How to combine multiple sensors and act as a switch?
My goal is to combine both a temperature and a window sensor. And of both meet certain conditions, then disable a specific device. Otherwise enable it.
I tried creating a templates switch without success.
For the start, I just used the window condition in the value_template (but temperature would follow):
But even this single condition never triggers the device on/off:
switch:
    switches:
      my_combined_switch:
        value_template: "{{ is_state('binary_sensor.openclose_kitchen', 'off') }}"
        #value_template: "{{ is_state('binary_sensor.openclose_kitchen', 'off') and (states('sensor.temperature_sensor')|float > 20) }}"
        turn_on:
          service: switch.turn_on
            entity_id: switch.kitchendevice
        turn_off:
          service: switch.turn_off
If you want things to act you need to write automations. Your template switch uses the state of the template to report the state of the switch - it doesn’t control it with that template.
You don’t want to create a switch. You want to create a binary sensor that you can then use in an automation to control the switch.
here is the binary sensor based on your (partial) code above:
binary_sensor:
    sensors:
      my_combined_sensor:
Can I somehow achieve this in a single automation? If the binary_sensor is on, then turn my kitchendevice on. If the sensor changes to off, then turn my kitchendevice off.
Or would I have to write two automations?
You can do that in one, with either templates or a choose section.
It doesn’t gain you anything though, so I always recommend starting with two, and then learning how to merge them if you really want to.
But it’s not possible to not create the binary_sensor, but directly add this condition to an automation? Because an automation can only act on a single trigger, and here I want to combine multiple conditions?
I somehow feels wrong to create an extra binary_sensor that is only used in one (or 2) automations.
Sure you can, you can add both as triggers, and as conditions.
automation:
- trigger:
  - platform: state
    entity_id: binary_sensor.openclose_kitchen
    to: 'off'
  - platform: numeric_state:
    entity_id: sensor.temperature_sensor
    above: 20
- condition:
  - condition: state
    state: 'off'
  - condition: numeric_state
    above: 20
- action:
  - service: switch.turn_on
As per the automation docs:
  • when either trigger becomes true
  • and both conditions are true
  • run the action
