Team,
I need help, I have a temp sensor that I use to switch off a fan when temperature is “low”.
The issue is that I cannot simply define a number for Low as it will not work during the year.
In the room I have a thermostat I can read.
How can I switch off the fan when the temperature from the sensor is between thermostat temp - 5 and thermostat temp + 5?
I was not able to define a rule in the automations
That is the legacy Template Binary Sensor syntax which has been scheduled for full deprecation in 4 months, use the current syntax as shown in the Template integration docs.
