Hi All,
I´m using HA on a wall mounted iPad.
For some switches I use the via HACS installed Restriction Card. That works fine so far.
Due to my security pins for these switches are numeric, I want that the ipad numeric keypad will open insted the full keyboard.
- card:
entity: switch.3d_drucker_outlet
icon: hass:power
duration: 10
state_color: true
restrictions:
pin:
code: 1234
text: 'Bitte Code eingeben:'
type: custom:restriction-card
row: true
duration: 10
How to force iPad to open the numeric Keypad? Is there any way to let the ipad now that numeric input is expected? Is there any trick I can use? Something like: {num’1234’}
Maybe a JS pro can give an answer…
Thanx
