Hi everyone,
I’m a little new in the relays topic. I have an electric lock that requires an external power supply, and I want to control it using the Aqara T2 relay in dry contact mode.
The Aqara T2 has the following terminals:
L, N, L1, L2, Lin, Lout
S1, S2, COM
My electric lock has two wires and needs its own external 12v power supply. I understand that in dry contact mode, the relay should work as a simple switch without supplying power.
My Questions:
Which terminals on the T2 should I use to properly switch the lock circuit?
How should I wire the external power supply to the lock while ensuring the relay can control it?
To be able to integrate my existing videodoorbell (with a push button), how should I wire it in the relay?
Any wiring diagrams or detailed explanations would be greatly appreciated. Thanks in advance!
