I am designing an ESP32C3 board that can be used to control electric baseboard heaters. It has a built-in temperature sensor, using Qwicc connectors it can activate a SSR and read temperature/humidity over i2C. I am planning to sell this device and want to make it as simple as possible to install.
It is quite simple to add it to ESPHome but a problem arises when it is time to link it to a thermostat card. It has to be a climate component.
The only way i found was to edit the configuration.yaml file.
climate:
- platform: generic_thermostat
heater: switch.study_heater
target_sensor: sensor.bureau_bureau_temp
min_temp: 15
max_temp: 24
ac_mode: false
target_temp: 17
cold_tolerance: 0.3
hot_tolerance: 0
min_cycle_duration:
seconds: 5
keep_alive:
minutes: 3
initial_hvac_mode: "off"
away_temp: 16
precision: 0.1
unique_id: climate.generic_thermostat.bureau
Once that is done,you can add a thermostat card.
I find this too difficult for a newbie. You need the file editor and you need to find the config file etc.
My Question:
Is it possible to define a climate component in its configuration yaml file in the ESPHome builder pane?
something like this adding climate:
i2c:
sda: GPIO5
scl: GPIO6
scan: True
#### add climate: ??????
- platform: htu31d
temperature:
name: "HTU31D Temperature"
humidity:
name: "HTU31D Humidity"
update_interval: 60s
switch:
- platform: gpio
pin: 8
inverted: True
Thanks and ESPHome is awesome.
