I keep reading these blog posts about the new changes in Home Assistant updates, and they mention the use of ChatGPT in HA.
How do you disable ChatGPT in Home Assistant, or is it only available after an Integration for it is installed?
ChatGPT is only used for the new voice assistant conversations, but only if you explicitly configure it. No worries, if you don’t want to, you are in no way obligated to use it.
