Hi @Schneider here are some new codes for you to test.
This first set should work with the relays luz_quarto, luz_mesa_jantar and luz_corredor. These are probably 315mhz codes.
# 0x074133 = 0000 0111 0100 0001 0011 0011: low_period=0x0b, high_period=0x24, stop_period=0x6a, inverted?N, TX mode=0xe9 315mhz???
command_on: "6QCWACQLJAskCyQLJAsLJAskCyQkCwskJAskCyQLJAskCwskJAskCwskCyQkCyQLCyQLJAFqJAskCyQLJAskCwskCyQLJCQLCyQkCyQLJAskCyQLCyQkCyQLCyQLJCQLJAsLJAskAWokCyQLJAskCyQLCyQLJAskJAsLJCQLJAskCyQLJAsLJCQLJAsLJAskJAskCwskCyQBag=="
# 0x07413c = 0000 0111 0100 0001 0011 1100: low_period=0x0b, high_period=0x24, stop_period=0x6a, inverted?N, TX mode=0xe9 315mhz???
command_off: "6QCWACQLJAskCyQLJAsLJAskCyQkCwskJAskCyQLJAskCwskJAskCwskCyQLJAskJAskCwFqJAskCyQLJAskCwskCyQLJCQLCyQkCyQLJAskCyQLCyQkCyQLCyQLJAskCyQkCyQLAWokCyQLJAskCyQLCyQLJAskJAsLJCQLJAskCyQLJAsLJCQLJAsLJAskCyQLJCQLJAsBag=="
# 0x1742c3 = 0001 0111 0100 0010 1100 0011: low_period=0x0b, high_period=0x24, stop_period=0x6a, inverted?N, TX mode=0xe9 315mhz???
command_on: "6QCWACQLJAskCwskJAsLJAskCyQkCwskJAskCyQLJAsLJCQLCyQLJCQLJAskCyQLCyQLJAFqJAskCyQLCyQkCwskCyQLJCQLCyQkCyQLJAskCwskJAsLJAskJAskCyQLJAsLJAskAWokCyQLJAsLJCQLCyQLJAskJAsLJCQLJAskCyQLCyQkCwskCyQkCyQLJAskCwskCyQBag=="
# 0x1742cc = 0001 0111 0100 0010 1100 1100: low_period=0x0b, high_period=0x24, stop_period=0x6a, inverted?N, TX mode=0xe9 315mhz???
command_off: "6QCWACQLJAskCwskJAsLJAskCyQkCwskJAskCyQLJAsLJCQLCyQLJCQLJAsLJAskJAskCwFqJAskCyQLCyQkCwskCyQLJCQLCyQkCyQLJAskCwskJAsLJAskJAskCwskCyQkCyQLAWokCyQLJAsLJCQLCyQLJAskJAsLJCQLJAskCyQLCyQkCwskCyQkCyQLCyQLJCQLJAsBag=="
# 0x274303 = 0010 0111 0100 0011 0000 0011: low_period=0x0b, high_period=0x24, stop_period=0x6a, inverted?N, TX mode=0xe9 315mhz???
command_on: "6QCWACQLJAsLJCQLJAsLJAskCyQkCwskJAskCyQLJAsLJAskJAskCyQLJAskCyQLCyQLJAFqJAskCwskJAskCwskCyQLJCQLCyQkCyQLJAskCwskCyQkCyQLJAskCyQLJAsLJAskAWokCyQLCyQkCyQLCyQLJAskJAsLJCQLJAskCyQLCyQLJCQLJAskCyQLJAskCwskCyQBag=="
# 0x27430c = 0010 0111 0100 0011 0000 1100: low_period=0x0b, high_period=0x24, stop_period=0x6a, inverted?N, TX mode=0xe9 315mhz???
command_off: "6QCWACQLJAsLJCQLJAsLJAskCyQkCwskJAskCyQLJAsLJAskJAskCyQLJAsLJAskJAskCwFqJAskCwskJAskCwskCyQLJCQLCyQkCyQLJAskCwskCyQkCyQLJAskCwskCyQkCyQLAWokCyQLCyQkCyQLCyQLJAskJAsLJCQLJAskCyQLCyQLJCQLJAskCyQLCyQLJCQLJAsBag=="
# 0x374403 = 0011 0111 0100 0100 0000 0011: low_period=0x0b, high_period=0x24, stop_period=0x6a, inverted?N, TX mode=0xe9 315mhz???
command_on: "6QCWACQLJAsLJAskJAsLJAskCyQkCwskJAskCyQLCyQkCyQLJAskCyQLJAskCyQLCyQLJAFqJAskCwskCyQkCwskCyQLJCQLCyQkCyQLJAsLJCQLJAskCyQLJAskCyQLJAsLJAskAWokCyQLCyQLJCQLCyQLJAskJAsLJCQLJAskCwskJAskCyQLJAskCyQLJAskCwskCyQBag=="
# 0x37440c = 0011 0111 0100 0100 0000 1100: low_period=0x0b, high_period=0x24, stop_period=0x6a, inverted?N, TX mode=0xe9 315mhz???
command_off: "6QCWACQLJAsLJAskJAsLJAskCyQkCwskJAskCyQLCyQkCyQLJAskCyQLJAsLJAskJAskCwFqJAskCwskCyQkCwskCyQLJCQLCyQkCyQLJAsLJCQLJAskCyQLJAskCwskCyQkCyQLAWokCyQLCyQLJCQLCyQLJAskJAsLJCQLJAskCwskJAskCyQLJAskCyQLCyQLJCQLJAsBag=="
# 0x474503 = 0100 0111 0100 0101 0000 0011: low_period=0x0b, high_period=0x24, stop_period=0x6a, inverted?N, TX mode=0xe9 315mhz???
command_on: "6QCWACQLCyQkCyQLJAsLJAskCyQkCwskJAskCyQLCyQkCwskJAskCyQLJAskCyQLCyQLJAFqJAsLJCQLJAskCwskCyQLJCQLCyQkCyQLJAsLJCQLCyQkCyQLJAskCyQLJAsLJAskAWokCwskJAskCyQLCyQLJAskJAsLJCQLJAskCwskJAsLJCQLJAskCyQLJAskCwskCyQBag=="
# 0x47450c = 0100 0111 0100 0101 0000 1100: low_period=0x0b, high_period=0x24, stop_period=0x6a, inverted?N, TX mode=0xe9 315mhz???
command_off: "6QCWACQLCyQkCyQLJAsLJAskCyQkCwskJAskCyQLCyQkCwskJAskCyQLJAsLJAskJAskCwFqJAsLJCQLJAskCwskCyQLJCQLCyQkCyQLJAsLJCQLCyQkCyQLJAskCwskCyQkCyQLAWokCwskJAskCyQLCyQLJAskJAsLJCQLJAskCwskJAsLJCQLJAskCyQLCyQLJCQLJAsBag=="
# 0x574633 = 0101 0111 0100 0110 0011 0011: low_period=0x0b, high_period=0x24, stop_period=0x6a, inverted?N, TX mode=0xe9 315mhz???
command_on: "6QCWACQLCyQkCwskJAsLJAskCyQkCwskJAskCyQLCyQLJCQLJAskCwskCyQkCyQLCyQLJAFqJAsLJCQLCyQkCwskCyQLJCQLCyQkCyQLJAsLJAskJAskCyQLCyQLJCQLJAsLJAskAWokCwskJAsLJCQLCyQLJAskJAsLJCQLJAskCwskCyQkCyQLJAsLJAskJAskCwskCyQBag=="
# 0x57463c = 0101 0111 0100 0110 0011 1100: low_period=0x0b, high_period=0x24, stop_period=0x6a, inverted?N, TX mode=0xe9 315mhz???
command_off: "6QCWACQLCyQkCwskJAsLJAskCyQkCwskJAskCyQLCyQLJCQLJAskCwskCyQLJAskJAskCwFqJAsLJCQLCyQkCwskCyQLJCQLCyQkCyQLJAsLJAskJAskCyQLCyQLJAskCyQkCyQLAWokCwskJAsLJCQLCyQLJAskJAsLJCQLJAskCwskCyQkCyQLJAsLJAskCyQLJCQLJAsBag=="
# 0x6747c3 = 0110 0111 0100 0111 1100 0011: low_period=0x0b, high_period=0x24, stop_period=0x6a, inverted?N, TX mode=0xe9 315mhz???
command_on: "6QCWACQLCyQLJCQLJAsLJAskCyQkCwskJAskCyQLCyQLJAskCyQLJCQLJAskCyQLCyQLJAFqJAsLJAskJAskCwskCyQLJCQLCyQkCyQLJAsLJAskCyQLJAskJAskCyQLJAsLJAskAWokCwskCyQkCyQLCyQLJAskJAsLJCQLJAskCwskCyQLJAskCyQkCyQLJAskCwskCyQBag=="
# 0x6747cc = 0110 0111 0100 0111 1100 1100: low_period=0x0b, high_period=0x24, stop_period=0x6a, inverted?N, TX mode=0xe9 315mhz???
command_off: "6QCWACQLCyQLJCQLJAsLJAskCyQkCwskJAskCyQLCyQLJAskCyQLJCQLJAsLJAskJAskCwFqJAsLJAskJAskCwskCyQLJCQLCyQkCyQLJAsLJAskCyQLJAskJAskCwskCyQkCyQLAWokCwskCyQkCyQLCyQLJAskJAsLJCQLJAskCwskCyQLJAskCyQkCyQLCyQLJCQLJAsBag=="
# 0x774803 = 0111 0111 0100 1000 0000 0011: low_period=0x0b, high_period=0x24, stop_period=0x6a, inverted?N, TX mode=0xe9 315mhz???
command_on: "6QCWACQLCyQLJAskJAsLJAskCyQkCwskJAskCwskJAskCyQLJAskCyQLJAskCyQLCyQLJAFqJAsLJAskCyQkCwskCyQLJCQLCyQkCyQLCyQkCyQLJAskCyQLJAskCyQLJAsLJAskAWokCwskCyQLJCQLCyQLJAskJAsLJCQLJAsLJCQLJAskCyQLJAskCyQLJAskCwskCyQBag=="
# 0x77480c = 0111 0111 0100 1000 0000 1100: low_period=0x0b, high_period=0x24, stop_period=0x6a, inverted?N, TX mode=0xe9 315mhz???
command_off: "6QCWACQLCyQLJAskJAsLJAskCyQkCwskJAskCwskJAskCyQLJAskCyQLJAsLJAskJAskCwFqJAsLJAskCyQkCwskCyQLJCQLCyQkCyQLCyQkCyQLJAskCyQLJAskCwskCyQkCyQLAWokCwskCyQLJCQLCyQLJAskJAsLJCQLJAsLJCQLJAskCyQLJAskCyQLCyQLJCQLJAsBag=="
# 0x0c4903 = 0000 1100 0100 1001 0000 0011: low_period=0x0b, high_period=0x24, stop_period=0x6a, inverted?N, TX mode=0xe9 315mhz???
command_on: "6QCWACQLJAskCyQLCyQLJCQLJAskCwskJAskCwskJAskCwskJAskCyQLJAskCyQLCyQLJAFqJAskCyQLJAsLJAskJAskCyQLCyQkCyQLCyQkCyQLCyQkCyQLJAskCyQLJAsLJAskAWokCyQLJAskCwskCyQkCyQLJAsLJCQLJAsLJCQLJAsLJCQLJAskCyQLJAskCwskCyQBag=="
# 0x0c490c = 0000 1100 0100 1001 0000 1100: low_period=0x0b, high_period=0x24, stop_period=0x6a, inverted?N, TX mode=0xe9 315mhz???
command_off: "6QCWACQLJAskCyQLCyQLJCQLJAskCwskJAskCwskJAskCwskJAskCyQLJAsLJAskJAskCwFqJAskCyQLJAsLJAskJAskCyQLCyQkCyQLCyQkCyQLCyQkCyQLJAskCwskCyQkCyQLAWokCyQLJAskCwskCyQkCyQLJAsLJCQLJAsLJCQLJAsLJCQLJAskCyQLCyQLJCQLJAsBag=="
# 0x1c4a03 = 0001 1100 0100 1010 0000 0011: low_period=0x0b, high_period=0x24, stop_period=0x6a, inverted?N, TX mode=0xe9 315mhz???
command_on: "6QCWACQLJAskCwskCyQLJCQLJAskCwskJAskCwskJAsLJCQLJAskCyQLJAskCyQLCyQLJAFqJAskCyQLCyQLJAskJAskCyQLCyQkCyQLCyQkCwskJAskCyQLJAskCyQLJAsLJAskAWokCyQLJAsLJAskCyQkCyQLJAsLJCQLJAsLJCQLCyQkCyQLJAskCyQLJAskCwskCyQBag=="
# 0x1c4a0c = 0001 1100 0100 1010 0000 1100: low_period=0x0b, high_period=0x24, stop_period=0x6a, inverted?N, TX mode=0xe9 315mhz???
command_off: "6QCWACQLJAskCwskCyQLJCQLJAskCwskJAskCwskJAsLJCQLJAskCyQLJAsLJAskJAskCwFqJAskCyQLCyQLJAskJAskCyQLCyQkCyQLCyQkCwskJAskCyQLJAskCwskCyQkCyQLAWokCyQLJAsLJAskCyQkCyQLJAsLJCQLJAsLJCQLCyQkCyQLJAskCyQLCyQLJCQLJAsBag=="
# 0x2c4b33 = 0010 1100 0100 1011 0011 0011: low_period=0x0b, high_period=0x24, stop_period=0x6a, inverted?N, TX mode=0xe9 315mhz???
command_on: "6QCWACQLJAsLJCQLCyQLJCQLJAskCwskJAskCwskJAsLJAskJAskCwskCyQkCyQLCyQLJAFqJAskCwskJAsLJAskJAskCyQLCyQkCyQLCyQkCwskCyQkCyQLCyQLJCQLJAsLJAskAWokCyQLCyQkCwskCyQkCyQLJAsLJCQLJAsLJCQLCyQLJCQLJAsLJAskJAskCwskCyQBag=="
# 0x2c4b3c = 0010 1100 0100 1011 0011 1100: low_period=0x0b, high_period=0x24, stop_period=0x6a, inverted?N, TX mode=0xe9 315mhz???
command_off: "6QCWACQLJAsLJCQLCyQLJCQLJAskCwskJAskCwskJAsLJAskJAskCwskCyQLJAskJAskCwFqJAskCwskJAsLJAskJAskCyQLCyQkCyQLCyQkCwskCyQkCyQLCyQLJAskCyQkCyQLAWokCyQLCyQkCwskCyQkCyQLJAsLJCQLJAsLJCQLCyQLJCQLJAsLJAskCyQLJCQLJAsBag=="
# 0x3c4cc3 = 0011 1100 0100 1100 1100 0011: low_period=0x0b, high_period=0x24, stop_period=0x6a, inverted?N, TX mode=0xe9 315mhz???
command_on: "6QCWACQLJAsLJAskCyQLJCQLJAskCwskJAskCwskCyQkCyQLCyQLJCQLJAskCyQLCyQLJAFqJAskCwskCyQLJAskJAskCyQLCyQkCyQLCyQLJCQLJAsLJAskJAskCyQLJAsLJAskAWokCyQLCyQLJAskCyQkCyQLJAsLJCQLJAsLJAskJAskCwskCyQkCyQLJAskCwskCyQBag=="
# 0x3c4ccc = 0011 1100 0100 1100 1100 1100: low_period=0x0b, high_period=0x24, stop_period=0x6a, inverted?N, TX mode=0xe9 315mhz???
command_off: "6QCWACQLJAsLJAskCyQLJCQLJAskCwskJAskCwskCyQkCyQLCyQLJCQLJAsLJAskJAskCwFqJAskCwskCyQLJAskJAskCyQLCyQkCyQLCyQLJCQLJAsLJAskJAskCwskCyQkCyQLAWokCyQLCyQLJAskCyQkCyQLJAsLJCQLJAsLJAskJAskCwskCyQkCyQLCyQLJCQLJAsBag=="
# 0x4c4d03 = 0100 1100 0100 1101 0000 0011: low_period=0x0b, high_period=0x24, stop_period=0x6a, inverted?N, TX mode=0xe9 315mhz???
command_on: "6QCWACQLCyQkCyQLCyQLJCQLJAskCwskJAskCwskCyQkCwskJAskCyQLJAskCyQLCyQLJAFqJAsLJCQLJAsLJAskJAskCyQLCyQkCyQLCyQLJCQLCyQkCyQLJAskCyQLJAsLJAskAWokCwskJAskCwskCyQkCyQLJAsLJCQLJAsLJAskJAsLJCQLJAskCyQLJAskCwskCyQBag=="
# 0x4c4d0c = 0100 1100 0100 1101 0000 1100: low_period=0x0b, high_period=0x24, stop_period=0x6a, inverted?N, TX mode=0xe9 315mhz???
command_off: "6QCWACQLCyQkCyQLCyQLJCQLJAskCwskJAskCwskCyQkCwskJAskCyQLJAsLJAskJAskCwFqJAsLJCQLJAsLJAskJAskCyQLCyQkCyQLCyQLJCQLCyQkCyQLJAskCwskCyQkCyQLAWokCwskJAskCwskCyQkCyQLJAsLJCQLJAsLJAskJAsLJCQLJAskCyQLCyQLJCQLJAsBag=="
# 0x5c4e03 = 0101 1100 0100 1110 0000 0011: low_period=0x0b, high_period=0x24, stop_period=0x6a, inverted?N, TX mode=0xe9 315mhz???
command_on: "6QCWACQLCyQkCwskCyQLJCQLJAskCwskJAskCwskCyQLJCQLJAskCyQLJAskCyQLCyQLJAFqJAsLJCQLCyQLJAskJAskCyQLCyQkCyQLCyQLJAskJAskCyQLJAskCyQLJAsLJAskAWokCwskJAsLJAskCyQkCyQLJAsLJCQLJAsLJAskCyQkCyQLJAskCyQLJAskCwskCyQBag=="
# 0x5c4e0c = 0101 1100 0100 1110 0000 1100: low_period=0x0b, high_period=0x24, stop_period=0x6a, inverted?N, TX mode=0xe9 315mhz???
command_off: "6QCWACQLCyQkCwskCyQLJCQLJAskCwskJAskCwskCyQLJCQLJAskCyQLJAsLJAskJAskCwFqJAsLJCQLCyQLJAskJAskCyQLCyQkCyQLCyQLJAskJAskCyQLJAskCwskCyQkCyQLAWokCwskJAsLJAskCyQkCyQLJAsLJCQLJAsLJAskCyQkCyQLJAskCyQLCyQLJCQLJAsBag=="
# 0x6c4f03 = 0110 1100 0100 1111 0000 0011: low_period=0x0b, high_period=0x24, stop_period=0x6a, inverted?N, TX mode=0xe9 315mhz???
command_on: "6QCWACQLCyQLJCQLCyQLJCQLJAskCwskJAskCwskCyQLJAskJAskCyQLJAskCyQLCyQLJAFqJAsLJAskJAsLJAskJAskCyQLCyQkCyQLCyQLJAskCyQkCyQLJAskCyQLJAsLJAskAWokCwskCyQkCwskCyQkCyQLJAsLJCQLJAsLJAskCyQLJCQLJAskCyQLJAskCwskCyQBag=="
# 0x6c4f0c = 0110 1100 0100 1111 0000 1100: low_period=0x0b, high_period=0x24, stop_period=0x6a, inverted?N, TX mode=0xe9 315mhz???
command_off: "6QCWACQLCyQLJCQLCyQLJCQLJAskCwskJAskCwskCyQLJAskJAskCyQLJAsLJAskJAskCwFqJAsLJAskJAsLJAskJAskCyQLCyQkCyQLCyQLJAskCyQkCyQLJAskCwskCyQkCyQLAWokCwskCyQkCwskCyQkCyQLJAsLJCQLJAsLJAskCyQLJCQLJAskCyQLCyQLJCQLJAsBag=="
# 0x7c4003 = 0111 1100 0100 0000 0000 0011: low_period=0x0b, high_period=0x24, stop_period=0x6a, inverted?N, TX mode=0xe9 315mhz???
command_on: "6QCWACQLCyQLJAskCyQLJCQLJAskCwskJAskCyQLJAskCyQLJAskCyQLJAskCyQLCyQLJAFqJAsLJAskCyQLJAskJAskCyQLCyQkCyQLJAskCyQLJAskCyQLJAskCyQLJAsLJAskAWokCwskCyQLJAskCyQkCyQLJAsLJCQLJAskCyQLJAskCyQLJAskCyQLJAskCwskCyQBag=="
# 0x7c400c = 0111 1100 0100 0000 0000 1100: low_period=0x0b, high_period=0x24, stop_period=0x6a, inverted?N, TX mode=0xe9 315mhz???
command_off: "6QCWACQLCyQLJAskCyQLJCQLJAskCwskJAskCyQLJAskCyQLJAskCyQLJAsLJAskJAskCwFqJAsLJAskCyQLJAskJAskCyQLCyQkCyQLJAskCyQLJAskCyQLJAskCwskCyQkCyQLAWokCwskCyQLJAskCyQkCyQLJAsLJCQLJAskCyQLJAskCyQLJAskCyQLCyQLJCQLJAsBag=="
Additionally, here are some more 433Mhz codes that are based on the scheme used by my eTekCity RF plugs.
# 0x064133 = 0000 0110 0100 0001 0011 0011: low_period=0x06, high_period=0x14, stop_period=0xbf, inverted?Y, TX mode=0xb2 433mhz
command_on: "sgCTAAYUBhQGFAYUBhQUBhQGBhQGFBQGBhQGFAYUBhQGFBQGBhQGFBQGFAYGFAYUFAYUBr8GFAYUBhQGFAYUFAYUBgYUBhQUBgYUBhQGFAYUBhQUBgYUBhQUBhQGBhQGFBQGFAa/BhQGFAYUBhQGFBQGFAYGFAYUFAYGFAYUBhQGFAYUFAYGFAYUFAYUBgYUBhQUBhQGvw=="
# 0x06413c = 0000 0110 0100 0001 0011 1100: low_period=0x06, high_period=0x14, stop_period=0xbf, inverted?Y, TX mode=0xb2 433mhz
command_off: "sgCTAAYUBhQGFAYUBhQUBhQGBhQGFBQGBhQGFAYUBhQGFBQGBhQGFBQGFAYUBhQGBhQGFL8GFAYUBhQGFAYUFAYUBgYUBhQUBgYUBhQGFAYUBhQUBgYUBhQUBhQGFAYUBgYUBhS/BhQGFAYUBhQGFBQGFAYGFAYUFAYGFAYUBhQGFAYUFAYGFAYUFAYUBhQGFAYGFAYUvw=="
# 0x1642c3 = 0001 0110 0100 0010 1100 0011: low_period=0x06, high_period=0x14, stop_period=0xbf, inverted?Y, TX mode=0xb2 433mhz
command_on: "sgCTAAYUBhQGFBQGBhQUBhQGBhQGFBQGBhQGFAYUBhQUBgYUFAYUBgYUBhQGFAYUFAYUBr8GFAYUBhQUBgYUFAYUBgYUBhQUBgYUBhQGFAYUFAYGFBQGFAYGFAYUBhQGFBQGFAa/BhQGFAYUFAYGFBQGFAYGFAYUFAYGFAYUBhQGFBQGBhQUBhQGBhQGFAYUBhQUBhQGvw=="
# 0x1642cc = 0001 0110 0100 0010 1100 1100: low_period=0x06, high_period=0x14, stop_period=0xbf, inverted?Y, TX mode=0xb2 433mhz
command_off: "sgCTAAYUBhQGFBQGBhQUBhQGBhQGFBQGBhQGFAYUBhQUBgYUFAYUBgYUBhQUBhQGBhQGFL8GFAYUBhQUBgYUFAYUBgYUBhQUBgYUBhQGFAYUFAYGFBQGFAYGFAYUFAYUBgYUBhS/BhQGFAYUFAYGFBQGFAYGFAYUFAYGFAYUBhQGFBQGBhQUBhQGBhQGFBQGFAYGFAYUvw=="
# 0x264303 = 0010 0110 0100 0011 0000 0011: low_period=0x06, high_period=0x14, stop_period=0xbf, inverted?Y, TX mode=0xb2 433mhz
command_on: "sgCTAAYUBhQUBgYUBhQUBhQGBhQGFBQGBhQGFAYUBhQUBhQGBhQGFAYUBhQGFAYUFAYUBr8GFAYUFAYGFAYUFAYUBgYUBhQUBgYUBhQGFAYUFAYUBgYUBhQGFAYUBhQGFBQGFAa/BhQGFBQGBhQGFBQGFAYGFAYUFAYGFAYUBhQGFBQGFAYGFAYUBhQGFAYUBhQUBhQGvw=="
# 0x26430c = 0010 0110 0100 0011 0000 1100: low_period=0x06, high_period=0x14, stop_period=0xbf, inverted?Y, TX mode=0xb2 433mhz
command_off: "sgCTAAYUBhQUBgYUBhQUBhQGBhQGFBQGBhQGFAYUBhQUBhQGBhQGFAYUBhQUBhQGBhQGFL8GFAYUFAYGFAYUFAYUBgYUBhQUBgYUBhQGFAYUFAYUBgYUBhQGFAYUFAYUBgYUBhS/BhQGFBQGBhQGFBQGFAYGFAYUFAYGFAYUBhQGFBQGFAYGFAYUBhQGFBQGFAYGFAYUvw=="
# 0x364403 = 0011 0110 0100 0100 0000 0011: low_period=0x06, high_period=0x14, stop_period=0xbf, inverted?Y, TX mode=0xb2 433mhz
command_on: "sgCTAAYUBhQUBhQGBhQUBhQGBhQGFBQGBhQGFAYUFAYGFAYUBhQGFAYUBhQGFAYUFAYUBr8GFAYUFAYUBgYUFAYUBgYUBhQUBgYUBhQGFBQGBhQGFAYUBhQGFAYUBhQGFBQGFAa/BhQGFBQGFAYGFBQGFAYGFAYUFAYGFAYUBhQUBgYUBhQGFAYUBhQGFAYUBhQUBhQGvw=="
# 0x36440c = 0011 0110 0100 0100 0000 1100: low_period=0x06, high_period=0x14, stop_period=0xbf, inverted?Y, TX mode=0xb2 433mhz
command_off: "sgCTAAYUBhQUBhQGBhQUBhQGBhQGFBQGBhQGFAYUFAYGFAYUBhQGFAYUBhQUBhQGBhQGFL8GFAYUFAYUBgYUFAYUBgYUBhQUBgYUBhQGFBQGBhQGFAYUBhQGFAYUFAYUBgYUBhS/BhQGFBQGFAYGFBQGFAYGFAYUFAYGFAYUBhQUBgYUBhQGFAYUBhQGFBQGFAYGFAYUvw=="
# 0x464503 = 0100 0110 0100 0101 0000 0011: low_period=0x06, high_period=0x14, stop_period=0xbf, inverted?Y, TX mode=0xb2 433mhz
command_on: "sgCTAAYUFAYGFAYUBhQUBhQGBhQGFBQGBhQGFAYUFAYGFBQGBhQGFAYUBhQGFAYUFAYUBr8GFBQGBhQGFAYUFAYUBgYUBhQUBgYUBhQGFBQGBhQUBgYUBhQGFAYUBhQGFBQGFAa/BhQUBgYUBhQGFBQGFAYGFAYUFAYGFAYUBhQUBgYUFAYGFAYUBhQGFAYUBhQUBhQGvw=="
# 0x46450c = 0100 0110 0100 0101 0000 1100: low_period=0x06, high_period=0x14, stop_period=0xbf, inverted?Y, TX mode=0xb2 433mhz
command_off: "sgCTAAYUFAYGFAYUBhQUBhQGBhQGFBQGBhQGFAYUFAYGFBQGBhQGFAYUBhQUBhQGBhQGFL8GFBQGBhQGFAYUFAYUBgYUBhQUBgYUBhQGFBQGBhQUBgYUBhQGFAYUFAYUBgYUBhS/BhQUBgYUBhQGFBQGFAYGFAYUFAYGFAYUBhQUBgYUFAYGFAYUBhQGFBQGFAYGFAYUvw=="
# 0x564633 = 0101 0110 0100 0110 0011 0011: low_period=0x06, high_period=0x14, stop_period=0xbf, inverted?Y, TX mode=0xb2 433mhz
command_on: "sgCTAAYUFAYGFBQGBhQUBhQGBhQGFBQGBhQGFAYUFAYUBgYUBhQGFBQGFAYGFAYUFAYUBr8GFBQGBhQUBgYUFAYUBgYUBhQUBgYUBhQGFBQGFAYGFAYUBhQUBhQGBhQGFBQGFAa/BhQUBgYUFAYGFBQGFAYGFAYUFAYGFAYUBhQUBhQGBhQGFAYUFAYUBgYUBhQUBhQGvw=="
# 0x56463c = 0101 0110 0100 0110 0011 1100: low_period=0x06, high_period=0x14, stop_period=0xbf, inverted?Y, TX mode=0xb2 433mhz
command_off: "sgCTAAYUFAYGFBQGBhQUBhQGBhQGFBQGBhQGFAYUFAYUBgYUBhQGFBQGFAYUBhQGBhQGFL8GFBQGBhQUBgYUFAYUBgYUBhQUBgYUBhQGFBQGFAYGFAYUBhQUBhQGFAYUBgYUBhS/BhQUBgYUFAYGFBQGFAYGFAYUFAYGFAYUBhQUBhQGBhQGFAYUFAYUBhQGFAYGFAYUvw=="
# 0x6647c3 = 0110 0110 0100 0111 1100 0011: low_period=0x06, high_period=0x14, stop_period=0xbf, inverted?Y, TX mode=0xb2 433mhz
command_on: "sgCTAAYUFAYUBgYUBhQUBhQGBhQGFBQGBhQGFAYUFAYUBhQGFAYUBgYUBhQGFAYUFAYUBr8GFBQGFAYGFAYUFAYUBgYUBhQUBgYUBhQGFBQGFAYUBhQGFAYGFAYUBhQGFBQGFAa/BhQUBhQGBhQGFBQGFAYGFAYUFAYGFAYUBhQUBhQGFAYUBhQGBhQGFAYUBhQUBhQGvw=="
# 0x6647cc = 0110 0110 0100 0111 1100 1100: low_period=0x06, high_period=0x14, stop_period=0xbf, inverted?Y, TX mode=0xb2 433mhz
command_off: "sgCTAAYUFAYUBgYUBhQUBhQGBhQGFBQGBhQGFAYUFAYUBhQGFAYUBgYUBhQUBhQGBhQGFL8GFBQGFAYGFAYUFAYUBgYUBhQUBgYUBhQGFBQGFAYUBhQGFAYGFAYUFAYUBgYUBhS/BhQUBhQGBhQGFBQGFAYGFAYUFAYGFAYUBhQUBhQGFAYUBhQGBhQGFBQGFAYGFAYUvw=="
# 0x764803 = 0111 0110 0100 1000 0000 0011: low_period=0x06, high_period=0x14, stop_period=0xbf, inverted?Y, TX mode=0xb2 433mhz
command_on: "sgCTAAYUFAYUBhQGBhQUBhQGBhQGFBQGBhQGFBQGBhQGFAYUBhQGFAYUBhQGFAYUFAYUBr8GFBQGFAYUBgYUFAYUBgYUBhQUBgYUBhQUBgYUBhQGFAYUBhQGFAYUBhQGFBQGFAa/BhQUBhQGFAYGFBQGFAYGFAYUFAYGFAYUFAYGFAYUBhQGFAYUBhQGFAYUBhQUBhQGvw=="
# 0x76480c = 0111 0110 0100 1000 0000 1100: low_period=0x06, high_period=0x14, stop_period=0xbf, inverted?Y, TX mode=0xb2 433mhz
command_off: "sgCTAAYUFAYUBhQGBhQUBhQGBhQGFBQGBhQGFBQGBhQGFAYUBhQGFAYUBhQUBhQGBhQGFL8GFBQGFAYUBgYUFAYUBgYUBhQUBgYUBhQUBgYUBhQGFAYUBhQGFAYUFAYUBgYUBhS/BhQUBhQGFAYGFBQGFAYGFAYUFAYGFAYUFAYGFAYUBhQGFAYUBhQGFBQGFAYGFAYUvw=="
# 0x0d4903 = 0000 1101 0100 1001 0000 0011: low_period=0x06, high_period=0x14, stop_period=0xbf, inverted?Y, TX mode=0xb2 433mhz
command_on: "sgCTAAYUBhQGFAYUFAYUBgYUFAYGFBQGBhQGFBQGBhQGFBQGBhQGFAYUBhQGFAYUFAYUBr8GFAYUBhQGFBQGFAYGFBQGBhQUBgYUBhQUBgYUBhQUBgYUBhQGFAYUBhQGFBQGFAa/BhQGFAYUBhQUBhQGBhQUBgYUFAYGFAYUFAYGFAYUFAYGFAYUBhQGFAYUBhQUBhQGvw=="
# 0x0d490c = 0000 1101 0100 1001 0000 1100: low_period=0x06, high_period=0x14, stop_period=0xbf, inverted?Y, TX mode=0xb2 433mhz
command_off: "sgCTAAYUBhQGFAYUFAYUBgYUFAYGFBQGBhQGFBQGBhQGFBQGBhQGFAYUBhQUBhQGBhQGFL8GFAYUBhQGFBQGFAYGFBQGBhQUBgYUBhQUBgYUBhQUBgYUBhQGFAYUFAYUBgYUBhS/BhQGFAYUBhQUBhQGBhQUBgYUFAYGFAYUFAYGFAYUFAYGFAYUBhQGFBQGFAYGFAYUvw=="
# 0x1d4a03 = 0001 1101 0100 1010 0000 0011: low_period=0x06, high_period=0x14, stop_period=0xbf, inverted?Y, TX mode=0xb2 433mhz
command_on: "sgCTAAYUBhQGFBQGFAYUBgYUFAYGFBQGBhQGFBQGBhQUBgYUBhQGFAYUBhQGFAYUFAYUBr8GFAYUBhQUBhQGFAYGFBQGBhQUBgYUBhQUBgYUFAYGFAYUBhQGFAYUBhQGFBQGFAa/BhQGFAYUFAYUBhQGBhQUBgYUFAYGFAYUFAYGFBQGBhQGFAYUBhQGFAYUBhQUBhQGvw=="
# 0x1d4a0c = 0001 1101 0100 1010 0000 1100: low_period=0x06, high_period=0x14, stop_period=0xbf, inverted?Y, TX mode=0xb2 433mhz
command_off: "sgCTAAYUBhQGFBQGFAYUBgYUFAYGFBQGBhQGFBQGBhQUBgYUBhQGFAYUBhQUBhQGBhQGFL8GFAYUBhQUBhQGFAYGFBQGBhQUBgYUBhQUBgYUFAYGFAYUBhQGFAYUFAYUBgYUBhS/BhQGFAYUFAYUBhQGBhQUBgYUFAYGFAYUFAYGFBQGBhQGFAYUBhQGFBQGFAYGFAYUvw=="
# 0x2d4b33 = 0010 1101 0100 1011 0011 0011: low_period=0x06, high_period=0x14, stop_period=0xbf, inverted?Y, TX mode=0xb2 433mhz
command_on: "sgCTAAYUBhQUBgYUFAYUBgYUFAYGFBQGBhQGFBQGBhQUBhQGBhQGFBQGFAYGFAYUFAYUBr8GFAYUFAYGFBQGFAYGFBQGBhQUBgYUBhQUBgYUFAYUBgYUBhQUBhQGBhQGFBQGFAa/BhQGFBQGBhQUBhQGBhQUBgYUFAYGFAYUFAYGFBQGFAYGFAYUFAYUBgYUBhQUBhQGvw=="
# 0x2d4b3c = 0010 1101 0100 1011 0011 1100: low_period=0x06, high_period=0x14, stop_period=0xbf, inverted?Y, TX mode=0xb2 433mhz
command_off: "sgCTAAYUBhQUBgYUFAYUBgYUFAYGFBQGBhQGFBQGBhQUBhQGBhQGFBQGFAYUBhQGBhQGFL8GFAYUFAYGFBQGFAYGFBQGBhQUBgYUBhQUBgYUFAYUBgYUBhQUBhQGFAYUBgYUBhS/BhQGFBQGBhQUBhQGBhQUBgYUFAYGFAYUFAYGFBQGFAYGFAYUFAYUBhQGFAYGFAYUvw=="
# 0x3d4cc3 = 0011 1101 0100 1100 1100 0011: low_period=0x06, high_period=0x14, stop_period=0xbf, inverted?Y, TX mode=0xb2 433mhz
command_on: "sgCTAAYUBhQUBhQGFAYUBgYUFAYGFBQGBhQGFBQGFAYGFAYUFAYUBgYUBhQGFAYUFAYUBr8GFAYUFAYUBhQGFAYGFBQGBhQUBgYUBhQUBhQGBhQGFBQGFAYGFAYUBhQGFBQGFAa/BhQGFBQGFAYUBhQGBhQUBgYUFAYGFAYUFAYUBgYUBhQUBhQGBhQGFAYUBhQUBhQGvw=="
# 0x3d4ccc = 0011 1101 0100 1100 1100 1100: low_period=0x06, high_period=0x14, stop_period=0xbf, inverted?Y, TX mode=0xb2 433mhz
command_off: "sgCTAAYUBhQUBhQGFAYUBgYUFAYGFBQGBhQGFBQGFAYGFAYUFAYUBgYUBhQUBhQGBhQGFL8GFAYUFAYUBhQGFAYGFBQGBhQUBgYUBhQUBhQGBhQGFBQGFAYGFAYUFAYUBgYUBhS/BhQGFBQGFAYUBhQGBhQUBgYUFAYGFAYUFAYUBgYUBhQUBhQGBhQGFBQGFAYGFAYUvw=="
# 0x4d4d03 = 0100 1101 0100 1101 0000 0011: low_period=0x06, high_period=0x14, stop_period=0xbf, inverted?Y, TX mode=0xb2 433mhz
command_on: "sgCTAAYUFAYGFAYUFAYUBgYUFAYGFBQGBhQGFBQGFAYGFBQGBhQGFAYUBhQGFAYUFAYUBr8GFBQGBhQGFBQGFAYGFBQGBhQUBgYUBhQUBhQGBhQUBgYUBhQGFAYUBhQGFBQGFAa/BhQUBgYUBhQUBhQGBhQUBgYUFAYGFAYUFAYUBgYUFAYGFAYUBhQGFAYUBhQUBhQGvw=="
# 0x4d4d0c = 0100 1101 0100 1101 0000 1100: low_period=0x06, high_period=0x14, stop_period=0xbf, inverted?Y, TX mode=0xb2 433mhz
command_off: "sgCTAAYUFAYGFAYUFAYUBgYUFAYGFBQGBhQGFBQGFAYGFBQGBhQGFAYUBhQUBhQGBhQGFL8GFBQGBhQGFBQGFAYGFBQGBhQUBgYUBhQUBhQGBhQUBgYUBhQGFAYUFAYUBgYUBhS/BhQUBgYUBhQUBhQGBhQUBgYUFAYGFAYUFAYUBgYUFAYGFAYUBhQGFBQGFAYGFAYUvw=="
# 0x5d4e03 = 0101 1101 0100 1110 0000 0011: low_period=0x06, high_period=0x14, stop_period=0xbf, inverted?Y, TX mode=0xb2 433mhz
command_on: "sgCTAAYUFAYGFBQGFAYUBgYUFAYGFBQGBhQGFBQGFAYUBgYUBhQGFAYUBhQGFAYUFAYUBr8GFBQGBhQUBhQGFAYGFBQGBhQUBgYUBhQUBhQGFAYGFAYUBhQGFAYUBhQGFBQGFAa/BhQUBgYUFAYUBhQGBhQUBgYUFAYGFAYUFAYUBhQGBhQGFAYUBhQGFAYUBhQUBhQGvw=="
# 0x5d4e0c = 0101 1101 0100 1110 0000 1100: low_period=0x06, high_period=0x14, stop_period=0xbf, inverted?Y, TX mode=0xb2 433mhz
command_off: "sgCTAAYUFAYGFBQGFAYUBgYUFAYGFBQGBhQGFBQGFAYUBgYUBhQGFAYUBhQUBhQGBhQGFL8GFBQGBhQUBhQGFAYGFBQGBhQUBgYUBhQUBhQGFAYGFAYUBhQGFAYUFAYUBgYUBhS/BhQUBgYUFAYUBhQGBhQUBgYUFAYGFAYUFAYUBhQGBhQGFAYUBhQGFBQGFAYGFAYUvw=="
# 0x6d4f03 = 0110 1101 0100 1111 0000 0011: low_period=0x06, high_period=0x14, stop_period=0xbf, inverted?Y, TX mode=0xb2 433mhz
command_on: "sgCTAAYUFAYUBgYUFAYUBgYUFAYGFBQGBhQGFBQGFAYUBhQGBhQGFAYUBhQGFAYUFAYUBr8GFBQGFAYGFBQGFAYGFBQGBhQUBgYUBhQUBhQGFAYUBgYUBhQGFAYUBhQGFBQGFAa/BhQUBhQGBhQUBhQGBhQUBgYUFAYGFAYUFAYUBhQGFAYGFAYUBhQGFAYUBhQUBhQGvw=="
# 0x6d4f0c = 0110 1101 0100 1111 0000 1100: low_period=0x06, high_period=0x14, stop_period=0xbf, inverted?Y, TX mode=0xb2 433mhz
command_off: "sgCTAAYUFAYUBgYUFAYUBgYUFAYGFBQGBhQGFBQGFAYUBhQGBhQGFAYUBhQUBhQGBhQGFL8GFBQGFAYGFBQGFAYGFBQGBhQUBgYUBhQUBhQGFAYUBgYUBhQGFAYUFAYUBgYUBhS/BhQUBhQGBhQUBhQGBhQUBgYUFAYGFAYUFAYUBhQGFAYGFAYUBhQGFBQGFAYGFAYUvw=="
# 0x7d4003 = 0111 1101 0100 0000 0000 0011: low_period=0x06, high_period=0x14, stop_period=0xbf, inverted?Y, TX mode=0xb2 433mhz
command_on: "sgCTAAYUFAYUBhQGFAYUBgYUFAYGFBQGBhQGFAYUBhQGFAYUBhQGFAYUBhQGFAYUFAYUBr8GFBQGFAYUBhQGFAYGFBQGBhQUBgYUBhQGFAYUBhQGFAYUBhQGFAYUBhQGFBQGFAa/BhQUBhQGFAYUBhQGBhQUBgYUFAYGFAYUBhQGFAYUBhQGFAYUBhQGFAYUBhQUBhQGvw=="
# 0x7d400c = 0111 1101 0100 0000 0000 1100: low_period=0x06, high_period=0x14, stop_period=0xbf, inverted?Y, TX mode=0xb2 433mhz
command_off: "sgCTAAYUFAYUBhQGFAYUBgYUFAYGFBQGBhQGFAYUBhQGFAYUBhQGFAYUBhQUBhQGBhQGFL8GFBQGFAYUBhQGFAYGFBQGBhQUBgYUBhQGFAYUBhQGFAYUBhQGFAYUFAYUBgYUBhS/BhQUBhQGFAYUBhQGBhQUBgYUFAYGFAYUBhQGFAYUBhQGFAYUBhQGFBQGFAYGFAYUvw=="
Cheers!
