How to get DSMR output into HA
Hello team,
I found two integrations
    • DSMR Slimme Meter - Home Assistant
      in the HA integration section.
      Furthermore I do have an Wemos configured according P1 Smart Meter - Tasmota and it is producing the MQTT messages below with the topic tele/tasmota82/RESULT .
      How would I need to configure either integration in order to get the DSMR information into HA ?
      I have noticed in DSMR Reader - Home Assistant there talk about a sensor_dsmr_<mqtt_topic> but what should I do with it?
Many thanks, Yann
`tele/tasmota82/RESULT {“SerialReceived”:"/Ene5\T210-D ESMR5.0
1-3:0.2.8(50)
0-0:1.0.0(210603115315S)
0-0:96.1.1(4530303438303030303339333836383139)
1-0:1.8.1(002511.598kWh)
1-0:1.8.2(002814.463
kWh)
1-0:2.8.1(000000.088kWh)
1-0:2.8.2(000000.000
kWh)
0-0:96.14.0(0002)
1-0:1.7.0(00.299kW)
1-0:2.7.0(00.000
kW)
0-0:96.7.21(00022)
0-0:96.7.9(00006)
1-0:99.97.0(1)(0-0:96.7.19)(210322030858W)(0000002791s)
1-0:32.32.0(00003)
1-0:52.32.0(00003)
1-0:72.32.0(00003)
1-0:32.36.0(00000)
1-0:52.36.0(00000)
1-0:72.36.0(00000)
0-0:96.13.0()
1-0"}
tele/tasmota82/RESULT {“SerialReceived”:"32.7.0(235.0
V)
1-0:52.7.0(234.0V)
1-0:72.7.0(233.0
V)
1-0:31.7.0(000A)
1-0:51.7.0(000
A)
1-0:71.7.0(000A)
1-0:21.7.0(00.093
kW)
1-0:41.7.0(00.072kW)
1-0:61.7.0(00.132
kW)
1-0:22.7.0(00.000kW)
1-0:42.7.0(00.000
kW)
1-0:62.7.0(00.000kW)
0-1:24.1.0(003)
0-1:96.1.0(4730303539303033393231373531303139)
0-1:24.2.1(210603115000S)(03148.056
m3)
!0D47
tele/tasmota82/RESULT {“SerialReceived”:”/Ene5\T210-D ESMR5.0
1-3:0.2.8(50)
0-0:1.0.0(210603115316S)
kWh)
kWh)
0-0:96.14.0(0002)
1-0:1.7.0(00.299kW)
1-0:2.7.0(00.000
kW)
0-0:96.7.21(00022)
0-0:96.7.9(00006)
1-0:32.32.0(00003)
1-0:52.32.0(00003)
1-0:72.32.0(00003)
1-0:32.36.0(00000)
1-0:52.36.0(00000)
1-0:72.36.0(00000)
0-0:96.13.0()
1-0"}
tele/tasmota82/RESULT {“SerialReceived”:"32.7.0(234.0
V)
1-0:52.7.0(234.0V)
1-0:72.7.0(233.0
V)
1-0:31.7.0(000A)
1-0:51.7.0(000
A)
1-0:71.7.0(000A)
1-0:21.7.0(00.094
kW)
1-0:61.7.0(00.132
kW)
1-0:42.7.0(00.000
kW)
0-1:24.1.0(003)
m3)
!37D8
