How to configure Z-wave parameters using MQTT?
Can someone please explain how to find the ValueID of an OpenZWave node, in MQTT Explorer?
I’m trying to change the reporting intervals (parameters 111, 112 & 113) for the Aeotec Smart Switch 6 (ZW096), but the OpenZwave Web UI only allows a value of ‘0’ (zero) - which disables reporting. So I want to try the mqtt.publish service or MQTT Explorer directly.
Here is node 22 in MQTT explorer; where do I look please? (Tried Search but it finds nothing!)
And as an alternative, where is the ‘OpenZWave/1/command/’ to set parameters in MQTT Explorer directly, as suggested in this GitHub post: https://github.com/home-assistant/addons/issues/1600#issuecomment-713747441
My OpenZWave in MQTT Explorer isn’t showing it?
Thanks.
As far as I remember it’s inside the commandclass 112.
The command topic is not shown until you publish something there.
See my comment on a github issue here, where I set a paramter for an aeotec multisensor.
Thanks @Burningstone, that got me on the right path to solving it.
