My bot sends me a Telegram every day. But I want to delete the last message before sending the next one.
I can’t get it work to delete that message by MessageId. Who can help me?
[{"id":"2aaf58f2.e531f8","type":"function","z":"f714f82a.1e3598","name":"save messageId","func":"// We store the messageId to be able to edit this reply in the callback query. \ncontext.global.set(\"batterijniveau\" , msg.payload.sentMessageId);\nreturn [ msg ];\n","outputs":"1","noerr":0,"initialize":"","finalize":"","x":880,"y":340,"wires":[["d1350d05.505ce"]]},{"id":"d1350d05.505ce","type":"debug","z":"f714f82a.1e3598","name":"","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"true","targetType":"full","statusVal":"","statusType":"auto","x":1050,"y":340,"wires":[]},{"id":"d7137dd4.be768","type":"inject","z":"f714f82a.1e3598","name":"","props":[{"p":"payload"}],"repeat":"","crontab":"","once":false,"onceDelay":"","topic":"","payload":"batterijniveau","payloadType":"global","x":150,"y":360,"wires":[["f6535f3a.7e6e6"]]},{"id":"bc7a7795.6fc0b8","type":"debug","z":"f714f82a.1e3598","name":"","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"payload","targetType":"msg","statusVal":"","statusType":"auto","x":610,"y":360,"wires":[]},{"id":"f6535f3a.7e6e6","type":"function","z":"f714f82a.1e3598","name":"evaluate callback query","func":"// This is a sample switch to demonstrate the handling of the user input.\n// Hide the keyboard and forget the messageId\nmsg.payload.type = 'deleteMessage';\nmsg.payload.content = context.global.keyboard.messageId\ncontext.global.keyboard.messageId = null;\n\n// You could also send a editMessageReplyMarkup with an empty reply_markup here\nreturn [ null, msg ];\n","outputs":1,"noerr":0,"initialize":"","finalize":"","x":390,"y":360,"wires":[["bc7a7795.6fc0b8"]]},{"id":"c27568aa.8da138","type":"comment","z":"f714f82a.1e3598","name":"Wis telegram wanneer batterijniveau van de Xiaomi Mi A2 30% of hoger.","info":"","x":290,"y":320,"wires":[]},{"id":"5996b627.ad95e8","type":"telegram sender","z":"f714f82a.1e3598","name":"","bot":"","x":870,"y":260,"wires":[["2aaf58f2.e531f8"]]},{"id":"b7197838.709908","type":"server-state-changed","z":"f714f82a.1e3598","name":"","server":"779d12e2.03b0bc","version":1,"exposeToHomeAssistant":false,"haConfig":[{"property":"name","value":""},{"property":"icon","value":""}],"entityidfilter":"sensor.mi_a2_battery_level","entityidfiltertype":"exact","outputinitially":false,"state_type":"str","haltifstate":"","halt_if_type":"str","halt_if_compare":"is","outputs":1,"output_only_on_state_change":false,"x":200,"y":80,"wires":[["db45ea7.6118518"]]},{"id":"fd0c7d7a.06ae","type":"function","z":"f714f82a.1e3598","name":"Telegram [ALERT]","func":"var mypayload = msg.payload;\nvar mytekst = ''\nif(mypayload < 16)\n{\n mytekst = '\\nTijd om op te laden !'\n}\n\nmsg.payload = {\n chatId : 123456789,\n type : 'message',\n content : 'Let op: Batterijniveau is ' + mypayload + '%.' + mytekst\n}\n\nreturn msg;","outputs":1,"noerr":0,"initialize":"","finalize":"","x":850,"y":180,"wires":[["5996b627.ad95e8"]]},{"id":"9a0855b.6a982a8","type":"comment","z":"f714f82a.1e3598","name":"Zend telegram wanneer batterijniveau van de Xiaomi Mi A2 30% of lager is. (indien niet aan de lader)","info":"","x":380,"y":40,"wires":[]},{"id":"331e18c7.1ce928","type":"inject","z":"f714f82a.1e3598","name":"click to test","props":[{"p":"payload"}],"repeat":"","crontab":"","once":false,"onceDelay":"","topic":"","payload":"10","payloadType":"num","x":440,"y":220,"wires":[["f09c9d0a.09681"]]},{"id":"da7e2fc1.a6dfe","type":"debug","z":"f714f82a.1e3598","name":"","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"true","targetType":"full","statusVal":"","statusType":"auto","x":650,"y":260,"wires":[]},{"id":"ae1f8a8f.517288","type":"api-current-state","z":"f714f82a.1e3598","name":"","server":"779d12e2.03b0bc","version":1,"outputs":1,"halt_if":"","halt_if_type":"num","halt_if_compare":"is","override_topic":false,"entity_id":"sensor.mi_a2_battery_level","state_type":"str","state_location":"payload","override_payload":"msg","entity_location":"data","override_data":"msg","blockInputOverrides":false,"x":340,"y":180,"wires":[["da7e2fc1.a6dfe","f09c9d0a.09681"]]},{"id":"f09c9d0a.09681","type":"switch","z":"f714f82a.1e3598","name":"","property":"payload","propertyType":"msg","rules":[{"t":"eq","v":"30","vt":"str"},{"t":"eq","v":"25","vt":"str"},{"t":"eq","v":"20","vt":"str"},{"t":"eq","v":"15","vt":"str"},{"t":"eq","v":"10","vt":"str"},{"t":"eq","v":"5","vt":"str"}],"checkall":"false","repair":false,"outputs":6,"x":650,"y":180,"wires":[["fd0c7d7a.06ae"],["fd0c7d7a.06ae"],["fd0c7d7a.06ae"],["fd0c7d7a.06ae"],["fd0c7d7a.06ae"],["fd0c7d7a.06ae"]]},{"id":"db45ea7.6118518","type":"api-current-state","z":"f714f82a.1e3598","name":"Niet aan het opladen?","server":"779d12e2.03b0bc","version":1,"outputs":2,"halt_if":"discharging","halt_if_type":"str","halt_if_compare":"is","override_topic":false,"entity_id":"sensor.mi_a2_battery_state","state_type":"str","state_location":"payload","override_payload":"msg","entity_location":"data","override_data":"msg","blockInputOverrides":false,"x":500,"y":80,"wires":[["ae1f8a8f.517288"],[]]},{"id":"779d12e2.03b0bc","type":"server","name":"Home Assistant","legacy":false,"addon":true,"rejectUnauthorizedCerts":true,"ha_boolean":"y|yes|true|on|home|open","connectionDelay":false,"cacheJson":true}]
