How to disable as many functions on iPad at wall (in rental home) and the perimeter function
I’m preparing Apple iPad’s for rental units to be mounted on the wall. I have about 3 apps which should be used, including HA. The rest should be all removed, including App Store, Photo library, iMessage and most importantly Settings. I don’t want renters to mesh around with the settings of the iPad and the access to the Apple account which it is linked.
The kiosk mode (guided access) is not working as it can only work with 1 app, while I have about 3 apps.
Also, it is preferred the screen goes off after for instance 10 minutes and at night and there is no movement. If there is any movement, it should be turned automatically without pressing the home button.
Is anyone have a suggestion?
