Watcher1
(John)
April 21, 2023, 7:31am
1
This topic appears lots of times but i wasnt able to get mine working.
- state_topic: "sensor/InverterMode"
state_class: measurement
device_class: enum
value_template: >-
{% if sensor.inverter_mode=="0" %} On Grid
{% elif sensor.inverter_mode=="3" %} Standby
{% endif %}
InverterMode comes via MQTT from my solar inverter and I need to convert the number to Text.
However the result is “unknown”
What am i doing wrong?
Try this:
device_class: enum
value_template: >-
{% if states('sensor.inverter_mode')=="0" %} On Grid
{% elif states('sensor.inverter_mode')=="3" %} Standby
{% endif %}
You might need an else in case it is not 0 or 3, change xxxxxx for whatever:
device_class: enum
value_template: >-
{% else %} xxxxxxx
{% endif %}
Watcher1
(John)
April 21, 2023, 9:13am
3
Holdestmade:
{% else %}
Thanks for your reply!
I used the following which covers all possible states according to the manual
#device_class: enum
value_template: >-
{% if states('sensor.inverter_mode')=="0" %} Initial
{% elif states('sensor.inverter_mode')=="3" %} On Grid
{% elif states('sensor.inverter_mode')=="1" %} Standby
{% elif states('sensor.inverter_mode')=="4" %} Off Grid
{% elif states('sensor.inverter_mode')=="5" %} Fault
{% elif states('sensor.inverter_mode')=="9" %} Shutdown
{% else %} undefined
{% endif %}
However instead of the option 3 - ‘On Grid’ which is the correct state , I get ‘undefined’ which means that none of the If statements is valid. So there is something wrong with the comparison…
If you paste
{{ states('sensor.inverter_mode') }}
in the template editor what do you get ?
Is the Result type a string or number ?
Also, not sure you need the state_class: measurement
as the output of the sensor will be a string
Watcher1
(John)
April 21, 2023, 12:26pm
5
Its a string. It also says undefined
Troon
(Troon)
April 21, 2023, 12:32pm
6
That’s because you’ve made a circular reference: the template is looking at the state of the sensor you’re trying to update! You should be using value
in the template to refer to the MQTT topic contents, assuming that topic contains just a single number:
value_template: >-
{% if value == "0" %} Initial
{% elif value == "3" %} On Grid
{% elif value == "1" %} Standby
{% elif value == "4" %} Off Grid
{% elif value == "5" %} Fault
{% elif value == "9" %} Shutdown
{% endif %}
Well spotted, I assumed it was a template sensor…
123
(Taras)
April 21, 2023, 12:54pm
8
value_template: >
{{ {'0': 'Initial', '1': 'Standby',
'3': 'On Grid', '4': 'Off Grid',
'5': 'Fault', '9': 'Shutdown'}.get(value, 'undefined') }}
Watcher1
(John)
April 21, 2023, 5:21pm
9
That worked! Thanks very much for your help!
Hi again…
Had to return to the same topic as my setup stopped working after system core updated to the latest version couple of days ago.
The value_template shown above now gives “unknown” ! Any ideas what changed?
Troon
(Troon)
May 5, 2023, 4:11pm
11
Please paste the complete sensor configuration as you now have it, plus the MQTT message for that topic, plus any relevant log entries.
As a random guess based on other topics, have you inserted a unit_of_measurement
into the sensor?
Hmm no! There is no unit of measurement…
This is what I have :
#device_class: enum
value_template: >-
{% if value=="0" %} Initial
{% elif value=="3" %} On Grid
{% elif value=="1" %} Standby
{% elif value=="4" %} Off Grid
{% elif value=="5" %} Fault
{% elif value=="9" %} Shutdown
{% endif %}
EDIT: Just tried to un-comment device_class: enum and it worked again!
