How to connect to deconz REST API when it's a Hassio add-on?
I am trying to use the REST API with deconz in order to adjust my Hue sensors.
I have tried to look up the core.config_entries and found deconz. In there I found my API key, but also the host, which is “172.30.33.0”, but my normal Hassio instance is “192.168.86.26” - which host adress is the correct?
Further more I can see in the config_entries that the port should be “40850”.
But if I try the following in order to retrieve something: “http://172.30.33.0:40850/api/56495799AE/sensors” I just get an error stating “Request failed”.
I also tried the above with the normal Hassio host adress, but same error.
How do I connect via REST?
Hi Morten,
Did you ever get your problem solved?
I’m in the exact same position trying to use the deCONZ rest-api to set the sensitivity on my hue sensors which is hooked up on my deCONZ integration in Home Assistant (using a conbee II device). I can’t seem to figure out how to get connection outside of HA.
