I’ve a Google Calendar setup. It does work fine and I do see my events in the Calendar tab.
I did create a “Holiday” agenda, named calendar.holiday. I do see this value changing between ON and OFF.
But I would like to setup stuff the previous day for the next day. Like at 9PM, I would like to setup the next day(alarm, philips hue, …), because I usually put my phone in plane mode during the night and therefore it will ring even the automation tried to deactivated it.
I don’t know how to see if the next morning I should be in the work or in the holiday mode?
Hi @Nick4 !
Thanks for the answer, I’ve tried a bit with your implementation.
The only issue I get is due to my agenda:
I can have either:
One full day of holiday
One half day(morning or afternoon) of holiday
the issue is that when I’ve a holiday for the full day, I set it as “full day” in google calendar, and therefore, the automation starts at 12:00
But when I’ve only one half day, I set it just for the morning(Typically 07:00 to 12:00).
Therefore if I just set an offset of X hours, it will not at all trigger at the same time.
Isn’t there a way to check if tomorrow at 08:00, a meeting is present, no matter the hour of the current day?
