How to correctly bind 2 devices in ZHA?
Hi, I am trying to Bind together two TRADFRI bulb E14 WS opal 600lm with a Remote Control N2 (IKEA devices) via ZHA integration (with SONOFF Zigbee 3.0 USB Dongle Plus as Gateway). I know for a fact that this can be done, as I managed to do this once some days ago. But then I had to remove the network and reintegrate all of the devices and now I cannot bind them together.
I tried both Group Binding as well as individual binding with each lightbulb and nothing happens. It just shows the spinning icon for ages.
Here you can see the logs of ZHA and zigpy when trying to bind, If it helps to understand the problem.
2022-10-25 13:37:50.348 DEBUG (MainThread) [zigpy.zdo] [0x0766:zdo] processing cluster: 6 Bind_req --> [d0:cf:5e:ff:fe:44:53:03]
2022-10-25 13:37:50.349 DEBUG (MainThread) [zigpy.zdo] [0x0766:zdo] processing cluster: 8 Bind_req --> [d0:cf:5e:ff:fe:44:53:03]
2022-10-25 13:37:50.351 DEBUG (MainThread) [zigpy.device] [0x0766] Extending timeout for 0x64 request
2022-10-25 13:37:50.353 DEBUG (MainThread) [zigpy.device] [0x0766] Extending timeout for 0x65 request
2022-10-25 13:37:53.420 DEBUG (MainThread) [zigpy.application] Received a packet: ZigbeePacket(src=AddrModeAddress(addr_mode=<AddrMode.NWK: 2>, address=0xF8D8), src_ep=1, dst=AddrModeAddress(addr_mode=<AddrMode.NWK: 2>, address=0x0000), dst_ep=1, source_route=None, extended_timeout=False, tsn=0, profile_id=260, cluster_id=61184, data=Serialized[b'\t\xb9\x02\x00\x00\x12\x02\x00\x04\x00\x00\x01\x1f'], tx_options=<TransmitOptions.NONE: 0>, radius=29, non_member_radius=0, lqi=57, rssi=None)
2022-10-25 13:37:53.421 DEBUG (MainThread) [zigpy.zcl] [0xF8D8:1:0xef00] Received ZCL frame: b'\t\xb9\x02\x00\x00\x12\x02\x00\x04\x00\x00\x01\x1f'
2022-10-25 13:37:53.422 DEBUG (MainThread) [zigpy.zcl] [0xF8D8:1:0xef00] Decoded ZCL frame header: ZCLHeader(frame_control=FrameControl(frame_type=<FrameType.CLUSTER_COMMAND: 1>, is_manufacturer_specific=0, direction=<Direction.Client_to_Server: 1>, disable_default_response=0, reserved=0, *is_cluster=True, *is_general=False, *is_reply=True), tsn=185, command_id=2, *direction=<Direction.Client_to_Server: 1>, *is_reply=True)
2022-10-25 13:37:53.423 DEBUG (MainThread) [zigpy.zcl] [0xF8D8:1:0xef00] Decoded ZCL frame: TuyaCO2ManufCluster:set_data_response(data=TuyaCommand(status=0, tsn=0, datapoints=[TuyaDatapointData(dp=18, data=TuyaData(dp_type=<TuyaDPType.VALUE: 2>, function=0, raw=b'\x1f\x01\x00\x00', *payload=287))]))
2022-10-25 13:37:53.424 DEBUG (MainThread) [zigpy.zcl] [0xF8D8:1:0xef00] Received command 0x02 (TSN 185): set_data_response(data=TuyaCommand(status=0, tsn=0, datapoints=[TuyaDatapointData(dp=18, data=TuyaData(dp_type=<TuyaDPType.VALUE: 2>, function=0, raw=b'\x1f\x01\x00\x00', *payload=287))]))
2022-10-25 13:37:53.425 DEBUG (MainThread) [homeassistant.core] Bus:Handling <Event state_changed[L]: entity_id=sensor.air_quality_monitor_temperature, old_state=<state sensor.air_quality_monitor_temperature=28.8; state_class=measurement, unit_of_measurement=°C, device_class=temperature, friendly_name=Air Quality Monitor Temperature @ 2022-10-25T13:37:48.399700+02:00>, new_state=<state sensor.air_quality_monitor_temperature=28.7; state_class=measurement, unit_of_measurement=°C, device_class=temperature, friendly_name=Air Quality Monitor Temperature @ 2022-10-25T13:37:53.425539+02:00>>
2022-10-25 13:37:53.432 DEBUG (MainThread) [zigpy.zcl] [0xF8D8:1:0xef00] Sending reply header: ZCLHeader(frame_control=FrameControl(frame_type=<FrameType.GLOBAL_COMMAND: 0>, is_manufacturer_specific=False, direction=<Direction.Client_to_Server: 1>, disable_default_response=1, reserved=0, *is_cluster=False, *is_general=True, *is_reply=True), tsn=185, command_id=<GeneralCommand.Default_Response: 11>, *direction=<Direction.Client_to_Server: 1>, *is_reply=True)
2022-10-25 13:37:53.432 DEBUG (MainThread) [zigpy.zcl] [0xF8D8:1:0xef00] Sending reply: Default_Response(command_id=2, status=<Status.SUCCESS: 0>)
2022-10-25 13:37:53.487 DEBUG (MainThread) [zigpy.application] Received a packet: ZigbeePacket(src=AddrModeAddress(addr_mode=<AddrMode.NWK: 2>, address=0xF8D8), src_ep=1, dst=AddrModeAddress(addr_mode=<AddrMode.NWK: 2>, address=0x0000), dst_ep=1, source_route=None, extended_timeout=False, tsn=0, profile_id=260, cluster_id=61184, data=Serialized[b'\t\xba\x02\x00\x00\x13\x02\x00\x04\x00\x00\x01\xa4'], tx_options=<TransmitOptions.NONE: 0>, radius=29, non_member_radius=0, lqi=57, rssi=None)
2022-10-25 13:37:53.489 DEBUG (MainThread) [zigpy.zcl] [0xF8D8:1:0xef00] Received ZCL frame: b'\t\xba\x02\x00\x00\x13\x02\x00\x04\x00\x00\x01\xa4'
2022-10-25 13:37:53.490 DEBUG (MainThread) [zigpy.zcl] [0xF8D8:1:0xef00] Decoded ZCL frame header: ZCLHeader(frame_control=FrameControl(frame_type=<FrameType.CLUSTER_COMMAND: 1>, is_manufacturer_specific=0, direction=<Direction.Client_to_Server: 1>, disable_default_response=0, reserved=0, *is_cluster=True, *is_general=False, *is_reply=True), tsn=186, command_id=2, *direction=<Direction.Client_to_Server: 1>, *is_reply=True)
2022-10-25 13:37:53.493 DEBUG (MainThread) [zigpy.zcl] [0xF8D8:1:0xef00] Decoded ZCL frame: TuyaCO2ManufCluster:set_data_response(data=TuyaCommand(status=0, tsn=0, datapoints=[TuyaDatapointData(dp=19, data=TuyaData(dp_type=<TuyaDPType.VALUE: 2>, function=0, raw=b'\xa4\x01\x00\x00', *payload=420))]))
2022-10-25 13:37:53.497 DEBUG (MainThread) [zigpy.zcl] [0xF8D8:1:0xef00] Received command 0x02 (TSN 186): set_data_response(data=TuyaCommand(status=0, tsn=0, datapoints=[TuyaDatapointData(dp=19, data=TuyaData(dp_type=<TuyaDPType.VALUE: 2>, function=0, raw=b'\xa4\x01\x00\x00', *payload=420))]))
2022-10-25 13:37:53.498 DEBUG (MainThread) [homeassistant.core] Bus:Handling <Event state_changed[L]: entity_id=sensor.air_quality_monitor_humidity, old_state=<state sensor.air_quality_monitor_humidity=41.4; state_class=measurement, unit_of_measurement=%, device_class=humidity, friendly_name=Air Quality Monitor Humidity @ 2022-10-25T13:37:48.479693+02:00>, new_state=<state sensor.air_quality_monitor_humidity=42.0; state_class=measurement, unit_of_measurement=%, device_class=humidity, friendly_name=Air Quality Monitor Humidity @ 2022-10-25T13:37:53.498649+02:00>>
2022-10-25 13:37:53.506 DEBUG (MainThread) [zigpy.zcl] [0xF8D8:1:0xef00] Sending reply header: ZCLHeader(frame_control=FrameControl(frame_type=<FrameType.GLOBAL_COMMAND: 0>, is_manufacturer_specific=False, direction=<Direction.Client_to_Server: 1>, disable_default_response=1, reserved=0, *is_cluster=False, *is_general=True, *is_reply=True), tsn=186, command_id=<GeneralCommand.Default_Response: 11>, *direction=<Direction.Client_to_Server: 1>, *is_reply=True)
2022-10-25 13:37:53.507 DEBUG (MainThread) [zigpy.zcl] [0xF8D8:1:0xef00] Sending reply: Default_Response(command_id=2, status=<Status.SUCCESS: 0>)
2022-10-25 13:37:54.668 DEBUG (MainThread) [zigpy.application] Received a packet: ZigbeePacket(src=AddrModeAddress(addr_mode=<AddrMode.NWK: 2>, address=0x5E74), src_ep=1, dst=AddrModeAddress(addr_mode=<AddrMode.NWK: 2>, address=0x0000), dst_ep=1, source_route=None, extended_timeout=False, tsn=0, profile_id=260, cluster_id=6, data=Serialized[b'\x18\x85\n\x00\x00\x10\x01'], tx_options=<TransmitOptions.NONE: 0>, radius=29, non_member_radius=0, lqi=69, rssi=None)
2022-10-25 13:37:54.669 DEBUG (MainThread) [zigpy.zcl] [0x5E74:1:0x0006] Received ZCL frame: b'\x18\x85\n\x00\x00\x10\x01'
2022-10-25 13:37:54.671 DEBUG (MainThread) [zigpy.zcl] [0x5E74:1:0x0006] Decoded ZCL frame header: ZCLHeader(frame_control=FrameControl(frame_type=<FrameType.GLOBAL_COMMAND: 0>, is_manufacturer_specific=0, direction=<Direction.Client_to_Server: 1>, disable_default_response=1, reserved=0, *is_cluster=False, *is_general=True, *is_reply=True), tsn=133, command_id=10, *direction=<Direction.Client_to_Server: 1>, *is_reply=True)
2022-10-25 13:37:54.673 DEBUG (MainThread) [zigpy.zcl] [0x5E74:1:0x0006] Decoded ZCL frame: TuyaZBOnOffAttributeCluster:Report_Attributes(attribute_reports=[Attribute(attrid=0x0000, value=TypeValue(type=Bool, value=<Bool.true: 1>))])
2022-10-25 13:37:54.676 DEBUG (MainThread) [zigpy.zcl] [0x5E74:1:0x0006] Received command 0x0A (TSN 133): Report_Attributes(attribute_reports=[Attribute(attrid=0x0000, value=TypeValue(type=Bool, value=<Bool.true: 1>))])
2022-10-25 13:37:54.677 DEBUG (MainThread) [zigpy.zcl] [0x5E74:1:0x0006] Attribute report received: on_off=<Bool.true: 1>
2022-10-25 13:37:54.682 DEBUG (MainThread) [zigpy.application] Received a packet: ZigbeePacket(src=AddrModeAddress(addr_mode=<AddrMode.NWK: 2>, address=0xF8D8), src_ep=1, dst=AddrModeAddress(addr_mode=<AddrMode.NWK: 2>, address=0x0000), dst_ep=1, source_route=None, extended_timeout=False, tsn=0, profile_id=260, cluster_id=61184, data=Serialized[b'\t\xbb\x02\x00\x02\x14\x02\x00\x04\x00\x00\x00\x05'], tx_options=<TransmitOptions.NONE: 0>, radius=29, non_member_radius=0, lqi=57, rssi=None)
2022-10-25 13:37:54.682 DEBUG (MainThread) [zigpy.zcl] [0xF8D8:1:0xef00] Received ZCL frame: b'\t\xbb\x02\x00\x02\x14\x02\x00\x04\x00\x00\x00\x05'
2022-10-25 13:37:54.683 DEBUG (MainThread) [zigpy.zcl] [0xF8D8:1:0xef00] Decoded ZCL frame header: ZCLHeader(frame_control=FrameControl(frame_type=<FrameType.CLUSTER_COMMAND: 1>, is_manufacturer_specific=0, direction=<Direction.Client_to_Server: 1>, disable_default_response=0, reserved=0, *is_cluster=True, *is_general=False, *is_reply=True), tsn=187, command_id=2, *direction=<Direction.Client_to_Server: 1>, *is_reply=True)
2022-10-25 13:37:54.684 DEBUG (MainThread) [zigpy.zcl] [0xF8D8:1:0xef00] Decoded ZCL frame: TuyaCO2ManufCluster:set_data_response(data=TuyaCommand(status=0, tsn=2, datapoints=[TuyaDatapointData(dp=20, data=TuyaData(dp_type=<TuyaDPType.VALUE: 2>, function=0, raw=b'\x05\x00\x00\x00', *payload=5))]))
2022-10-25 13:37:54.685 DEBUG (MainThread) [zigpy.zcl] [0xF8D8:1:0xef00] Received command 0x02 (TSN 187): set_data_response(data=TuyaCommand(status=0, tsn=2, datapoints=[TuyaDatapointData(dp=20, data=TuyaData(dp_type=<TuyaDPType.VALUE: 2>, function=0, raw=b'\x05\x00\x00\x00', *payload=5))]))
2022-10-25 13:37:54.686 DEBUG (MainThread) [zigpy.zcl] [0xF8D8:1:0xef00] No datapoint handler for TuyaDatapointData(dp=20, data=TuyaData(dp_type=<TuyaDPType.VALUE: 2>, function=0, raw=b'\x05\x00\x00\x00', *payload=5))
2022-10-25 13:37:54.688 DEBUG (MainThread) [zigpy.zcl] [0xF8D8:1:0xef00] Sending reply header: ZCLHeader(frame_control=FrameControl(frame_type=<FrameType.GLOBAL_COMMAND: 0>, is_manufacturer_specific=False, direction=<Direction.Client_to_Server: 1>, disable_default_response=1, reserved=0, *is_cluster=False, *is_general=True, *is_reply=True), tsn=187, command_id=<GeneralCommand.Default_Response: 11>, *direction=<Direction.Client_to_Server: 1>, *is_reply=True)
2022-10-25 13:37:54.689 DEBUG (MainThread) [zigpy.zcl] [0xF8D8:1:0xef00] Sending reply: Default_Response(command_id=2, status=<Status.UNSUPPORTED_ATTRIBUTE: 134>)
2022-10-25 13:37:54.738 DEBUG (MainThread) [zigpy.application] Received a packet: ZigbeePacket(src=AddrModeAddress(addr_mode=<AddrMode.NWK: 2>, address=0xF8D8), src_ep=1, dst=AddrModeAddress(addr_mode=<AddrMode.NWK: 2>, address=0x0000), dst_ep=1, source_route=None, extended_timeout=False, tsn=0, profile_id=260, cluster_id=61184, data=Serialized[b'\t\xbc\x02\x00\x02\x15\x02\x00\x04\x00\x00\x00\r'], tx_options=<TransmitOptions.NONE: 0>, radius=29, non_member_radius=0, lqi=60, rssi=None)
2022-10-25 13:37:54.739 DEBUG (MainThread) [zigpy.zcl] [0xF8D8:1:0xef00] Received ZCL frame: b'\t\xbc\x02\x00\x02\x15\x02\x00\x04\x00\x00\x00\r'
2022-10-25 13:37:54.741 DEBUG (MainThread) [zigpy.zcl] [0xF8D8:1:0xef00] Decoded ZCL frame header: ZCLHeader(frame_control=FrameControl(frame_type=<FrameType.CLUSTER_COMMAND: 1>, is_manufacturer_specific=0, direction=<Direction.Client_to_Server: 1>, disable_default_response=0, reserved=0, *is_cluster=True, *is_general=False, *is_reply=True), tsn=188, command_id=2, *direction=<Direction.Client_to_Server: 1>, *is_reply=True)
2022-10-25 13:37:54.744 DEBUG (MainThread) [zigpy.zcl] [0xF8D8:1:0xef00] Decoded ZCL frame: TuyaCO2ManufCluster:set_data_response(data=TuyaCommand(status=0, tsn=2, datapoints=[TuyaDatapointData(dp=21, data=TuyaData(dp_type=<TuyaDPType.VALUE: 2>, function=0, raw=b'\r\x00\x00\x00', *payload=13))]))
2022-10-25 13:37:54.746 DEBUG (MainThread) [zigpy.zcl] [0xF8D8:1:0xef00] Received command 0x02 (TSN 188): set_data_response(data=TuyaCommand(status=0, tsn=2, datapoints=[TuyaDatapointData(dp=21, data=TuyaData(dp_type=<TuyaDPType.VALUE: 2>, function=0, raw=b'\r\x00\x00\x00', *payload=13))]))
2022-10-25 13:37:54.747 DEBUG (MainThread) [homeassistant.core] Bus:Handling <Event state_changed[L]: entity_id=sensor.air_quality_monitor_voclevel, old_state=<state sensor.air_quality_monitor_voclevel=19; state_class=measurement, unit_of_measurement=µg/m³, device_class=volatile_organic_compounds, friendly_name=Air Quality Monitor Voclevel @ 2022-10-25T13:37:47.696664+02:00>, new_state=<state sensor.air_quality_monitor_voclevel=13; state_class=measurement, unit_of_measurement=µg/m³, device_class=volatile_organic_compounds, friendly_name=Air Quality Monitor Voclevel @ 2022-10-25T13:37:54.747678+02:00>>
2022-10-25 13:37:54.753 DEBUG (MainThread) [zigpy.zcl] [0xF8D8:1:0xef00] Sending reply header: ZCLHeader(frame_control=FrameControl(frame_type=<FrameType.GLOBAL_COMMAND: 0>, is_manufacturer_specific=False, direction=<Direction.Client_to_Server: 1>, disable_default_response=1, reserved=0, *is_cluster=False, *is_general=True, *is_reply=True), tsn=188, command_id=<GeneralCommand.Default_Response: 11>, *direction=<Direction.Client_to_Server: 1>, *is_reply=True)
2022-10-25 13:37:54.754 DEBUG (MainThread) [zigpy.zcl] [0xF8D8:1:0xef00] Sending reply: Default_Response(command_id=2, status=<Status.SUCCESS: 0>)
2022-10-25 13:37:54.820 DEBUG (MainThread) [zigpy.application] Received a packet: ZigbeePacket(src=AddrModeAddress(addr_mode=<AddrMode.NWK: 2>, address=0xF8D8), src_ep=1, dst=AddrModeAddress(addr_mode=<AddrMode.NWK: 2>, address=0x0000), dst_ep=1, source_route=None, extended_timeout=False, tsn=0, profile_id=260, cluster_id=61184, data=Serialized[b'\t\xbd\x02\x00\x02\x16\x02\x00\x04\x00\x00\x01i'], tx_options=<TransmitOptions.NONE: 0>, radius=29, non_member_radius=0, lqi=60, rssi=None)
2022-10-25 13:37:54.821 DEBUG (MainThread) [zigpy.zcl] [0xF8D8:1:0xef00] Received ZCL frame: b'\t\xbd\x02\x00\x02\x16\x02\x00\x04\x00\x00\x01i'
2022-10-25 13:37:54.823 DEBUG (MainThread) [zigpy.zcl] [0xF8D8:1:0xef00] Decoded ZCL frame header: ZCLHeader(frame_control=FrameControl(frame_type=<FrameType.CLUSTER_COMMAND: 1>, is_manufacturer_specific=0, direction=<Direction.Client_to_Server: 1>, disable_default_response=0, reserved=0, *is_cluster=True, *is_general=False, *is_reply=True), tsn=189, command_id=2, *direction=<Direction.Client_to_Server: 1>, *is_reply=True)
2022-10-25 13:37:54.826 DEBUG (MainThread) [zigpy.zcl] [0xF8D8:1:0xef00] Decoded ZCL frame: TuyaCO2ManufCluster:set_data_response(data=TuyaCommand(status=0, tsn=2, datapoints=[TuyaDatapointData(dp=22, data=TuyaData(dp_type=<TuyaDPType.VALUE: 2>, function=0, raw=b'i\x01\x00\x00', *payload=361))]))
2022-10-25 13:37:54.828 DEBUG (MainThread) [zigpy.zcl] [0xF8D8:1:0xef00] Received command 0x02 (TSN 189): set_data_response(data=TuyaCommand(status=0, tsn=2, datapoints=[TuyaDatapointData(dp=22, data=TuyaData(dp_type=<TuyaDPType.VALUE: 2>, function=0, raw=b'i\x01\x00\x00', *payload=361))]))
2022-10-25 13:37:54.832 DEBUG (MainThread) [zigpy.zcl] [0xF8D8:1:0xef00] Sending reply header: ZCLHeader(frame_control=FrameControl(frame_type=<FrameType.GLOBAL_COMMAND: 0>, is_manufacturer_specific=False, direction=<Direction.Client_to_Server: 1>, disable_default_response=1, reserved=0, *is_cluster=False, *is_general=True, *is_reply=True), tsn=189, command_id=<GeneralCommand.Default_Response: 11>, *direction=<Direction.Client_to_Server: 1>, *is_reply=True)
2022-10-25 13:37:54.833 DEBUG (MainThread) [zigpy.zcl] [0xF8D8:1:0xef00] Sending reply: Default_Response(command_id=2, status=<Status.SUCCESS: 0>)
2022-10-25 13:37:54.883 DEBUG (MainThread) [zigpy.application] Received a packet: ZigbeePacket(src=AddrModeAddress(addr_mode=<AddrMode.NWK: 2>, address=0xF8D8), src_ep=1, dst=AddrModeAddress(addr_mode=<AddrMode.NWK: 2>, address=0x0000), dst_ep=1, source_route=None, extended_timeout=False, tsn=0, profile_id=260, cluster_id=61184, data=Serialized[b'\t\xbe\x02\x00\x04\x02\x02\x00\x04\x00\x00\x00\x06'], tx_options=<TransmitOptions.NONE: 0>, radius=29, non_member_radius=0, lqi=60, rssi=None)
2022-10-25 13:37:54.884 DEBUG (MainThread) [zigpy.zcl] [0xF8D8:1:0xef00] Received ZCL frame: b'\t\xbe\x02\x00\x04\x02\x02\x00\x04\x00\x00\x00\x06'
2022-10-25 13:37:54.886 DEBUG (MainThread) [zigpy.zcl] [0xF8D8:1:0xef00] Decoded ZCL frame header: ZCLHeader(frame_control=FrameControl(frame_type=<FrameType.CLUSTER_COMMAND: 1>, is_manufacturer_specific=0, direction=<Direction.Client_to_Server: 1>, disable_default_response=0, reserved=0, *is_cluster=True, *is_general=False, *is_reply=True), tsn=190, command_id=2, *direction=<Direction.Client_to_Server: 1>, *is_reply=True)
2022-10-25 13:37:54.891 DEBUG (MainThread) [zigpy.zcl] [0xF8D8:1:0xef00] Decoded ZCL frame: TuyaCO2ManufCluster:set_data_response(data=TuyaCommand(status=0, tsn=4, datapoints=[TuyaDatapointData(dp=2, data=TuyaData(dp_type=<TuyaDPType.VALUE: 2>, function=0, raw=b'\x06\x00\x00\x00', *payload=6))]))
2022-10-25 13:37:54.892 DEBUG (MainThread) [zigpy.zcl] [0xF8D8:1:0xef00] Received command 0x02 (TSN 190): set_data_response(data=TuyaCommand(status=0, tsn=4, datapoints=[TuyaDatapointData(dp=2, data=TuyaData(dp_type=<TuyaDPType.VALUE: 2>, function=0, raw=b'\x06\x00\x00\x00', *payload=6))]))
2022-10-25 13:37:54.894 DEBUG (MainThread) [homeassistant.core] Bus:Handling <Event state_changed[L]: entity_id=sensor.air_quality_monitor_carbondioxideconcentration, old_state=<state sensor.air_quality_monitor_carbondioxideconcentration=43691; state_class=measurement, unit_of_measurement=ppm, device_class=carbon_dioxide, friendly_name=Air Quality Monitor Carbondioxideconcentration @ 2022-10-25T13:37:47.832999+02:00>, new_state=<state sensor.air_quality_monitor_carbondioxideconcentration=6; state_class=measurement, unit_of_measurement=ppm, device_class=carbon_dioxide, friendly_name=Air Quality Monitor Carbondioxideconcentration @ 2022-10-25T13:37:54.893999+02:00>>
2022-10-25 13:37:54.903 DEBUG (MainThread) [zigpy.zcl] [0xF8D8:1:0xef00] Sending reply header: ZCLHeader(frame_control=FrameControl(frame_type=<FrameType.GLOBAL_COMMAND: 0>, is_manufacturer_specific=False, direction=<Direction.Client_to_Server: 1>, disable_default_response=1, reserved=0, *is_cluster=False, *is_general=True, *is_reply=True), tsn=190, command_id=<GeneralCommand.Default_Response: 11>, *direction=<Direction.Client_to_Server: 1>, *is_reply=True)
2022-10-25 13:37:54.903 DEBUG (MainThread) [zigpy.zcl] [0xF8D8:1:0xef00] Sending reply: Default_Response(command_id=2, status=<Status.SUCCESS: 0>)
2022-10-25 13:37:56.929 DEBUG (MainThread) [homeassistant.components.zha.core.device] [0x4799](Remote Control N2): last_seen is 75306.50145483017 seconds ago and ping attempts have been exhausted, marking the device unavailable
2022-10-25 13:37:56.930 DEBUG (MainThread) [homeassistant.components.zha.core.device] [0x4799](Remote Control N2): Update device availability -  device available: False - new availability: False - changed: False
2022-10-25 13:38:00.539 DEBUG (MainThread) [homeassistant.components.zha.core.channels.base] [0xAF70:1:0x0702]: async_force_update
2022-10-25 13:38:00.539 DEBUG (MainThread) [homeassistant.components.zha.core.channels.base] [0xAF70:1:0x0702]: Reading attributes in chunks: ['current_summ_delivered', 'status']
2022-10-25 13:38:00.541 DEBUG (MainThread) [zigpy.zcl] [0xAF70:1:0x0702] Sending request header: ZCLHeader(frame_control=FrameControl(frame_type=<FrameType.GLOBAL_COMMAND: 0>, is_manufacturer_specific=False, direction=<Direction.Server_to_Client: 0>, disable_default_response=0, reserved=0, *is_cluster=False, *is_general=True, *is_reply=False), tsn=102, command_id=<GeneralCommand.Read_Attributes: 0>, *direction=<Direction.Server_to_Client: 0>, *is_reply=False)
2022-10-25 13:38:00.543 DEBUG (MainThread) [zigpy.zcl] [0xAF70:1:0x0702] Sending request: Read_Attributes(attribute_ids=[0, 512])
2022-10-25 13:38:00.550 DEBUG (MainThread) [homeassistant.components.zha.core.channels.base] [0xAA94:1:0x0702]: async_force_update
2022-10-25 13:38:00.550 DEBUG (MainThread) [homeassistant.components.zha.core.channels.base] [0xAA94:1:0x0702]: Reading attributes in chunks: ['current_summ_delivered', 'status']
2022-10-25 13:38:00.552 DEBUG (MainThread) [zigpy.zcl] [0xAA94:1:0x0702] Sending request header: ZCLHeader(frame_control=FrameControl(frame_type=<FrameType.GLOBAL_COMMAND: 0>, is_manufacturer_specific=False, direction=<Direction.Server_to_Client: 0>, disable_default_response=0, reserved=0, *is_cluster=False, *is_general=True, *is_reply=False), tsn=103, command_id=<GeneralCommand.Read_Attributes: 0>, *direction=<Direction.Server_to_Client: 0>, *is_reply=False)
2022-10-25 13:38:00.553 DEBUG (MainThread) [zigpy.zcl] [0xAA94:1:0x0702] Sending request: Read_Attributes(attribute_ids=[0, 512])
2022-10-25 13:38:00.554 DEBUG (MainThread) [homeassistant.components.zha.core.channels.base] [0xAF70:1:0x0b04]: async_update
2022-10-25 13:38:00.555 DEBUG (MainThread) [homeassistant.components.zha.core.channels.base] [0xAF70:1:0x0b04]: Reading attributes in chunks: ['active_power', 'rms_current', 'rms_voltage']
2022-10-25 13:38:00.556 DEBUG (MainThread) [zigpy.zcl] [0xAF70:1:0x0b04] Sending request header: ZCLHeader(frame_control=FrameControl(frame_type=<FrameType.GLOBAL_COMMAND: 0>, is_manufacturer_specific=False, direction=<Direction.Server_to_Client: 0>, disable_default_response=0, reserved=0, *is_cluster=False, *is_general=True, *is_reply=False), tsn=104, command_id=<GeneralCommand.Read_Attributes: 0>, *direction=<Direction.Server_to_Client: 0>, *is_reply=False)
2022-10-25 13:38:00.556 DEBUG (MainThread) [zigpy.zcl] [0xAF70:1:0x0b04] Sending request: Read_Attributes(attribute_ids=[1291, 1288, 1285])
2022-10-25 13:38:00.559 DEBUG (MainThread) [homeassistant.components.zha.core.channels.base] [0xAA94:1:0x0b04]: async_update
2022-10-25 13:38:00.559 DEBUG (MainThread) [homeassistant.components.zha.core.channels.base] [0xAA94:1:0x0b04]: Reading attributes in chunks: ['active_power', 'rms_current', 'rms_voltage']
2022-10-25 13:38:00.560 DEBUG (MainThread) [zigpy.zcl] [0xAA94:1:0x0b04] Sending request header: ZCLHeader(frame_control=FrameControl(frame_type=<FrameType.GLOBAL_COMMAND: 0>, is_manufacturer_specific=False, direction=<Direction.Server_to_Client: 0>, disable_default_response=0, reserved=0, *is_cluster=False, *is_general=True, *is_reply=False), tsn=105, command_id=<GeneralCommand.Read_Attributes: 0>, *direction=<Direction.Server_to_Client: 0>, *is_reply=False)
2022-10-25 13:38:00.561 DEBUG (MainThread) [zigpy.zcl] [0xAA94:1:0x0b04] Sending request: Read_Attributes(attribute_ids=[1291, 1288, 1285])
2022-10-25 13:38:00.562 DEBUG (MainThread) [homeassistant.components.zha.core.channels.base] [0x5E74:1:0x0b04]: async_update
2022-10-25 13:38:00.563 DEBUG (MainThread) [homeassistant.components.zha.core.channels.base] [0x5E74:1:0x0b04]: Reading attributes in chunks: ['active_power', 'rms_current', 'rms_voltage']
2022-10-25 13:38:00.563 DEBUG (MainThread) [zigpy.zcl] [0x5E74:1:0x0b04] Sending request header: ZCLHeader(frame_control=FrameControl(frame_type=<FrameType.GLOBAL_COMMAND: 0>, is_manufacturer_specific=False, direction=<Direction.Server_to_Client: 0>, disable_default_response=0, reserved=0, *is_cluster=False, *is_general=True, *is_reply=False), tsn=106, command_id=<GeneralCommand.Read_Attributes: 0>, *direction=<Direction.Server_to_Client: 0>, *is_reply=False)
2022-10-25 13:38:00.564 DEBUG (MainThread) [zigpy.zcl] [0x5E74:1:0x0b04] Sending request: Read_Attributes(attribute_ids=[1291, 1288, 1285])
2022-10-25 13:38:00.615 DEBUG (MainThread) [zigpy.application] Received a packet: ZigbeePacket(src=AddrModeAddress(addr_mode=<AddrMode.NWK: 2>, address=0xAF70), src_ep=1, dst=AddrModeAddress(addr_mode=<AddrMode.NWK: 2>, address=0x0000), dst_ep=1, source_route=None, extended_timeout=False, tsn=0, profile_id=260, cluster_id=1794, data=Serialized[b'\x18f\x01\x00\x00\x00%\x83\x00\x00\x00\x00\x00\x00\x02\x00\x18\x00'], tx_options=<TransmitOptions.NONE: 0>, radius=29, non_member_radius=0, lqi=90, rssi=None)
2022-10-25 13:38:00.617 DEBUG (MainThread) [zigpy.zcl] [0xAF70:1:0x0702] Received ZCL frame: b'\x18f\x01\x00\x00\x00%\x83\x00\x00\x00\x00\x00\x00\x02\x00\x18\x00'
2022-10-25 13:38:00.618 DEBUG (MainThread) [zigpy.zcl] [0xAF70:1:0x0702] Decoded ZCL frame header: ZCLHeader(frame_control=FrameControl(frame_type=<FrameType.GLOBAL_COMMAND: 0>, is_manufacturer_specific=0, direction=<Direction.Client_to_Server: 1>, disable_default_response=1, reserved=0, *is_cluster=False, *is_general=True, *is_reply=True), tsn=102, command_id=1, *direction=<Direction.Client_to_Server: 1>, *is_reply=True)
2022-10-25 13:38:00.621 DEBUG (MainThread) [zigpy.zcl] [0xAF70:1:0x0702] Decoded ZCL frame: TuyaZBMeteringCluster:Read_Attributes_rsp(status_records=[ReadAttributeRecord(attrid=0x0000, status=<Status.SUCCESS: 0>, value=TypeValue(type=uint48_t, value=131)), ReadAttributeRecord(attrid=0x0200, status=<Status.SUCCESS: 0>, value=TypeValue(type=bitmap8, value=<bitmap8.0: 0>))])
2022-10-25 13:38:00.632 DEBUG (MainThread) [homeassistant.components.zha.core.channels.base] [0x5E74:1:0x0702]: async_force_update
2022-10-25 13:38:00.633 DEBUG (MainThread) [homeassistant.components.zha.core.channels.base] [0x5E74:1:0x0702]: Reading attributes in chunks: ['current_summ_delivered', 'status']
2022-10-25 13:38:00.634 DEBUG (MainThread) [zigpy.zcl] [0x5E74:1:0x0702] Sending request header: ZCLHeader(frame_control=FrameControl(frame_type=<FrameType.GLOBAL_COMMAND: 0>, is_manufacturer_specific=False, direction=<Direction.Server_to_Client: 0>, disable_default_response=0, reserved=0, *is_cluster=False, *is_general=True, *is_reply=False), tsn=107, command_id=<GeneralCommand.Read_Attributes: 0>, *direction=<Direction.Server_to_Client: 0>, *is_reply=False)
2022-10-25 13:38:00.635 DEBUG (MainThread) [zigpy.zcl] [0x5E74:1:0x0702] Sending request: Read_Attributes(attribute_ids=[0, 512])
2022-10-25 13:38:00.659 DEBUG (MainThread) [zigpy.application] Received a packet: ZigbeePacket(src=AddrModeAddress(addr_mode=<AddrMode.NWK: 2>, address=0xAA94), src_ep=1, dst=AddrModeAddress(addr_mode=<AddrMode.NWK: 2>, address=0x0000), dst_ep=1, source_route=None, extended_timeout=False, tsn=0, profile_id=260, cluster_id=1794, data=Serialized[b'\x18g\x01\x00\x00\x00%\xd0\x06\x00\x00\x00\x00\x00\x02\x00\x18\x00'], tx_options=<TransmitOptions.NONE: 0>, radius=29, non_member_radius=0, lqi=45, rssi=None)
2022-10-25 13:38:00.659 DEBUG (MainThread) [zigpy.zcl] [0xAA94:1:0x0702] Received ZCL frame: b'\x18g\x01\x00\x00\x00%\xd0\x06\x00\x00\x00\x00\x00\x02\x00\x18\x00'
2022-10-25 13:38:00.660 DEBUG (MainThread) [zigpy.zcl] [0xAA94:1:0x0702] Decoded ZCL frame header: ZCLHeader(frame_control=FrameControl(frame_type=<FrameType.GLOBAL_COMMAND: 0>, is_manufacturer_specific=0, direction=<Direction.Client_to_Server: 1>, disable_default_response=1, reserved=0, *is_cluster=False, *is_general=True, *is_reply=True), tsn=103, command_id=1, *direction=<Direction.Client_to_Server: 1>, *is_reply=True)
2022-10-25 13:38:00.662 DEBUG (MainThread) [zigpy.zcl] [0xAA94:1:0x0702] Decoded ZCL frame: TuyaZBMeteringCluster:Read_Attributes_rsp(status_records=[ReadAttributeRecord(attrid=0x0000, status=<Status.SUCCESS: 0>, value=TypeValue(type=uint48_t, value=1744)), ReadAttributeRecord(attrid=0x0200, status=<Status.SUCCESS: 0>, value=TypeValue(type=bitmap8, value=<bitmap8.0: 0>))])
2022-10-25 13:38:00.698 DEBUG (MainThread) [zigpy.application] Received a packet: ZigbeePacket(src=AddrModeAddress(addr_mode=<AddrMode.NWK: 2>, address=0xAF70), src_ep=1, dst=AddrModeAddress(addr_mode=<AddrMode.NWK: 2>, address=0x0000), dst_ep=1, source_route=None, extended_timeout=False, tsn=0, profile_id=260, cluster_id=2820, data=Serialized[b'\x18h\x01\x0b\x05\x00)\x00\x00\x08\x05\x00!\x00\x00\x05\x05\x00!\xea\x00'], tx_options=<TransmitOptions.NONE: 0>, radius=29, non_member_radius=0, lqi=87, rssi=None)
2022-10-25 13:38:00.699 DEBUG (MainThread) [zigpy.zcl] [0xAF70:1:0x0b04] Received ZCL frame: b'\x18h\x01\x0b\x05\x00)\x00\x00\x08\x05\x00!\x00\x00\x05\x05\x00!\xea\x00'
2022-10-25 13:38:00.700 DEBUG (MainThread) [zigpy.zcl] [0xAF70:1:0x0b04] Decoded ZCL frame header: ZCLHeader(frame_control=FrameControl(frame_type=<FrameType.GLOBAL_COMMAND: 0>, is_manufacturer_specific=0, direction=<Direction.Client_to_Server: 1>, disable_default_response=1, reserved=0, *is_cluster=False, *is_general=True, *is_reply=True), tsn=104, command_id=1, *direction=<Direction.Client_to_Server: 1>, *is_reply=True)
2022-10-25 13:38:00.703 DEBUG (MainThread) [zigpy.zcl] [0xAF70:1:0x0b04] Decoded ZCL frame: TuyaZBElectricalMeasurement:Read_Attributes_rsp(status_records=[ReadAttributeRecord(attrid=0x050B, status=<Status.SUCCESS: 0>, value=TypeValue(type=int16s, value=0)), ReadAttributeRecord(attrid=0x0508, status=<Status.SUCCESS: 0>, value=TypeValue(type=uint16_t, value=0)), ReadAttributeRecord(attrid=0x0505, status=<Status.SUCCESS: 0>, value=TypeValue(type=uint16_t, value=234))])
2022-10-25 13:38:00.735 DEBUG (MainThread) [zigpy.application] Received a packet: ZigbeePacket(src=AddrModeAddress(addr_mode=<AddrMode.NWK: 2>, address=0xAA94), src_ep=1, dst=AddrModeAddress(addr_mode=<AddrMode.NWK: 2>, address=0x0000), dst_ep=1, source_route=None, extended_timeout=False, tsn=0, profile_id=260, cluster_id=2820, data=Serialized[b'\x18i\x01\x0b\x05\x00)\x00\x00\x08\x05\x00!\x00\x00\x05\x05\x00!\xeb\x00'], tx_options=<TransmitOptions.NONE: 0>, radius=29, non_member_radius=0, lqi=48, rssi=None)
2022-10-25 13:38:00.735 DEBUG (MainThread) [zigpy.zcl] [0xAA94:1:0x0b04] Received ZCL frame: b'\x18i\x01\x0b\x05\x00)\x00\x00\x08\x05\x00!\x00\x00\x05\x05\x00!\xeb\x00'
2022-10-25 13:38:00.736 DEBUG (MainThread) [zigpy.zcl] [0xAA94:1:0x0b04] Decoded ZCL frame header: ZCLHeader(frame_control=FrameControl(frame_type=<FrameType.GLOBAL_COMMAND: 0>, is_manufacturer_specific=0, direction=<Direction.Client_to_Server: 1>, disable_default_response=1, reserved=0, *is_cluster=False, *is_general=True, *is_reply=True), tsn=105, command_id=1, *direction=<Direction.Client_to_Server: 1>, *is_reply=True)
2022-10-25 13:38:00.738 DEBUG (MainThread) [zigpy.zcl] [0xAA94:1:0x0b04] Decoded ZCL frame: TuyaZBElectricalMeasurement:Read_Attributes_rsp(status_records=[ReadAttributeRecord(attrid=0x050B, status=<Status.SUCCESS: 0>, value=TypeValue(type=int16s, value=0)), ReadAttributeRecord(attrid=0x0508, status=<Status.SUCCESS: 0>, value=TypeValue(type=uint16_t, value=0)), ReadAttributeRecord(attrid=0x0505, status=<Status.SUCCESS: 0>, value=TypeValue(type=uint16_t, value=235))])
Any clue on why this is not working?
Thanks!
Manuel
