you are welcome!
im going to order 10 switches now without remotes!!!
you are welcome!
you can get one here, for only 6$:
thanx, but i have already some sesoo switches, i want it to be the same
Nice one! Just a heads up: it works with IR codes as well! I could paste an IR code and change the repeat of it. Works great!
yup, no reason it wont, same broadlink protocol
I just got my RM pro and now waiting for a sonoff rf relay with no remote control with the intention to use similar codes mentioned in this post. I downloaded rm pluggin lite and can see the rm pro existing codes but not sure:
1 if the above codes will work with the sonoff rf relays
2 if they should work i am not familiar with the process … shall i just paste the codes on rm pluggin lite? How will these be assigned to the key / shortcut on e control?
Sorry for what it seems to be a very basic question but once reading the post this got me very intrestred and would like to have a go at this …
I have config my emylo’s with your generator, but in latched mode the switch don’t turn off. Please add the possibility to generator on and off code (0xe and 0xd) for emylo in latch mode. Thanks
im am not familiar with emylo, but if you will provide some info and test with me, i think ill be able to do that pretty fast
Thanks this is wonderful
The emylo only needs programming with the ‘on’ code as any code with the right channel ID, other than the ‘on’ code will turn the relay off. ID 0xE (example 0x23726e) run on and ID 0xB (example 0x23726b) run off.
Hi @dimagoltsman or anyone else with the knowhow, would it be possible to add a random generator for Nexa switches? They are quite ubiquitous here in scandinavia, but I couldn’t get the codes from your generator working on them and this is beyond my current skill level.
Old info about Nexa protocol from telldus. Maybe still relevant?
I’ve got codes dumped from e-control that work for both teaching (repeatedly clicking swith so rm pro keeps sending the command) and controlling via home-assistant → rm-pro.
rf_1 turns all switches on/off rf_2 through rf_4 control individual switches.
rf_4 turn_off worked once, but when I reprogrammed the switch, it hasn’t worked again.
rf_1:
friendly_name: "rf_1"
command_on: "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"
command_off: "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"
rf_2:
friendly_name: "rf_2"
command_on: "sgCeAgpbCQkKLAkJCiwKKwoJCgkKLAkJCiwJCQosCisKCQorCgoJCQosCSwKCQoJCisKCQosCQkKLAoJCSwKLAkJCgkKLAoJCSwKCQosCQkKLAoICiwKKwoJCgkKLAkJCiwJCgksCiwJCgkKCSwKCQksCiwJCQoJCisKCQosCQkKLAoJCSwKAAFcCloKCQosCQkKLAksCgkKCQksCgkKLAkJCiwKKwoJCisKCgkJCiwKKwoJCgkKLAkJCiwKCAosCQoJLAorCgoJCQosCgkJLAoJCiwJCQosCQoJLAorCgkKCQosCQkKLAkJCiwKLAkKCQkKLAoICiwKKwoJCgkKLAkJCiwJCQosCgkKKwoAAVwKWgoJCiwJCQosCisJCgoJCSwKCQorCgkKLAorCgkKKwoKCQkKLAksCgkKCQksCgkKLAkJCiwKCQksCisKCQoJCiwKCQorCgkKKwoJCiwKCAosCSwKCgkJCSwKCQosCQkKLAosCQoJCQosCQoJLAorCgkKCQorCgkKLAkJCiwKCQksCQABXQlbCgkKKwoJCiwJLAoJCgkKKwoJCiwJCQorCiwKCQorCgoJCQosCSwKCQoJCisKCQksCgkKLAkJCiwKKwoJCgkKLAoJCSwKCQksCgkKLAkJCiwKKwoJCgkJLAoJCiwJCQotCSsKCgkJCiwJCQosCisKCQoJCisKCQosCQkKLAoJCisJAAFdCVsKCQorCgkKLAksCQoKCQksCgkKLAkJCiwJLAoJCisKCgoICiwKKwoJCgkKKwoJCisKCQosCgkJLAorCgkKCQosCgkKKwoJCiwJCQosCQkKLAksCgkKCQosCQkKLAkJCiwKLAkKCQkKLAkKCSwKKwoJCgkKLAkJCiwKCAosCgkKKwkABdwAAAAAAAAAAAAA"
command_off: "sQCeAglbCQkKLAoJCSwKKwoKCQoJLAkJCiwJCgktCSsKCQosCQoKCQksCisKCgkJCiwJCQosCQoJLAoJCSwKLAkKCQkKLAoJCSwKCQosCQkKLAoJCSwJLAoJCgkKLAkJCiwJCgktCSwJCgkJCiwJCgksCgkJLQkJCiwJCQosCQoJLAkKCSwJAAFdCVsKCQksCgkKLAksCgkJCgksCgkJLQkJCisKLAkKCSwJCwkJCiwJLAkKCgkJLAoJCSwKCQosCQkKLAorCgkJCgktCQoJLAkKCSwKCQktCQkKLAksCgkKCQksCgkJLQkJCiwKKwoKCQkKKwoJCiwJCQosCgkJLQkJCiwJCQosCQkKLAkAAV0JWwoJCS0JCQktCSwJCgkKCSwKCQksCgkKLAksCgkJLAkLCQkKLAksCgkJCgksCgkJLQkJCS0JCQosCisKCQoJCS0JCgksCQoJLAoJCiwJCQosCisKCQkKCS0JCQosCQkKLAosCQoJCQosCggKLAoJCSwKCQksCgkKLAkKCSwKCQksCQABXQpaCgkKLAkJCiwJLAoJCgkJLQkJCS0JCQosCSwKCQorCgoJCQosCisKCQoJCS0JCQosCQkKLAoJCSwKKwoKCQkKLAoJCSwKCQosCQkKLAkKCSwKLAkJCgkKLAkJCiwJCgktCSwJCgoICiwKCQksCgkKKwoJCiwJCgksCgkJLAoJCisKAAFcClsKCAosCgkJLAosCQoJCQosCQkKLAoJCSwKKwoKCSwKCQoJCS0JLAoJCQkKLAoJCSwKCQorCgkKLAksCgkKCQktCQkKLAoJCSwKCQksCgkKLAorCgkKCQksCgkJLAoJCiwKLAkJCgkKKwoJCiwKCAosCgkJLAoJCiwJCQosCQoJLAkABdwAAAAAAAAAAAAA"
rf_3:
friendly_name: "rf_3"
command_on: "sgCeAgpaCgkKKwoJCiwKKwoJCggKLAoJCiwJCQosCisKCQorCgoJCQosCisKCQoJCisKCQosCgkJLAoJCisKLAoJCggKLAoJCiwKCAosCggKLAoJCisKLAoJCggKLAoICysKCQosCisKCQoJCisKCQosCSwKCQoJCisKCQosCQkKLAorCgkJAAFdCloKCQosCggKLAorCgkKCQorCgkKLAoICiwKKwoJCisLCQoJCSwKKwsICgkKLAoICiwKCQksCgkKKwosCgkKCQosCQkKLAoJCisKCQorCgkKLAorCgkKCQksCgkKKwoJCiwKLAkJCgkKLAoJCisKKwoKCQkKLAkJCiwKCQorCiwJCQoAAV0JWwoJCSwKCQorCiwJCgoICiwKCQksCgkKLAksCgkKKwoKCggKLAorCgkKCQorCgkKLAoICiwKCQksCisKCQsICiwKCQosCggKLAoICiwKCQorCiwJCgoICiwKCQksCgkKLAorCgkKCQorCgkKLAorCgkKCQorCgkKLAoICiwKKwoJCgABXApaCgkKLAoICiwKKwoJCgkKLAoICiwKCQorCisKCQosCgkKCQorCiwKCQoICiwKCQksCgkKKwsICiwKKwoJCgkKLAoICysKCQorCgkKLAkJCiwKKwoJCgkKKwsICiwKCAsrCiwKCQoICiwKCQorCisLCQoICiwKCAosCgkKKwosCgkJAAFdCVsKCQorCgkKKwosCgkKCAosCgkJLAoJCiwJLAoJCisKCQsICiwKKwoJCgkKKwoJCiwJCQosCggLKworCgkLCAosCgkKKwoJCiwKCAosCgkJLAorCwgKCQosCggLKwoJCiwKKwoJCgkKKwoKCSwKKwoJCgkKKwoJCiwJCQosCisKCQoABdwAAAAAAAAAAAAA"
command_off: "sgCeAglbCgkJLQkJCiwJLAoJCgkJLAoJCiwJCQosCSwKCQorCgoJCQosCisKCQoJCisKCQosCQoJLAoJCSwKLAkKCQkKLAoJCiwJCQosCgkJLAoJCiwJLAkKCggKLAkKCSwKCQktCisKCQoJCisKCQosCggKLAoJCisKCQorCgkKLAorCgkJAAFdCVsKCQorCgkKLAorCgkJCgksCgkKLAkJCiwJLAoJCisKCgkJCiwKKwoJCgkKKwsICiwKCQksCgkKKworCgoKCAotCQkKLAoICiwKCAosCgkKLAksCQoKCQksCgkJLAoJCiwKKwoJCgkKLAoICiwKCAosCgkJLAoJCiwKCAosCisKCQoAAVwKWgoJCiwKCAosCisKCQoJCiwJCQosCgkJLAorCgkKLAkKCgkKKwosCQoKCAosCgkKKwoJCisKCQosCSwKCQoJCS0KCQksCgkJLAoJCiwJCQosCisKCQoJCisKCQosCggKLAosCgkKCQksCggKLAoJCisKCQosCgkJLAoJCisKLAkJCgABXApbCgkJLAoJCisKLAoJCgkJLAoJCSwKCQorCiwKCQorCgkKCQosCisKCQoJCSwKCQosCQkKLAoICiwKLAkKCQoJLAoJCisKCQosCQoJLAoJCSwKLAoICgkKLAoJCisKCQosCisKCQoJCisKCQosCggKLAoJCisKCQorCgkKLAorCgkJAAFdCloKCQosCQkKLAorCgkKCQorCgkKLAoICiwKKwoJCisKCgoJCSwKLAkJCgkKLAoJCSwKCQorCgkKLAksCgkKCQosCggKLAoICysKCQorCgkKLAorCgkKCQksCgkKKwoJCiwKLAkJCgkKLAoICiwKCQorCgkKLAkJCiwKCQorCisKCQoABdwAAAAAAAAAAAAA"
rf_4:
friendly_name: "rf_4"
command_on: "sgCeAgpaCgkKLAkJCiwKKwoJCgkKLAkJCiwJCQosCisKCQosCQoKCQksCiwJCgkJCiwJCgksCgkKLAkJCiwJLAkKCQoJLQkJCiwKCAosCgkJLAoJCiwJLAoJCgkJLAoJCS0JCQosCisKCgkJCiwKCAosCSwKCQoJCiwJCQosCSwKCQoJCSwJAAFdCloKCQosCQoJLAorCgkKCQosCQkKLAkKCSwKKwoJCiwJCgoJCS0JLAoJCQkKLAkKCSwKCQosCQkKLAksCgkKCQktCggKLAoJCSwKCQosCQkKLAksCgkKCQksCgkKLAkKCSwKLAkKCQkKLAkKCSwKLAkJCgkKLAoICiwJLAoJCgkKKwoAAV0JWwkKCSwKCQksCiwJCgkJCiwKCQksCgkJLQksCQoJLAkKCgkKLAksCgkKCQksCgkKLAkJCiwJCgksCisKCQoJCiwJCgksCgkKLAoICiwKCQksCiwJCgkJCiwJCgksCgkJLQorCgkKCQksCgkJLQksCgkKCQksCgkKKwosCgkJCgksCQABXQlbCgkJLQkJCiwKKwoJCgkJLAoJCiwJCQosCisKCQosCQoKCQksCiwJCgkKCSwKCAosCgkJLQkJCiwJLAoJCgkKLAkJCiwKCQksCgkKLAkJCiwKKwoJCgkKLAkJCiwJCQotCSwJCgkKCSwKCQosCSwJCgkJCiwKCQksCiwJCQoJCiwJAAFdCVsKCQorCgkKLAksCQoJCgksCgkKKwoJCiwJLAoJCisKCgkJCiwKKwoJCgkKLAkJCiwKCQksCgkKLAksCgkJCgksCgkKLAkJCiwKCQksCgkKLAorCgkJCgksCgkKKwoJCiwKKwoJCgkKLAkKCSwKLAkJCgkKLAkKCSwKKwoJCgkKKwoABdwAAAAAAAAAAAAA"
command_off: "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"
And while we are on the subject, could this generator-teaching thing be integrated into home-assistant as an addon?
In any case, great work so far! I’ve been reading this forum a few days and this seems like a good community.
That would be hard since i dont have this kind of device…
Hi I´ve tried to use the RF 315Mhz codes from the generator with my sonoff touch t1 us, but it didn´t work
Does someone successfully accomplished this sonoff touch t1 us?
thanks!
I have this code with rm plugin but I can´t decode to HA.
b2001a03a81312080514120805140613061313071208051412070613061406131208120706141207120805141207061412071208120712080514061306131307120812071208051405140613061405140515051313070614051406130613061405140613061405141307051405140613061412071307120713071207130705140613061405141209a71312080514120706140613061313071208051412070614051406131307120706141207120805141207061313071307120713070613061405141207130712071307051406130614051406130614051412070614061306130614051406130614051406141207051406140514061313071207130712071307120706140513071306131308a71412070613130706130614051412071307061313070514061306141207120805141208120706131307051412081207120713070614051406131306130712081207061306140613061306140514061313070613061405140613061306140613061306141207061405140613061412071306130713071207120707130613061406131208a81313070514120706140514061313071207061412070613061406131307120706131307120707131207061412071207130712080514061306131307120713071208061306130613061406130613061412070614061306130614051406130613061406131307061306130614061312071307130712071307120706130614061306131308a71313070613130706130613061412071307061313070613061306131307120805141207130706131307061313071207130613070613061406131208120713061307061306140613061306140514061313070613061306140613061306140613061405141207061405140613061313071307120713071207130706130613061405141208a8131208051313070614051406131306130706141207061306140514120713070613130712080514120706141207120812071307051406130613130713071207130606140613071206140514061306141207061405140613061405140613061306140613130706130613061405141207130713071207120713070613061406130613130005dc0000000000000000000000000000
¿Anybody can help me?
Thanks in advance.
I have similar problem with IR codes. I have Andoid mini pc MECOOL and on this I have TV app Horizon. I use Broadlink RM Pro and app RM plugin lite. So I am able to send recorded codes with Alexa. I have small remote control from AliExpress but with this remote I can send only few numbers. Not all. My problem is, that i can not figured out, how to simulate all my numbers. I attach code, which send my working number 3. Is it possible to define base this code the other which I miss? thx
@dimagoltsman Thank so much for your work creating the RF code generator.
I notice that the codes I am capturing on HA from my 433MHz RF garage door openers are much longer than the ones that are created by your tool. When I try to replace one of my captured codes with one of yours and use the Remote: Send Command call service from within HA it fails with “unknown error”.
I think I am probably being incredibly dumb but is there any reason why HA would refuse to use a code generated from your tool? Example below where the last code uses one of the shorter ones generated from your tool
"version": 1,
"key": "broadlink_remote_a043b0b8fc83_codes",
"data": {
"main_gate2": {
"on": "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"
"garage_door_left2": {
"on": "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"
"garage_door_right2": {
"on": "scBuBIieBgAvDiAdEA4fHRAOHw4fHRAPHg8eDx4PHh4PHg8PHhAeHg4fDw8eDx4PHg8eDx4fDgABABAOHw4fHRAOHx4PDx4PHh4PDx4PHg8eDx4fDh4QDx4PHh4PHg8PHg8eDx4PHhAdHw//Dw8fDh8dEA4fHg8PHg8eHg8PHg8fDyANHh4PHg8PHg8eHg8eDw8eDx8PHg8eDx4eD/8QDx4PHh4PDx4eDw8eDx4eEA4fDx4PHg8eHg8eDw8eDx4fDh8PDx4PHg8eDx4PHh4PAAEADw8eDx4eDw8fHRAPHg8eHg8PHg8eDx4QHR8PHg8PHg8eHg8eDw8eDx4QHg8dEB4eD/8QDx4PHh4PDx4eDw8eDx4eDw8fDx4PHg8eHg8eDw8eDx4eDx8PDh8PHg8eDx4PHh4PAAEADw8eDx4eDw8eHhAOHw8eHg8PHg8eDx4PHh4PHg8PHw8eHg8eDw8eDx4PHg8eEB0fD/8PDx8OHx4PDx4eDw8eDx4eDw8eDx8OHw8eHg8eDw8eDx4eDx4PDx4PHw8eDx4PHh4PAAEADw8fDh4eDw8eHg8PHw4fHg8PHg8eDx4PHh4PHg8PHw8eHg8eDw8eDx4PHg8eEB0fDgABAA8PHw4fHRAOHx4PDx4PHh4PDx4PHw4fDx4eDx4PDx4PHh4PHhAOHhAeDx4PHg8eHg8AAQAPDx4PHh4PDx4eEA4eDx8eDw8eDx4PHg8eHg8eEA8eDx4eDx4PDx4PHg8eDx4PHx4P/w8PHg8fHRAPHh4PDx4PHh4PDx4PHhAdEB4eDx4PDx4PHh4PHg8PHg8eEB0QHg8eHg8AAQAPDx4PHh4PDx4eDw8eDx4eEA4eEB4PHg8eHg8eDw8eDx4eDx4QDx4PHg8eDx4PHh4PAAEADw8eDx4eDw8eHg8PHw4fHRAPHg8eDx4PHh4PHg8PHg8eHhAeDw8eDx4PHg8eDx4eDwABAA8PHg8eHg8PHh4QDh8PHh4PDx4PHg8eDx4eDx8OEB4PHh4PHg8PHg8eDx4PHhAdHw4AAQAPDx8OHx4PDx4eDw8eDx4eDw8eDx4PHw8eIQweDw8eDx4eDx4PDx4PHg8eEB0QHh4P/xAOHw4fHg8OHx4PDx4PHh4PDx4PHw8dEB0fDx4PDx4PHh4PHg8PHg8fDx4PHg8eHg//EA8eDx4eDw8eHg8PHg8eHg8PHw8eDx4PHh4PHg8PHg8eHg8fDw8eDx4PHg8eDx4eDwABAA8PHg8eHg8PHx0QDh8OHx4PDx4PHg8eDx4eDx4PDx4QHh4PHg8PHg8eDx4PHg8eHg8AAQAPDx4PHh4QDh8dEA8eDx4eDw8eDx4PHg8eHg8eDxAeDx4eDx4PDx4PHg8eDx4PHh8P/w8PHg8fHRAPHh4PDx4PHh4PDx4PHhAeDx4eDx4PDx4PHh4PHhAOHw8eDx4PHg8eHg8AAQAPDx4PHh4PDx4eDw8fDh8eDw8eDx4PHg8eHg8eEA4eEB4eDx4PDx4PHg8eDx4QHh4P/w8PHwAF3A=="
"garage_door_right_new": {
"on": "sgCoAAsjJAwLJAsjDAABZyMNIwwLJAsjDCMjDSMMCyQjDAskCyQjDAskCyQLIyMMDCMMIwskIwwMIyMMDCMLJAsAAWgjDCMNCyMMIwwjIwwjDQskIwwLJAsjJAwLJAskCyMkCwwjDCMMIyMMDCMjDAwkCyMLAAFpIgwkDAskCyMMIyMNIwwMIyMMDCMLJCMMDCMMIwskIwwMIwwjCyQjDAskIwwMIwwjCwAF3A=="
Have you been able to fix this?
Would you mind sharing your garage door motor?
I am looking for one with 433 MHz.
Thank you.
