I have a light fixture (LED retrofits but with the old transformers still in place) integrated via MQTT into my Home Assistant instance that has a very specific oddity regarding brightness control.
I can send a value from 0 to 100 to the light, but it stays turned off with values below 61. I now want to “emulate” a standard light (brightness from 1 to 100) in the HA frontend and backend so all my existing automations work for this light.
I need to translate the state (current brightness, can be from 61 to 100) I get from the light into 1-100 for HA display, manipulation and storage, then translate commands to the light’s brightness scale (61 to 100) again before sending them.
I have Node-RED running and currently use that for the light control over MQTT so I could wire in any node between the MQTT topics and HA.
Best wishes
Aaron
