francisp
(Francis)
1
I have tried
logger:
default: error
logs:
homeassistant.components.light.rflink: debug
homeassistant.components.sensor.rflink: debug
homeassistant.components.rflink.light: debug
homeassistant.components.rflink.switch: debug
rflink: debug
rflink.light: debug
Still nothing useful in the logs
tom_l
2
Assuming rflink is an integration (core or 3rd party) this should be it:
logger:
default: error
logs:
homeassistant.components.rflink: debug
francisp
(Francis)
3
it is a core, but not maintained, integration
tom_l
4
Then if it supports debug logging the config I posted should work.
javicalle
(javicalle)
5
That’s my usual config for debug:
# Logger
logger:
logs:
# rflink: debug
# homeassistant.components.rflink: debug
# custom_components.rflink: debug
# custom_components.rflink.cover: debug
BTW rflink: debug is just for the library, not the integration.
IIRC components (light, cover,…) don’t have many logs messages.
francisp
(Francis)
6
I see in the log the data is received
2025-10-09 17:27:17.695 DEBUG (MainThread) [rflink.protocol] received data: 20;19;NewKaku;ID=03a0b800;SWITCH
2025-10-09 17:27:17.698 DEBUG (MainThread) [rflink.protocol] received data: =2;CMD=ON;
2025-10-09 17:27:17.699 DEBUG (MainThread) [rflink.protocol] got packet: 20;19;NewKaku;ID=03a0b800;SWITCH=2;CMD=ON;
2025-10-09 17:27:17.699 DEBUG (MainThread) [rflink.protocol] decoded packet: {'node': 'gateway', 'protocol': 'newkaku', 'id': '03a0b800', 'switch': '2', 'command': 'on'}
2025-10-09 17:27:17.700 DEBUG (MainThread) [rflink.protocol] got event: {'id': 'newkaku_03a0b800_2', 'command': 'on'}
2025-10-09 17:27:20.032 DEBUG (MainThread) [rflink.protocol] received data: 20;1A;NewKaku;ID=03a0b800;SWITCH
2025-10-09 17:27:20.036 DEBUG (MainThread) [rflink.protocol] received data: =3;CMD=ON;
2025-10-09 17:27:20.037 DEBUG (MainThread) [rflink.protocol] got packet: 20;1A;NewKaku;ID=03a0b800;SWITCH=3;CMD=ON;
2025-10-09 17:27:20.037 DEBUG (MainThread) [rflink.protocol] decoded packet: {'node': 'gateway', 'protocol': 'newkaku', 'id': '03a0b800', 'switch': '3', 'command': 'on'}
2025-10-09 17:27:20.038 DEBUG (MainThread) [rflink.protocol] got event: {'id': 'newkaku_03a0b800_3', 'command': 'on'}
2025-10-09 17:27:21.585 DEBUG (MainThread) [rflink.protocol] received data: 20;1B;NewKaku;ID=03a0b800;SWITCH
2025-10-09 17:27:21.589 DEBUG (MainThread) [rflink.protocol] received data: =2;CMD=ON;
2025-10-09 17:27:21.590 DEBUG (MainThread) [rflink.protocol] got packet: 20;1B;NewKaku;ID=03a0b800;SWITCH=2;CMD=ON;
2025-10-09 17:27:21.590 DEBUG (MainThread) [rflink.protocol] decoded packet: {'node': 'gateway', 'protocol': 'newkaku', 'id': '03a0b800', 'switch': '2', 'command': 'on'}
2025-10-09 17:27:21.590 DEBUG (MainThread) [rflink.protocol] got event: {'id': 'newkaku_03a0b800_2', 'command': 'on'}
2025-10-09 17:27:23.210 DEBUG (MainThread) [rflink.protocol] received data: 20;1C;NewKaku;ID=03a0b800;SWITCH
2025-10-09 17:27:23.214 DEBUG (MainThread) [rflink.protocol] received data: =3;CMD=ON;
2025-10-09 17:27:23.215 DEBUG (MainThread) [rflink.protocol] got packet: 20;1C;NewKaku;ID=03a0b800;SWITCH=3;CMD=ON;
2025-10-09 17:27:23.215 DEBUG (MainThread) [rflink.protocol] decoded packet: {'node': 'gateway', 'protocol': 'newkaku', 'id': '03a0b800', 'switch': '3', 'command': 'on'}
2025-10-09 17:27:23.216 DEBUG (MainThread) [rflink.protocol] got event: {'id': 'newkaku_03a0b800_3', 'command': 'on'}
but the entity is no longer created
- platform: rflink
device_defaults:
fire_event: true
signal_repetitions: 3
devices:
newkaku_03a0b800_3:
newkaku_03a0b800_2:
don’t know since when, but the logs are not very useful. They show what is received, but nothing about the entities.
