How to get all my calendar entries
Hi all
I’m trying to make a helper list of all the calendar evens I have in some calendars so that I can use that to trigger automations. But I’m not getting the list and not sure where I’m going wrong. Any help would be appreciated.
alias: Schedule - Calendar events for the day
description: >-
  Gets a list of events that are on the calendars and can be used in other
  automations
triggers:
  - trigger: time
    at: "00:01:00"
conditions: []
actions:
  - action: calendar.get_events
      entity_id:
        - calendar.calendar1
        - calendar.calendar2
    response_variable: calendar_events
  - action: input_text.set_value
      value: "{{ calendar_events | map(attribute='summary') | join(', ') }}"
      entity_id: input_text.helper_calendar_events_for_the_day
mode: single
Input text can only hold 255 characters.
Could that be the issue?
There’s not that many events, but I suppose characters can fill up quickly. I’ll check.
Would it not fill in the first 255 characters still?
No not the way you set it up.
It will break
OK, thanks. I checked though and there are less than 30 characters in events, so that is not the problem :frowning:
Your variable calendar_events does not contain anything with a summary attribute. It contains a dictionary whose keys are the entity IDs of your calendars. Those entity ID strings don’t have a “summary” attributes.
You might be better off setting this up as a Trigger-based template sensor and storing the list of events in an attribute.
Regarding Hellis81’s comment about state length… if you really want to store the list in a state, make sure to use the truncate() filter to cutoff the returned value at 254 characters.
Thanks, I’ll have a look at that. I don’t specifically want to store as a state. I just want anyway I can get my calendar events and use the results in automation conditions. I’m still n00b so trying to figure out and learn as I go along.
