After all, I couldn’t find a way to add more climate entities trough UI so I edited the main configuration.yaml file and added those 2 lines at the end of the file:
climate: !include climates.yaml
switch: !include switches.yaml
The climates.yaml files has all the EXTRA thermostats, except the first one that I don’t know where exactly is saved. The first one can be updated trough UI, all the other ones that are created in YAML file can’t be updated trough UI also the GENERIC THERMOSTAT option menu is missing
- platform: generic_thermostat
name: "Kitchen Thermostat"
heater: switch.ipat_kitchen_reversed
target_sensor: sensor.kitchen_temperature
min_temp: 10
max_temp: 25
target_temp: 21
cold_tolerance: 0.3
hot_tolerance: 0.3
away_temp: 16
precision: 0.1
unique_id: kitchen_thermostat_1
name: "Livingroom Thermostat"
heater: switch.ipat_lounge_2_reversed
target_sensor: sensor.living_room_temperature
min_temp: 10
max_temp: 25
target_temp: 21
cold_tolerance: 0.3
hot_tolerance: 0.3
away_temp: 16
precision: 0.1
unique_id: livingroom_thermostat_1
name: "Main Bathroom Thermostat"
heater: switch.ipat_bath_reversed
target_sensor: sensor.bathroom_temperature_temperature
min_temp: 10
max_temp: 27
target_temp: 22
cold_tolerance: 0.3
hot_tolerance: 0.3
away_temp: 16
precision: 0.1
unique_id: main_bathroom_thermostat_1
name: "Office Thermostat"
heater: switch.ipat_room_1_reversed
target_sensor: sensor.office_temperature
min_temp: 10
max_temp: 25
target_temp: 20
cold_tolerance: 0.3
hot_tolerance: 0.3
away_temp: 16
precision: 0.1
unique_id: office_thermostat_1
name: "Hallway Thermostat"
heater: switch.ipat_lounge_reversed
min_temp: 10
max_temp: 25
target_temp: 20
cold_tolerance: 0.3
hot_tolerance: 0.3
away_temp: 16
precision: 0.1
unique_id: hallway_thermostat_1
The switches.yaml file has now this content:
switches:
ipat_entrance_reversed:
friendly_name: "IPAT Entrance (Reversed)"
value_template: "{{ is_state('switch.esphome_web_ipat2_ipat_entrance', 'off') }}"
turn_on:
service: switch.turn_off
entity_id: switch.esphome_web_ipat2_ipat_entrance
turn_off:
service: switch.turn_on
ipat_room_1_reversed:
friendly_name: "IPAT Room 1 (Reversed)"
value_template: "{{ is_state('switch.esphome_web_ipat2_ipat_room_1', 'off') }}"
turn_on:
entity_id: switch.esphome_web_ipat2_ipat_room_1
turn_off:
ipat_lounge_2_reversed:
friendly_name: "IPAT Lounge 2 (Reversed)"
value_template: "{{ is_state('switch.esphome_web_ipat2_ipat_lounge_2', 'off') }}"
turn_on:
entity_id: switch.esphome_web_ipat2_ipat_lounge_2
turn_off:
ipat_room_2_reversed:
friendly_name: "IPAT Room 2 (Reversed)"
value_template: "{{ is_state('switch.esphome_web_ipat2_ipat_room_2', 'off') }}"
turn_on:
entity_id: switch.esphome_web_ipat2_ipat_room_2
turn_off:
ipat_kitchen_reversed:
friendly_name: "IPAT Kitchen (Reversed)"
value_template: "{{ is_state('switch.esphome_web_c56e68_ipat_kitchen', 'off') }}"
turn_on:
entity_id: switch.esphome_web_c56e68_ipat_kitchen
turn_off:
ipat_bath_reversed:
friendly_name: "IPAT Bath (Reversed)"
value_template: "{{ is_state('switch.esphome_web_c56e68_ipat_bath', 'off') }}"
turn_on:
entity_id: switch.esphome_web_c56e68_ipat_bath
turn_off:
ipat_gallery_reversed:
friendly_name: "IPAT Gallery (Reversed)"
value_template: "{{ is_state('switch.esphome_web_c56e68_ipat_gallery', 'off') }}"
turn_on:
entity_id: switch.esphome_web_c56e68_ipat_gallery
turn_off:
ipat_lounge_reversed:
friendly_name: "IPAT Lounge (Reversed)"
value_template: "{{ is_state('switch.esphome_web_c56e68_ipat_lounge', 'off') }}"
turn_on:
entity_id: switch.esphome_web_c56e68_ipat_lounge
turn_off:
and I also added the reverse switch so the underfloor heating system works as it should, with the NORMALLY OPENED valves, this way when the thermostat set to heating needs to turn on HEAT, it turns on the reversed switched, the template of the reversed switch will turn off the real switch connected to the valve .
When the thermostat turn off heating reversed switched, the real switch turns on and finally the valve is actuated and stops the flow of water trough the underfloor circuit.
I find NORMALLY OPENED valves the best option, as no matter what happens to the automation, to the smart home brain, the heating in the house won’t be affected, as all circuits are opened and the heating can be set trough the gas heater temperature setting. In my case I use only 32 - 33 degrees for the water, it works smoothly and the gas consumption is quite low.
So this is the only way to have multiple thermostats added to HA, multiple climate entities? Isn’t there a way to have all the thermostats with this menu available: GENERIC THERMOSTAT OPTION.? This menu is missing in all the thermostats created trough yaml, only the first thermostat I created has this option, and I don’t understand why : (
Thank you
