I am new to HA, I have 1 problem with Z2M button working.
I have 20 same Ikea Tradfri 5button , connected with Z2M button automaiton. 19 of them working good, but 1 button not working I do the same like 19 what working.
Strange problem is that when I press that button - device remote react and I see that I press button. (so probably remote is sucesfully connected to HA)
Strangest thing is that light think its ON but bulb not turn on. (if I press the light in application its normaly bulb turn on)
in automations it detect last triggered when I press but nothing happend to device.
I checked its connected to bulb normaly.
I have similar situation with automation for SunSet and Sunrise, automation triggered but light don’t turn on , but on Sunrise its normaly go off.
I want to learn and see how I can debug this to know for future using.
I am new to HA after 5 years of Smartthings and I sucesfully connected more then 60 devices in HA in just 3 days of learning
. I love speed of HA against Smartthings.
Post the automations you are having trouble with (as preformatted text)
Automation code for automation that don’t working
alias: Spavaća soba Vedran daljinski - automatizacija
description: ""
use_blueprint:
path: starbuck93/zigbee2mqtt-2-0-ikea-five-button-remote.yaml
input:
remote: 194b3fd085ab9b5aabe3cc9d26cf55e7
light:
device_id: 56a1e21a94a8b8e893de348cf6be6b0d
Automation config (Not working)
mode: restart
max_exceeded: silent
variables:
force_brightness: false
triggers:
- domain: mqtt
device_id: 194b3fd085ab9b5aabe3cc9d26cf55e7
type: action
subtype: toggle
trigger: device
- domain: mqtt
type: action
subtype: brightness_down_hold
trigger: device
- domain: mqtt
type: action
subtype: brightness_down_release
trigger: device
- domain: mqtt
type: action
subtype: brightness_down_click
trigger: device
- domain: mqtt
type: action
subtype: arrow_left_hold
trigger: device
- domain: mqtt
type: action
subtype: arrow_left_release
trigger: device
- domain: mqtt
type: action
subtype: arrow_left_click
trigger: device
- domain: mqtt
type: action
subtype: toggle_hold
trigger: device
- domain: mqtt
type: action
subtype: brightness_up_hold
trigger: device
- domain: mqtt
type: action
subtype: brightness_up_release
trigger: device
- domain: mqtt
type: action
subtype: brightness_up_click
trigger: device
- domain: mqtt
type: action
subtype: arrow_right_click
trigger: device
- domain: mqtt
type: action
subtype: arrow_right_hold
trigger: device
- domain: mqtt
type: action
subtype: arrow_right_release
trigger: device
actions:
- variables:
command: '{{ trigger.payload }}'
button_long_max_loop_repeats: 100
- choose:
- conditions:
- '{{ command == ''toggle'' }}'
sequence:
- choose:
- conditions: '{{ force_brightness }}'
sequence:
- target:
transition: 1
brightness_pct: 50
action: light.toggle
default:
- target:
transition: 0
- conditions:
- '{{ command == ''brightness_up_click'' }}'
sequence:
- target:
brightness_step_pct: 10
transition: 1
action: light.turn_on
- conditions:
- '{{ command == ''brightness_up_hold'' }}'
sequence:
- repeat:
while: '{{ repeat.index < button_long_max_loop_repeats | int }}'
sequence:
- data:
transition: 1
- delay: '1'
- conditions:
- '{{ command == ''brightness_up_release'' }}'
sequence: []
- conditions:
- '{{ command == ''brightness_down_click'' }}'
sequence:
- target:
brightness_step_pct: -10
transition: 1
- conditions:
- '{{ command == ''brightness_down_hold'' }}'
sequence:
- repeat:
sequence:
- data:
transition: 1
- delay: '1'
- conditions:
- '{{ command == ''brightness_down_release'' }}'
sequence: []
- conditions:
- '{{ command == ''arrow_left_click'' }}'
sequence: []
- conditions:
- '{{ command == ''arrow_left_hold'' }}'
sequence: []
- conditions:
- '{{ command == ''arrow_right_click'' }}'
sequence: []
- conditions:
- '{{ command == ''arrow_right_hold'' }}'
sequence: []
description: ''
Here is same 2 devices what normaly working I will paste of working automation too.
Automation 2 - What is Working
alias: Spavaća soba Tatjana daljinski - automatizacija
description: ''
use_blueprint:
input:
remote: 100264b5f652004453cc03f80a656176
light:
device_id: 5a2ffe82aeab184199095b03e5fd1e55
Automation 2 (Working) - Automatin config
mode: restart
variables:
triggers:
- domain: mqtt
device_id: 100264b5f652004453cc03f80a656176
type: action
subtype: toggle
trigger: device
- domain: mqtt
type: action
trigger: device
- domain: mqtt
type: action
trigger: device
- domain: mqtt
type: action
trigger: device
- domain: mqtt
type: action
trigger: device
- domain: mqtt
type: action
trigger: device
- domain: mqtt
type: action
trigger: device
- domain: mqtt
type: action
trigger: device
- domain: mqtt
type: action
trigger: device
- domain: mqtt
type: action
trigger: device
- domain: mqtt
type: action
trigger: device
- domain: mqtt
type: action
trigger: device
- domain: mqtt
type: action
trigger: device
- domain: mqtt
type: action
trigger: device
actions:
- variables:
- choose:
- conditions:
sequence:
- choose:
sequence:
- target:
transition: 1
brightness_pct: 50
default:
- target:
transition: 0
- conditions:
sequence:
- target:
transition: 1
- conditions:
sequence:
- repeat:
sequence:
- data:
transition: 1
- delay: '1'
- conditions:
sequence: []
- conditions:
sequence:
- target:
transition: 1
- conditions:
sequence:
- repeat:
sequence:
- data:
transition: 1
- delay: '1'
- conditions:
sequence: []
- conditions:
sequence: []
- conditions:
sequence: []
- conditions:
sequence: []
- conditions:
sequence: []
description: ''
Trace timeline (working automation)
Trace timeline (not working automation)
