How to create group of entities which can then be used in various places in HA?
I feel that I’m duplicating code and an wondering if there is a better way to do it.
I have created a group of lights, starting with all lights and then filtering out some:
{{ states.light | selectattr('state', 'eq', 'on') | rejectattr('attributes.friendly_name', 'contains', 'Air Quality') | map(attribute='attributes.friendly_name') }}
I have used this group to create a numeric sensor:
{{ states.light | selectattr('state', 'eq', 'on') | rejectattr('attributes.friendly_name', 'contains', 'Air Quality') | map(attribute='attributes.friendly_name') | list | count }}
I have used this group to enumerate a list of all these lights in a notification message:
{{ states.light | selectattr('state', 'eq', 'on') | rejectattr('attributes.friendly_name', 'contains', 'Air Quality') | map(attribute="attributes.friendly_name") | join(', ') }}
I’m concerned that when I want to filter out additional lights in the future that I’ll have to do this is multiple places and it will become untenable.
Is there a way that I can not duplicate the code used to create this list of entities?
One simple and reliable method is to store the list in an attribute of a Template sensor.
template:
  - binary_sensor:
      - name: On Lights
        state: |
          | list | count > 0 }}
        attributes:
          entity_id: |
            | map(attribute='entity_id') | list }}
You can use any attribute name you like, I’ve used entity_id so it matches the way existing group helper and group entities work.
Thank you for the suggestion. How do I then use the data placed into the entity attribute to reduce code duplication when I wish to use this list of entities when creating a new entity?
In this example, use:
{{ is_state('binary_sensor.on_lights', 'on') }}
to return true if any of your selection is on, and:
{{ state_attr('binary_sensor.on_lights', 'entity_id') }}
to access the list.
Your bedtime reading:
