_location":"data","override_data":"msg","x":890,"y":240,"wires":[[],["dbea14c9.1b85"]]},{"id":"e6643818.b040c","type":"api-current-state","z":"b4f7b0b8.7bb9f8","name":"Keramikstrahler an oder aus?","server":"86616542.19f378","version":3,"outputs":2,"halt_if":"on","halt_if_type":"str","halt_if_compare":"is","entity_id":"switch.smart_outdoor_plug_mss620_switch_2","state_type":"str","blockInputOverrides":false,"outputProperties":[{"property":"payload","propertyType":"msg","value":"","valueType":"entityState"},{"property":"data","propertyType":"msg","value":"","valueType":"entity"}],"for":0,"forType":"num","forUnits":"minutes","override_topic":false,"state_location":"payload","override_payload":"msg","entity_location":"data","override_data":"msg","x":890,"y":360,"wires":[[],["dbea14c9.1b85"]]},{"id":"2a2a29c0.4f6c36","type":"api-current-state","z":"b4f7b0b8.7bb9f8","name":"Keramikstrahler an oder aus?","server":"86616542.19f378","version":3,"outputs":2,"halt_if":"on","halt_if_type":"str","halt_if_compare":"is","entity_id":"switch.smart_outdoor_plug_mss620_switch_2","state_type":"str","blockInputOverrides":false,"outputProperties":[{"property":"payload","propertyType":"msg","value":"","valueType":"entityState"},{"property":"data","propertyType":"msg","value":"","valueType":"entity"}],"for":0,"forType":"num","forUnits":"minutes","override_topic":false,"state_location":"payload","override_payload":"msg","entity_location":"data","override_data":"msg","x":890,"y":420,"wires":[["ecb6e973.c2cad"],[]]},{"id":"665b7dfb.fc8ce4","type":"api-current-state","z":"b4f7b0b8.7bb9f8","name":"Lampe an oder aus?","server":"86616542.19f378","version":3,"outputs":2,"halt_if":"on","halt_if_type":"str","halt_if_compare":"is","entity_id":"switch.smart_outdoor_plug_mss620_switch_1","state_type":"str","blockInputOverrides":false,"outputProperties":[{"property":"payload","propertyType":"msg","value":"","valueType":"entityState"},{"property":"data","propertyType":"msg","value":"","valueType":"entity"}],"for":0,"forType":"num","forUnits":"minutes","override_topic":false,"state_location":"payload","override_payload":"msg","entity_location":"data","override_data":"msg","x":880,"y":300,"wires":[["caf0a08c.adb5b8"],[]]},{"id":"f3f5cde9.757828","type":"poll-state","z":"b4f7b0b8.7bb9f8","name":"Schildkröten Temperatur","server":"86616542.19f378","version":2,"exposeToHomeAssistant":false,"haConfig":[{"property":"name","value":""},{"property":"icon","value":""}],"updateinterval":"30","updateIntervalType":"num","updateIntervalUnits":"seconds","outputinitially":false,"outputonchanged":true,"entity_id":"sensor.schildkrotengehege_temperatur","state_type":"num","halt_if":"","halt_if_type":"str","halt_if_compare":"is","outputs":1,"x":150,"y":280,"wires":[["322e11d5.32dbe6","58287db0.b9c094"]]},{"id":"46a2955f.e94dac","type":"stoptimer","z":"b4f7b0b8.7bb9f8","duration":"1","units":"Hour","payloadtype":"num","payloadval":"0","name":"","x":1690,"y":220,"wires":[["450799ae.7a5c4","e63e3b7c.6363f8"],[]]},{"id":"450799ae.7a5c4","type":"switch","z":"b4f7b0b8.7bb9f8","name":"Warm oder kalt?","property":"payload","propertyType":"msg","rules":[{"t":"gte","v":"14","vt":"str"},{"t":"lt","v":"14","vt":"str"}],"checkall":"true","repair":false,"outputs":2,"x":1480,"y":260,"wires":[["ecb6e973.c2cad"],["46a2955f.e94dac"]]},{"id":"85f161d1.7eddc","type":"time-range-switch","z":"b4f7b0b8.7bb9f8","name":"Tag oder Nacht","lat":"52.039453","lon":"7.477365","startTime":"sunriseEnd","endTime":"sunset","startOffset":0,"endOffset":0,"x":1480,"y":200,"wires":[[],["46a2955f.e94dac"]]},{"id":"e63e3b7c.6363f8","type":"debug","z":"b4f7b0b8.7bb9f8","name":"","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"false","statusVal":"","statusType":"auto","x":1890,"y":220,"wires":[]},{"id":"c2870d4adf82c8df","type":"server-state-changed","z":"b4f7b0b8.7bb9f8","name":"Upper Temp Day","server":"86616542.19f378","version":4,"exposeToHomeAssistant":false,"haConfig":[{"property":"name","value":""},{"property":"icon","value":""}],"entityidfilter":"input_number.temperatur_schildkroten_tagsuber_maximum","entityidfiltertype":"exact","outputinitially":false,"state_type":"str","haltifstate":"","halt_if_type":"str","halt_if_compare":"is","outputs":1,"output_only_on_state_change":false,"for":"0","forType":"num","forUnits":"minutes","ignorePrevStateNull":false,"ignorePrevStateUnknown":false,"ignorePrevStateUnavailable":false,"ignoreCurrentStateUnknown":false,"ignoreCurrentStateUnavailable":false,"outputProperties":[{"property":"uppertempday","propertyType":"global","value":"","valueType":"entityState"}],"x":380,"y":60,"wires":[["3389c9c8.74a64e"]]},{"id":"586fd7a53a22b3c5","type":"server-state-changed","z":"b4f7b0b8.7bb9f8","name":"Mid Temp Day","server":"86616542.19f378","version":4,"exposeToHomeAssistant":false,"haConfig":[{"property":"name","value":""},{"property":"icon","value":""}],"entityidfilter":"input_number.temperatur_schildkroten_tagsuber_medium","entityidfiltertype":"exact","outputinitially":false,"state_type":"str","haltifstate":"","halt_if_type":"str","halt_if_compare":"is","outputs":1,"output_only_on_state_change":false,"for":"0","forType":"num","forUnits":"minutes","ignorePrevStateNull":false,"ignorePrevStateUnknown":false,"ignorePrevStateUnavailable":false,"ignoreCurrentStateUnknown":false,"ignoreCurrentStateUnavailable":false,"outputProperties":[{"property":"midtempday","propertyType":"global","value":"","valueType":"entityState"}],"x":370,"y":120,"wires":[["3389c9c8.74a64e"]]},{"id":"f2c76250acabe2e0","type":"server-state-changed","z":"b4f7b0b8.7bb9f8","name":"Lower Temp Day","server":"86616542.19f378","version":4,"exposeToHomeAssistant":false,"haConfig":[{"property":"name","value":""},{"property":"icon","value":""}],"entityidfilter":"input_number.temperatur_schildkroten_tagsuber_minimum","entityidfiltertype":"exact","outputinitially":false,"state_type":"str","haltifstate":"","halt_if_type":"str","halt_if_compare":"is","outputs":1,"output_only_on_state_change":false,"for":"0","forType":"num","forUnits":"minutes","ignorePrevStateNull":false,"ignorePrevStateUnknown":false,"ignorePrevStateUnavailable":false,"ignoreCurrentStateUnknown":false,"ignoreCurrentStateUnavailable":false,"outputProperties":[{"property":"lowertempday","propertyType":"global","value":"","valueType":"entityState"}],"x":380,"y":180,"wires":[["3389c9c8.74a64e"]]},{"id":"5a73e9aa9bcddf1f","type":"server-state-changed","z":"b4f7b0b8.7bb9f8","name":"Upper Temp Night","server":"86616542.19f378","version":4,"exposeToHomeAssistant":false,"haConfig":[{"property":"name","value":""},{"property":"icon","value":""}],"entityidfilter":"input_number.temperatur_schildkroten_nachts_maximum","entityidfiltertype":"exact","outputinitially":false,"state_type":"str","haltifstate":"","halt_if_type":"str","halt_if_compare":"is","outputs":1,"output_only_on_state_change":false,"for":"0","forType":"num","forUnits":"minutes","ignorePrevStateNull":false,"ignorePrevStateUnknown":false,"ignorePrevStateUnavailable":false,"ignoreCurrentStateUnknown":false,"ignoreCurrentStateUnavailable":false,"outputProperties":[{"property":"uppertempnight","propertyType":"global","value":"","valueType":"entityState"}],"x":390,"y":420,"wires":[["79c77414.9b3e0c"]]},{"id":"d8b644ae9e1bb2cc","type":"server-state-changed","z":"b4f7b0b8.7bb9f8","name":"Lower Temp Night","server":"86616542.19f378","version":4,"exposeToHomeAssistant":false,"haConfig":[{"property":"name","value":""},{"property":"icon","value":""}],"entityidfilter":"input_number.temperatur_schildkroten_nachts_minimum","entityidfiltertype":"exact","outputinitially":false,"state_type":"str","haltifstate":"","halt_if_type":"str","halt_if_compare":"is","outputs":1,"output_only_on_state_change":false,"for":"0","forType":"num","forUnits":"minutes","ignorePrevStateNull":false,"ignorePrevStateUnknown":false,"ignorePrevStateUnavailable":false,"ignoreCurrentStateUnknown":false,"ignoreCurrentStateUnavailable":false,"outputProperties":[{"property":"lowertempnight","propertyType":"global","value":"","valueType":"entityState"}],"x":390,"y":360,"wires":[["79c77414.9b3e0c"]]},{"id":"86616542.19f378","type":"server","name":"Home Assistant","version":2,"addon":true,"rejectUnauthorizedCerts":true,"ha_boolean":"y|yes|true|on|home|open","connectionDelay":true,"cacheJson":true,"heartbeat":false,"heartbeatInterval":"30"}]
