How to delete an Automation.yami
New guy here: I built and now want to delete a couple of automations but an error message "Only automations in automations.yaml can be deleted." How do I do this?
These are automations that you either moved out of the ui editor or created using an external editor. You would need to use an external editor to edit or remove those.
I only used the HA UI to create them? I have deleted them in the past from the UI but for some reason the same automations are now coming up with the same error message that I must use automation yaml to delete. I dont even know where to find that.
Never mind... I just restarted HA and was able to delete as usual. Thx
