I’m busys creating my own dashboard and struggling to get something done.
I like to detect in a custom:button-card how many lights are on in a specifick area
something like:
in this example → (states[“light.ikea_5_lamp_tv”].state == “off”)
must be code to detect the amount of lights on of a specific area.
I know that I do need to use the attribute.device_class
of light and then check the state.
But I don’t know how to translate this in an if test code
I like to create a result to show like:
This sample is very cobbled together from one of my templates for door sensors and a couple of searches here, but reveals that two of the light sets in my kitchen are currently on:
{%- set ns = namespace(lightsensors=[]) -%}
{%- set ns.lightsensors = states.light
| selectattr('entity_id', 'in', area_entities('Kitchen'))
| selectattr('state', 'eq', 'on')
| map (attribute='name') | list -%}
{{ ns.lightsensors | count }}
Remove the “| count” if you want an array, which you can join if you want a string. I do this to show a list of doors/windows that are unlocked and/or open.
You can add
| selectattr('attributes.brightness', '>=', 128)
For example, to narrow the list to lights that are 50% brightness or higher (assuming like mine yours go to 255).
Thanks very much for the answers.
I’m just started 2 weeks ago to create my own dashboard
It is quit more complex then I expected
I don’t understand where to create these sensors.
In the configuration or sensor.yaml?
and @myle is this sensor not missing the area?
If I put it in the template tester it shows indeed a figure of all my lights
and @haus it indeed shows trhe amount of lights in my “Woonkamer” if I put that as area.
I only need to know where to create these sensors
