How to connect to VirtualBox Home Assistant instance from other computers on home network?
I have HA 2021.5.5 running in a VirtualBox on a headless Mac Mini. Everything is running fine on that Mac at http://homeassistant.local:8123.
How do I connect to that machine and the HA instance from other computers on the home network?
The IP for the Mac Mini is 192.168.1.240, do I need to edit hosts file to point to the VM? How do I find the IP for that? Is that the value in the Host Network Manager?
What I used VirtualBox on windows I made sure the VM had a bridged network adapter to get an ip address from the home network. The default is to NAT through a network local to the VirtualBox host.
Adapter 1 for the VM is set to Bridged AdapterIn my VB under “Host Network Manager” there is an entry called “vboxnet0” with an IPv4 address/mask of 192.168.10.4/24 and under DHCP adapter a server address of 192.168.56.100. The Mac Mini is on 192.168.1.240, i can SSH into that machine using that IP.
What are these other two IPs? A ping to ether of them fails.
