I have HA setup in a docker container on my home server with a Zigbee USB dongle. My LED strip in question is a temperature adjustable white COB strip connected to a Tuya WiFi LED driver. I have also connected a Zigbee button to HA through the Zigbee Home Automation integration.
I was able to create automations to toggle the light strip on and off when the button is pressed. I can also change the brightness by rotating via automation (although it’s really choppy and would love better suggestions!). I want to be able to press and rotate at the same time to adjust the temperature of the lights. How can I do this? Do I need a dedicated Zigbee hub to connect to Smart Life and configure there? Do I need a Zigbee driver instead of a WiFi one? Or is there something I can configure in HA that I’m not aware of?
Thanks in advanced!!
