[Solved] How to create two rows on ipad mini
Up until HA 0.115 I had my Lovelace showing in two rows on the iPad mini. Like on pc:
but after updating two 0.116 it shows in one row:
Any suggestions as to how I can get my two rows back? I dont want to use HACS.
Two vertical stacks? With nested horizontal stacks in the column on the left?
Here is a solution to have more controls over the UI grid.
Or you can do more complex coding for particular breakpoints. Look for some ideas here
And just try to reload a cache on the tablet and switch horizontal and back to vertical mode to reload a screen resolution
Thank you! I nested the nest within the nests nest :sweat_smile: And made a new Lovelace dashboard with the YAML below which I set as default on the panel in the hallway!
  - title: Panel
    path: panel
    panel: true
    badges: []
    cards:
      - type: vertical-stack
        cards:
          - type: horizontal-stack
            cards:
                cards:
                  - type: weather-forecast
                    entity: weather.hjem
                    title: Moduser
                    cards:
                      - type: button
                        tap_action:
                          action: toggle
                        entity: input_boolean.hjemme
                        show_state: false
                        icon_height: 60px
                      - type: button
                        tap_action:
                          action: toggle
                        entity: input_boolean.godnatt
                        icon_height: 60px
                      - type: button
                        tap_action:
                          action: toggle
                        entity: input_boolean.ferie
                        icon_height: 60px
                    cards:
                        cards:
                          - type: button
                            tap_action:
                              action: toggle
                            entity: input_boolean.kveldskos
                            icon_height: 60px
                          - type: button
                            tap_action:
                              action: toggle
                            entity: input_boolean.gaar_hjemmefra
                            icon_height: 60px
                          - type: button
                            tap_action:
                              action: toggle
                            entity: input_boolean.kjorer_hjemmefra
                            icon_height: 60px
                    title: Dør og port
                    cards:
                      - type: button
                        tap_action:
                          action: toggle
                        entity: lock.id_lock_as_150_locked
                        show_state: true
                        icon_height: 60px
                      - type: button
                        tap_action:
                          action: toggle
                        entity: cover.garasjeport_barrier_state_label
                        show_state: true
                        icon_height: 60px
                cards:
                    cards:
                      - type: glance
                        entities:
                          - entity: person.anette_haugland
                          - entity: person.daniel
                          - entity: person.leah_haugland
                      - type: entities
                        entities:
                          - entity: switch.outlet_kaffetrakter
                          - entity: switch.fibaro_system_fgwpe_f_wall_plug_gen5_switch
                          - entity: switch.panelovn_kjeller
                            name: Panelovn kjellergang
                          - entity: vacuum.roomba
                          - entity: switch.taklys_garasjen_switch_3
                            name: Taklys i garasjen
                          - entity: climate.varmepumpe
                        show_header_toggle: false
                      - type: history-graph
                        entities:
                          - entity: sensor.stue_temp
                          - entity: sensor.temperature_kjellergang
                          - entity: sensor.sensor_garasje_temperature
                        hours_to_show: 24
                        refresh_interval: 0
