How to connect apollo Air 1 to home assistant green
con someone explain to me insimple ways how to connect Apollo Air 1 to home assistant green?
I am a novice at that and cannot figure it out.
Thank you
Pascal
If it is connected to the same LAN then it should be autodetected. When you go to the Settings / Integrations page there should be a tile asking you to add it (through the ESPHome integration). It is explined in the docs of the device.
