How to delete an old / orphaned Alarm Entity
Hi Community,
I´m pretty new to homeassistant and learning each day.
I played a little bit with the Alarm Panel and have old entities which I can´t delete anymore.
How can I delete those?
Thanks for a hint.
Greetings
Electro
after you remove it from configuration.yaml restart. then logout, then log back in and refresh the page.
If that doesn’t work, restart. (After your check config.)
Thank you very much, I went really crazy, because I restarted and deleted cache and they still appeared.
After 2 days, they are gone, now :slight_smile:
