How to get a list filtering another list in a template?
I am trying to build an automation that sends me a notification if any of the entities inside a group of temperature sensors is above a given value.
First I am trying to build the template for it but I just can find how to create a new list from my filtered values.
Given this
{% set temp_sensors =  expand('sensor.home_inside_temperature_sensors') | map(attribute='entity_id') | list %}
{% set max_temp = 1 %}
{{ temp_sensors |   list }}
{% set filtered_list = [] %}
{% for item in temp_sensors %}
  {% if (states(item) | float) > 16 %}
    "{{states(item)}}"
    {% set filtered_list = filtered_list + [item] %}
  {% endif %}
{% endfor %}
{{filtered_list}}
I get this output
['sensor.2_hobbyraum_keller_temperature',
'sensor.1_abstellraum_keller_temperature',
'sensor.3_technikraum_keller_temperature',
'sensor.room_temperature',
'sensor.switchbot_temp_sala']
    "19.6"
    "20.5"
    "19.2"
    "21.6"
    "22.0"
As you see the filtering is working correctly but {% set filtered_list = filtered_list + [item] %} is not working.
I also tried with {% set _ = filtered_list.append(item) %} but it is rejected.
I can not wrap y head around how to do this.
I would be grateful for any tip!
Thanks!
{% set entities = state_attr('sensor.home_inside_temperature_sensors', 'entity_id') %}
{% set values = entities | map('states') | map('float',0) | list %}
{% set z = zip(entities, values) | selectattr(1, 'gt', 16) | list %}
{{ z | map(attribute=0) | list }}
The result is a list containing the entity_id of all sensors (who are members of sensor.home_inside_temperature_sensors) whose state value is greater than 16.
Let me know if you need help to modify it to meet any other requirements you have.
NOTE
The reason why filtered_list fails to report anything is because of Jinja2’s scope rules. When you change a variable’s value inside a Jinja2 for-loop, that value remains local to the for-loop. In other words, that value doesn’t exist outside of the for-loop.
You would need to use namespace to ensure the variable’s value is preserved outside the for-loop.
{% set ns = namespace(filtered_list = []) %}
    {% set ns.filtered = ns.filtered_list + [item] %}
  {% endif %}
{% endfor %}
{{ ns.filtered_list }}
Or like this:
{% for item in temp_sensors if (states(item) | float) > 16 %}
{% endfor %}
Or you can forego the use of a for-loop and use zip as shown in my example.
Wouldn’t you want the select('has_value') on entities… otherwise you might get deletion errors when zipping.
Thanks for bringing it to my attention.
For simplicity, I removed it and will let float(0) take care of non-nominal values.
WOW! thanks I am pretty sure I would not arrive to that solution without expending some weeks on the process.
Thanks a lot!
