I would like to create an automation that checks if ALL my doors are closed (binary_sensor.XYZ_contact state to off) and ALL my Rolling Shutter as well closed (cover.rolling_shutter_switch_XYZ are in state closed), and if ALL those are in a desired state, then my input_boolean becomes on.
On the Automations I cannot handle the AND statement. AFAIK it works in OR, also the input_boolean would thange its state already if one door gets closed.
How to accomplish this?
Then I’ve another question. Is then possible to change, in the same automation, not only the input_boolean status, but the icon as well?
I would then use this input_boolean to trigger an alarm system later on.
Create a binary_sensor that is on, when at least 1 door is open and off otherwise. The icon will be an open door when at least one door is open, otherwise it will be a closed door.
binary_sensor:
sensors:
at_least_one_door_open:
friendly_name: At least one door open
value_template: >-
{{ expand('group.all_door_entities')|selectattr('state','eq','on')|list|count > 0 }}
device_class: door
Hello @Burningstone,
Thanks for the help. What about the cover.rolling_shutter_switch_000 which are in state open, closed, opening or closing? I need that they are in closed.
Thank you!
- alias: whatever name
- platform: state
entity_id: group.all_door_entities
to: 'on'
will trigger when any of the group items changes to ‘on’. A similar approach can be used for an ‘off’ transition, or, checking for all “closing” or “closed”. The combinations are numerous. The binary_sensor might be an overkill - depends on what the final objective is.
Hello @ninjaef,
Thanks you too… I ask you the same:
What about the cover.rolling_shutter_switch_000 which are in state open, closed, opening or closing? I need that they are in closed. So they are different entitiy types in the same group.
Thank you!
And read the docs on Groups and Automation. There are endless configs that can be created to account for a plethora of scenarios and requirements.
I am not suggesting binary_sensor is not suitable, it is indeed one way to cook the egg, but sometimes chunking up to a higher abstraction level is easier, more flexible, modular, and future proof (or as good as).
EDIT: Sorry, this post was sent at the same time you replied.
Also, when using automations, consider the impact of automation mode (it is described in the docs) which can on occasion yield undesired effects. The default is (when not specified) “single” but this can result in system behaviour that is not necessarily that which is expected or indeed, needed. That said, “single” might be totally suitable in certain use cases…
Yep, all should start from the RTFM approach, really true
often I’m sure to use the right approach without knowing the thousend ways that egg could be cooked. Sometimes is a little difficult to have an overview about the different alternatives, for which, this forum does a great job.
Thank you @ninjaef !
