I was facing the same problem and found my own solution. I don’t know if there is any ‘offical’ one yet.
So I noticed that in .storage/core.entity_registry there are all information we need. With the following shell_command you can extract the entity_ids and aliases:
get_entity_alias: jq '[.data.entities[] | select(.options.conversation.should_expose == true and (.aliases | length > 0)) | {aliases, entity_id}]' ./.storage/core.entity_registry
I’ve then made a sensor:
#Sensor für Zuordnung von Alias Namen zu Entity-IDs (Update über Neustart oder Service homeassistant.update_entity)
- trigger:
- platform: homeassistant
event: start
- service: shell_command.get_entity_alias
data: {}
response_variable: result
- name: "Assist: Entity IDs mit Alias"
state: '0'
attributes:
entities: "{{result.stdout}}"
And there you have it. In your script you can then use something like this:
variables:
area: "{{area}}"
area_id: "{{area_id(area) or None}}"
entity_id: >-
{{ (state_attr('sensor.assist_entity_ids_mit_alias','entities') |
selectattr('aliases', 'contains', name) | map(attribute='entity_id') |
list)[0] or None }}
