How to check WHEN input_select was given value
Question is simple, yet solution might not:
I’m looking to check when given input_select (let’s call it: “input_select.X”) was a certain value (let’s call this value “ASDF”), becuase I would like to display this as an information of when certain event happened. I would love to use that data also in some automations … but “baby steps”.
Could probably be done with an SQL sensor.
I don’t know enough about SQL or the DB schema to tell you what the query would be though.
You just create an automation that triggers on state change.
For example I have an input_select to choose between three states on my AC (Off, Cool or Heat) and triggers for each:
triggers:
  - trigger: state
    entity_id:
      - input_select.accontrol
      - Cool
      - Heat
    to: "Off"
  - trigger: state
    entity_id:
    to:
      - Cool
      - Heat
  - trigger: state
    entity_id:
      - Cool
      - Heat
    to:
      - Cool
      - Heat
conditions: []
actions:
  - choose:
      - conditions:
          - condition: trigger
            id:
              - Turn Off
            alias: AC Turned Off
        sequence:
          - alias: Send Power command to AC
            action: remote.send_command
            metadata: {}
              device: aircon_lg
              command: power
              entity_id: remote.deskremote
      >>> MORE CONDITIONS <<<
I wanted to handle the different conditions differently (Turning on, Turning off and changing between Heat and Cool).
But if your requirements are simpler you could have a much simpler trigger statement, something like this:
triggers:
  - trigger: state
    entity_id:
conditions: []
actions:
Yes, I’ve seen your solution in other threads. I though that it was crude and did not allow to automatically go through the history.
HOWEVER,
I think it’s the only simple solution without going through db kung-fu, so I’ll mark your answer as an solution.
You are going to need to provide some details about what you want to do.
Behind the scenes Home Assistant is just a glorified event broker - events happen and trigger automations which then trigger other events.
Events can be triggered by external things happening (an IR sensor detects movement) and events can trigger real world changes (turns on a light).
All events are recorded so you can go back and look at what happened historically.
Your example does not do this though:
You could do it with triggered template sensors. e.g.
# configuration.yaml
template:
  - trigger:
      - trigger: state
        entity_id: input_select.x
        to: "ASDF"
        not_from:
          - unknown
          - unavailable
      - name: ASDF Last Selected
        state: "{{ now() }}"
  - trigger:
      - trigger: state
        to: "QWERTY"
        not_from:
          - unknown
          - unavailable
      - name: QWERTY Last Selected
If you have many select options it could be simplified to one triggered sensor with a load of attributes, one for each option.
thanks for that.
