I tested to calculate the value of the current for our Quasar wallbox in the developer tools environment and it worked fine:
{{ (states('sensor.wallbox_portal_max_charging_current')|float) + 1 }}
However, if I use it in my yaml automation, I get an error message.
This is the yaml code:
- device id: <id>
domain: number
entity_id: <id>
type: set_value
value: >
This is the error message, when I try to save the code:
Message malformed: expected float at 'value'
What did I wrong?
