How to generate json data from template?
I have an automation:
- alias: mqtt_ha_start
    platform: homeassistant
    event: start
    service: mqtt.publish
      topic: homeassistant/scenes/test_room/list
      retain: true
      payload_template: "{{ state_attr('input_select.test_room','options') }}"
I would like to generate json data in payload_template. Is there any way to do it?
You could try the tojson filter.
payload_template: "{{ state_attr('input_select.test_room','options')|tojson }}"
Unfortunately tojson is not available. Tried in template Developer Tools:
Error rendering template: UndefinedError: ‘tojson’ is undefined
Try again. It’s a filter, not a function. I just tried it and it works fine.
I just tried Phil’s template and though I had to adjust it for an input_select that exists on my system it worked as advertised, generating : - “[“Day”, “Evening”, “Night”]”
Yes, it worked. I tried it as a function before. Many thanks!
